[svn:fx-trunk] 16271: Add svn properties for new files
Darrell Loverin May 20, 2010 7:20 PMRevision: 16271
Revision: 16271
Author: dloverin@adobe.com
Date: 2010-05-20 19:20:04 -0700 (Thu, 20 May 2010)
Log Message:
svn:mime-type = text/plain
svn:eol-style = native
QE notes: None
Doc notes: None
Bugs:
Reviewer:
Tests run:
Is noteworthy for integration:
Modified Paths:
flex/sdk/trunk/frameworks/projects/framework/manifest.xml
flex/sdk/trunk/frameworks/projects/mx/build.xml
flex/sdk/trunk/frameworks/projects/mx/defaults-3.0.0.css
flex/sdk/trunk/frameworks/projects/mx/defaults.css
flex/sdk/trunk/frameworks/projects/mx/manifest.xml
flex/sdk/trunk/frameworks/projects/mx/src/MxClasses.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/AnchorStyles.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/BarColorStyle.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/BorderStyles.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/ContainerBackgroundStyles.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/GapStyles.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/LeadingStyle.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/PaddingStyles.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/styles/metadata/TextStyles.as
Property Changed:
