10 Replies Latest reply on May 21, 2010 3:36 PM by Darrell Loverin
    READY event not firing in module (FB4)
    freevryheid Level 1
      Hi guys
      Sorry for posting all this code but I'm unsure how to get my point across otherwise.
      The following block of code loads modules when a context menu is selected. The modules are compiled in the same project as the main application. Each module includes a "modInit" function that is called when the module is READY. The problem is that one of the modules extends a TitleWindow and the READY event is never fired (I checked while debugging). Consequently the module never inits.Another module that calls an Alert.show dialog loads and inits without a problem.
      Are titlewindows a no go in Flex 4 - I noticed a post somewhere that indicated s:Panels are prefered. This problem has been frustating to resolve so any pointers or help is appreciated.
      Thanks in advance,
      Andre
                      for each (menuitem in cm.customItems) {
                          menuitem.addEventListener(ContextMenuEvent.MENU_ITEM_SELECT,
                              function(evt:ContextMenuEvent):void {
                                  var mod:ModuleLoader = new ModuleLoader();
                                  mod.url="mod/"+FindMenuFile(configMenus,evt.currentTarget.caption)+".swf";
                                  mod.addEventListener(ModuleEvent.READY,
                                      function(e:Event):void {
                                          var ichild:IModuleInterface = e.target.child as IModuleInterface;
                                          ichild.modInit();
                                  mod.addEventListener(TxCIT.txEvent.UNLOADMOD,
                                      function(e:txEvent):void {
                                          removeModule(mod);
                                  modArray.push(mod);
                                  createModule(mod);
      Here's the module with the TitleWindow:
      <comp:ModuleTitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
                                 xmlns:mx="library://ns.adobe.com/flex/mx"
                              xmlns:comp="TxCIT.*"
                                 width="400" height="300"
                              close="closeHandler(event);"
                              implements="TxCIT.IModuleInterface">
          <fx:Declarations>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import TxCIT.*;
                  import mx.core.FlexGlobals;
                  import mx.events.CloseEvent;
                  import mx.managers.PopUpManager;
                  public function modInit():void {
                      trace("modCoord init ...");
                      this.title="Coordinates";
                      PopUpManager.addPopUp(this, FlexGlobals.topLevelApplication as DisplayObject, false);
                      PopUpManager.centerPopUp(this);
                  private function closeHandler(e:CloseEvent):void {
                      PopUpManager.removePopUp(this);
                      modExit();
                  private function modExit():void {
                      var params:Object;
                      var evt:txEvent=new txEvent(txEvent.UNLOADMOD,params,true);
                      trace("modCoord ...exit.");
                      dispatchEvent(evt);
          </fx:Script>
      </comp:ModuleTitleWindow>
      Here's ModuleTitleWindow:
      package TxCIT {
          [Frame(factoryClass="mx.core.FlexModuleFactory")]
          import spark.components.TitleWindow;
          public class ModuleTitleWindow extends TitleWindow {
              public function ModuleTitleWindow() {
                  super();
      and here's the interface:
      package TxCIT {
          import flash.events.IEventDispatcher;
          public interface IModuleInterface extends IEventDispatcher
              function modInit():void;
      Here's the module that works:
      <mx:Module xmlns:fx="http://ns.adobe.com/mxml/2009"
          <fx:Declarations>
              <mx:HTTPService id="httpService"
                              resultFormat="e4x"
                              fault="httpService_fault(event);"
                              result="httpService_result(event)" />
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import TxCIT.*;
                  import mx.controls.Alert;
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                      trace("modAbout init ...");
                      loadConfig("xml/modAbout.xml");
                  private function loadConfig(src:String):void {
                      httpService.url = src;
                      httpService.send();
                  private function httpService_fault(evt:FaultEvent):void {
                      Alert.show(evt.fault.faultString, evt.type + " (" + evt.fault.faultCode + ")");
                  private function httpService_result(evt:ResultEvent):void {
                      var config:XML = evt.result as XML;
                      ShowAbout(config);
                  private function ShowAbout(config:XML):void {
                      var msg:String = "TxDOT Cartographic Information System (TxCIT)";
                      msg+="\nVersion: "+config..version;
                      msg+="\nAuthor: "+config..who;
                      msg+="\nCompany: "+config..where;
                      msg+="\nContact: "+config..how;
                      msg+="\nDate: "+config..when;
                      Alert.show(msg,"About",Alert.OK,null,
                          function(e:CloseEvent):void {
                              if (e.detail==Alert.OK) {
                                  modExit();
                      var params:Object;
                      trace("modAbout ...exit.");
                      dispatchEvent(evt);
          </fx:Script>
      </mx:Module>
        • 1. Re: READY event not firing in module (FB4)
          Flex harUI Adobe Employee
          Generate a link-report for the main app and make sure ModuleTitleWindow is
          not in the main app.
          • 2. Re: READY event not firing in module (FB4)
            freevryheid Level 1
            Here's the link report. ModuleTitleWindow is not featured - but neither is modCoord (the TitleWindow module). Weird.
            <report>
              <scripts>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.core:IRepeaterClient)" mod="1262975720635" size="1213" optimizedsize="321">
                  <def id="mx.core:IRepeaterClient" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="_modAbout_Styles.as" mod="1274444452095" size="12174" optimizedsize="11325">
                  <def id="_modAbout_Styles" />
                  <pre id="Object" />
                  <dep id="mx.core:UIComponent" />
                  <dep id="spark.skins.spark:FocusSkin" />
                  <dep id="mx.skins.spark:ScrollBarTrackSkin" />
                  <dep id="mx.skins.spark:BorderSkin" />
                  <dep id="mx.skins.spark:PanelBorderSkin" />
                  <dep id="mx.core:mx_internal" />
                  <dep id="mx.styles:CSSCondition" />
                  <dep id="mx.utils:ObjectUtil" />
                  <dep id="mx.skins.spark:ScrollBarDownButtonSkin" />
                  <dep id="AS3" />
                  <dep id="mx.skins.halo:HaloFocusRect" />
                  <dep id="mx.styles:CSSSelector" />
                  <dep id="mx.skins.spark:DefaultButtonSkin" />
                  <dep id="mx.styles:CSSStyleDeclaration" />
                  <dep id="mx.skins.spark:ContainerBorderSkin" />
                  <dep id="spark.skins.spark:ErrorSkin" />
                  <dep id="mx.skins.halo:BusyCursor" />
                  <dep id="mx.core:UITextField" />
                  <dep id="mx.skins.spark:ButtonSkin" />
                  <dep id="mx.core:IFlexModuleFactory" />
                  <dep id="mx.skins.spark:ScrollBarUpButtonSkin" />
                  <dep id="_modAbout_Styles__embed_css_Assets_swf_mx_skins_cursor_BusyCursor_43142970" />
                  <dep id="mx.skins.halo:ToolTipBorder" />
                  <dep id="mx.skins.spark:ScrollBarThumbSkin" />
                  <dep id="mx.styles:IStyleManager2" />
                </script>
                <script name="_modAbout_FlexInit-generated.as" mod="1274444452110" size="4963" optimizedsize="4344">
                  <def id="_modAbout_FlexInit" />
                  <pre id="Object" />
                  <dep id="mx.collections:ArrayList" />
                  <dep id="mx.messaging.messages:MessagePerformanceInfo" />
                  <dep id="mx.managers.systemClasses:ChildManager" />
                  <dep id="mx.messaging.messages:CommandMessage" />
                  <dep id="en_US$containers_properties" />
                  <dep id="mx.core:TextFieldFactory" />
                  <dep id="en_US$components_properties" />
                  <dep id="en_US$logging_properties" />
                  <dep id="mx.accessibility:UIComponentAccProps" />
                  <dep id="mx.messaging.messages:AsyncMessageExt" />
                  <dep id="mx.utils:ObjectProxy" />
                  <dep id="en_US$layout_properties" />
                  <dep id="mx.messaging.messages:AcknowledgeMessageExt" />
                  <dep id="AS3" />
                  <dep id="mx.accessibility:AlertAccImpl" />
                  <dep id="en_US$messaging_properties" />
                  <dep id="en_US$collections_properties" />
                  <dep id="mx.styles:StyleManagerImpl" />
                  <dep id="mx.messaging.messages:HTTPRequestMessage" />
                  <dep id="mx.messaging.messages:AcknowledgeMessage" />
                  <dep id="en_US$skins_properties" />
                  <dep id="en_US$core_properties" />
                  <dep id="Error" />
                  <dep id="en_US$styles_properties" />
                  <dep id="mx.collections:ArrayCollection" />
                  <dep id="flash.net:registerClassAlias" />
                  <dep id="mx.effects:EffectManager" />
                  <dep id="flash.net:getClassByAlias" />
                  <dep id="en_US$controls_properties" />
                  <dep id="en_US$effects_properties" />
                  <dep id="flash.system:Capabilities" />
                  <dep id="mx.messaging.config:ConfigMap" />
                  <dep id="mx.messaging.messages:ErrorMessage" />
                  <dep id="mx.accessibility:ButtonAccImpl" />
                  <dep id="en_US$rpc_properties" />
                  <dep id="mx.messaging.messages:AsyncMessage" />
                  <dep id="mx.accessibility:PanelAccImpl" />
                  <dep id="mx.messaging.messages:CommandMessageExt" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/skins.propertie s" mod="1264592004000" size="286" optimizedsize="260">
                  <def id="en_US$skins_properties" />
                  <pre id="mx.resources:ResourceBundle" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.resources:IResourceModule)" mod="1262975759135" size="539" optimizedsize="178">
                  <def id="mx.resources:IResourceModule" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.core:IFlexModuleFactory)" mod="1262975720869" size="1415" optimizedsize="437">
                  <def id="mx.core:IFlexModuleFactory" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="flash.utils:Dictionary" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\rpc_rb.swc$locale/en_US/messaging.properties" mod="1262975649588" size="5888" optimizedsize="5789">
                  <def id="en_US$messaging_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\airframework_rb.swc$locale/en_US/collections.propert ies" mod="1262975823447" size="1321" optimizedsize="1278">
                  <def id="en_US$collections_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.resources:IResourceManager)" mod="1262975759150" size="3588" optimizedsize="1031">
                  <def id="mx.resources:IResourceManager" />
                  <pre id="flash.events:IEventDispatcher" />
                  <pre id="Object" />
                  <dep id="flash.system:SecurityDomain" />
                  <dep id="AS3" />
                  <dep id="mx.resources:IResourceBundle" />
                  <dep id="flash.system:ApplicationDomain" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.core:IFlexModule)" mod="1262975722213" size="560" optimizedsize="188">
                  <def id="mx.core:IFlexModule" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc(mx.resources:ResourceBundle) " mod="1264592068000" size="1846" optimizedsize="855">
                  <def id="mx.resources:ResourceBundle" />
                  <pre id="mx.resources:IResourceBundle" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="Error" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.events:RSLEvent)" mod="1262975748463" size="1365" optimizedsize="775">
                  <def id="mx.events:RSLEvent" />
                  <pre id="flash.events:ProgressEvent" />
                  <dep id="flash.events:Event" />
                  <dep id="flash.net:URLRequest" />
                  <dep id="AS3" />
                  <dep id="flash.display:LoaderInfo" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.core:FlexModuleFactory)" mod="1262975721682" size="9960" optimizedsize="5887">
                  <def id="mx.core:FlexModuleFactory" />
                  <pre id="mx.core:IFlexModuleFactory" />
                  <pre id="flash.display:MovieClip" />
                  <dep id="mx.utils:LoaderUtil" />
                  <dep id="flash.text:TextFieldAutoSize" />
                  <dep id="mx.resources:ResourceManager" />
                  <dep id="Error" />
                  <dep id="mx.resources:IResourceManager" />
                  <dep id="mx.core:RSLItem" />
                  <dep id="AS3" />
                  <dep id="mx.core:RSLListLoader" />
                  <dep id="flash.text:TextField" />
                  <dep id="mx.events:ModuleEvent" />
                  <dep id="mx.core:Singleton" />
                  <dep id="flash.utils:Timer" />
                  <dep id="flash.events:TimerEvent" />
                  <dep id="flash.events:ErrorEvent" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.utils:LoaderUtil)" mod="1262975731416" size="2104" optimizedsize="1241">
                  <def id="mx.utils:LoaderUtil" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="Math" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\rpc_rb.swc$locale/en_US/rpc.properties" mod="1262975649573" size="4200" optimizedsize="4124">
                  <def id="en_US$rpc_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.core:IChildList)" mod="1262975721604" size="1469" optimizedsize="497">
                  <def id="mx.core:IChildList" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="flash.display:DisplayObject" />
                  <dep id="flash.geom:Point" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.utils:NameUtil)" mod="1262975731275" size="1899" optimizedsize="1264">
                  <def id="mx.utils:NameUtil" />
                  <pre id="Object" />
                  <dep id="mx.core:IRepeaterClient" />
                  <dep id="SecurityError" />
                  <dep id="flash.utils:getQualifiedClassName" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.graphics:RectangularDropShadow)" mod="1262975734041" size="7005" optimizedsize="3389">
                  <def id="mx.graphics:RectangularDropShadow" />
                  <pre id="Object" />
                  <dep id="mx.core:FlexShape" />
                  <dep id="flash.display:Graphics" />
                  <dep id="flash.display:BitmapData" />
                  <dep id="AS3" />
                  <dep id="flash.geom:Rectangle" />
                  <dep id="flash.geom:Matrix" />
                  <dep id="Math" />
                  <dep id="flash.filters:DropShadowFilter" />
                  <dep id="mx.utils:GraphicsUtil" />
                  <dep id="flash.display:Shape" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.core:RSLItem)" mod="1262975720619" size="2751" optimizedsize="1686">
                  <def id="mx.core:RSLItem" />
                  <pre id="Object" />
                  <dep id="trace" />
                  <dep id="mx.events:RSLEvent" />
                  <dep id="flash.events:IOErrorEvent" />
                  <dep id="flash.display:Loader" />
                  <dep id="flash.events:SecurityErrorEvent" />
                  <dep id="flash.events:ProgressEvent" />
                  <dep id="AS3" />
                  <dep id="flash.system:LoaderContext" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\framework_rb.swc$locale/en_US/logging.properties" mod="1262975823369" size="735" optimizedsize="704">
                  <def id="en_US$logging_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.preloaders:SparkDownloadProgressBar)" mod="1263586859699" size="13103" optimizedsize="6977">
                  <def id="mx.preloaders:SparkDownloadProgressBar" />
                  <pre id="mx.preloaders:IPreloaderDisplay" />
                  <pre id="flash.display:Sprite" />
                  <dep id="mx.graphics:RectangularDropShadow" />
                  <dep id="Math" />
                  <dep id="flash.text:TextFormat" />
                  <dep id="AS3" />
                  <dep id="flash.utils:getDefinitionByName" />
                  <dep id="mx.events:FlexEvent" />
                  <dep id="flash.geom:ColorTransform" />
                  <dep id="flash.utils:getTimer" />
                  <dep id="Error" />
                  <dep id="mx.managers:ISystemManager" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.utils:StringUtil)" mod="1262975731385" size="2760" optimizedsize="1459">
                  <def id="mx.utils:StringUtil" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="RegExp" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.resources:LocaleSorter)" mod="1262975759056" size="10087" optimizedsize="6859">
                  <def id="mx.resources:LocaleSorter" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.managers:ISystemManager)" mod="1262975729447" size="3416" optimizedsize="1009">
                  <def id="mx.managers:ISystemManager" />
                  <pre id="mx.core:IChildList" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="flash.display:Stage" />
                  <dep id="flash.display:Sprite" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/effects.propert ies" mod="1264592004000" size="401" optimizedsize="374">
                  <def id="en_US$effects_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc(mx.resources:IResourceBundle )" mod="1264592024000" size="807" optimizedsize="216">
                  <def id="mx.resources:IResourceBundle" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.core:RSLListLoader)" mod="1262975721525" size="2335" optimizedsize="1114">
                  <def id="mx.core:RSLListLoader" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Documents and Settings\smitad-la\Adobe Flash Builder 4\TxCIT\src\mod\modAbout.mxml" mod="1274358268700" size="4525" optimizedsize="3188">
                  <def id="mod:modAbout" />
                  <pre id="TxCIT:IModuleInterface" />
                  <pre id="mx.modules:Module" />
                  <dep id="TxCIT:txEvent" />
                  <dep id="_modAbout_FlexInit" />
                  <dep id="mx.controls:Alert" />
                  <dep id="trace" />
                  <dep id="mx.core:UIComponentDescriptor" />
                  <dep id="_modAbout_Styles" />
                  <dep id="mx.binding:BindingManager" />
                  <dep id="mx.rpc.events:FaultEvent" />
                  <dep id="mx.rpc.http.mxml:HTTPService" />
                  <dep id="mx.rpc.events:ResultEvent" />
                  <dep id="AS3" />
                  <dep id="mx.events:CloseEvent" />
                  <dep id="XML" />
                  <dep id="mx.events:PropertyChangeEvent" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/controls.proper ties" mod="1264592004000" size="2621" optimizedsize="2556">
                  <def id="en_US$controls_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\textLayout.swc(flashx.textLayout.compose:ISWFContext)" mod="1264794041603" size="679" optimizedsize="234">
                  <def id="flashx.textLayout.compose:ISWFContext" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\spark_rb.swc$locale/en_US/layout.properties" mod="1262975590714" size="344" optimizedsize="317">
                  <def id="en_US$layout_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/styles.properti es" mod="1264592004000" size="301" optimizedsize="275">
                  <def id="en_US$styles_properties" />
                  <dep id="AS3" />
                </script>
                <script name="_modAbout_Styles__embed_css_Assets_swf_mx_skins_cursor_BusyCursor_43142970.as" mod="1262975698000" size="1051" optimizedsize="375">
                  <def id="_modAbout_Styles__embed_css_Assets_swf_mx_skins_cursor_BusyCursor_43142970" />
                  <pre id="mx.core:SpriteAsset" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc(mx.core:mx_internal)" mod="1264592040000" size="226" optimizedsize="109">
                  <def id="mx.core:mx_internal" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.resources:ResourceManager)" mod="1262975759119" size="1134" optimizedsize="657">
                  <def id="mx.resources:ResourceManager" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="mx.resources:ResourceManagerImpl" />
                  <dep id="Error" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.modules:ModuleManagerGlobals)" mod="1262975753306" size="508" optimizedsize="211">
                  <def id="mx.modules:ModuleManagerGlobals" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.core:Singleton)" mod="1262975722604" size="1075" optimizedsize="555">
                  <def id="mx.core:Singleton" />
                  <pre id="Object" />
                  <dep id="AS3" />
                  <dep id="Error" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.events:ResourceEvent)" mod="1262975747650" size="1071" optimizedsize="571">
                  <def id="mx.events:ResourceEvent" />
                  <dep id="AS3" />
                </script>
                <script name="_modAbout_mx_core_FlexModuleFactory.as" mod="1274444452110" size="2654" optimizedsize="1945">
                  <def id="_modAbout_mx_core_FlexModuleFactory" />
                  <pre id="mx.core:FlexModuleFactory" />
                  <pre id="flashx.textLayout.compose:ISWFContext" />
                  <dep id="flash.system:Security" />
                  <dep id="AS3" />
                  <dep id="mx.core:IFlexModule" />
                  <dep id="mx.preloaders:SparkDownloadProgressBar" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.utils:GraphicsUtil)" mod="1262975731354" size="2641" optimizedsize="1443">
                  <def id="mx.utils:GraphicsUtil" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.events:Request)" mod="1263605502111" size="900" optimizedsize="481">
                  <def id="mx.events:Request" />
                  <pre id="flash.events:Event" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.resources:ResourceManagerImpl)" mod="1262975759135" size="12015" optimizedsize="6341">
                  <def id="mx.resources:ResourceManagerImpl" />
                  <pre id="mx.resources:IResourceManager" />
                  <pre id="flash.events:EventDispatcher" />
                  <pre id="Object" />
                  <dep id="mx.resources:LocaleSorter" />
                  <dep id="flash.events:IEventDispatcher" />
                  <dep id="mx.resources:IResourceModule" />
                  <dep id="trace" />
                  <dep id="mx.utils:StringUtil" />
                  <dep id="mx.resources:ResourceBundle" />
                  <dep id="Error" />
                  <dep id="mx.modules:ModuleManager" />
                  <dep id="mx.modules:IModuleInfo" />
                  <dep id="AS3" />
                  <dep id="mx.events:ResourceEvent" />
                  <dep id="flash.events:FocusEvent" />
                  <dep id="mx.managers:SystemManagerGlobals" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.managers:SystemManagerGlobals)" mod="1262975729432" size="849" optimizedsize="429">
                  <def id="mx.managers:SystemManagerGlobals" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.events:ModuleEvent)" mod="1262975748135" size="1345" optimizedsize="729">
                  <def id="mx.events:ModuleEvent" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/core.properties " mod="1264592004000" size="1396" optimizedsize="1356">
                  <def id="en_US$core_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\spark_rb.swc$locale/en_US/components.properties" mod="1262975590667" size="4035" optimizedsize="3969">
                  <def id="en_US$components_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\locale\en_US\automation_agent_rb.swc$locale/en_US/containers.prop erties" mod="1264592004000" size="451" optimizedsize="422">
                  <def id="en_US$containers_properties" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.modules:ModuleManager)" mod="1262975753306" size="10968" optimizedsize="5757">
                  <def id="mx.modules:ModuleManager" />
                  <pre id="mx.modules:IModuleInfo" />
                  <pre id="Object" />
                  <dep id="flash.utils:ByteArray" />
                  <dep id="Error" />
                  <dep id="mx.modules:ModuleManagerGlobals" />
                  <dep id="mx.events:Request" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.modules:IModuleInfo)" mod="1262975753322" size="1730" optimizedsize="534">
                  <def id="mx.modules:IModuleInfo" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.core:FlexShape)" mod="1262975720916" size="864" optimizedsize="496">
                  <def id="mx.core:FlexShape" />
                  <pre id="flash.display:Shape" />
                  <dep id="AS3" />
                  <dep id="Error" />
                  <dep id="mx.utils:NameUtil" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\framework.swc(mx.preloaders:IPreloaderDisplay)" mod="1262975731869" size="2113" optimizedsize="508">
                  <def id="mx.preloaders:IPreloaderDisplay" />
                  <pre id="Object" />
                  <dep id="AS3" />
                </script>
                <script name="C:\Program Files\Adobe\Adobe Flash Builder 4\sdks\4.0.0\frameworks\libs\flash-integration.swc(mx.events:FlexEvent)" mod="1262975747760" size="3240" optimizedsize="2026">
                  <def id="mx.events:FlexEvent" />
                  <dep id="AS3" />
                </script>
              </scripts>
              <external-defs>
                <ext id="mx.core:UIComponent" />
                <ext id="mx.accessibility:AlertAccImpl" />
                <ext id="mx.styles:CSSStyleDeclaration" />
                <ext id="TxCIT:txEvent" />
                <ext id="AS3" />
                <ext id="flash.events:IOErrorEvent" />
                <ext id="mx.styles:IStyleManager2" />
                <ext id="flash.geom:ColorTransform" />
                <ext id="flash.display:DisplayObject" />
                <ext id="mx.messaging.messages:AcknowledgeMessageExt" />
                <ext id="mx.accessibility:UIComponentAccProps" />
                <ext id="TxCIT:IModuleInterface" />
                <ext id="mx.styles:CSSSelector" />
                <ext id="mx.skins.halo:BusyCursor" />
                <ext id="mx.skins.spark:ScrollBarTrackSkin" />
                <ext id="mx.core:UIComponentDescriptor" />
                <ext id="flash.filters:DropShadowFilter" />
                <ext id="flash.events:IEventDispatcher" />
                <ext id="flash.utils:Dictionary" />
                <ext id="mx.utils:ObjectProxy" />
                <ext id="flash.events:SecurityErrorEvent" />
                <ext id="flash.display:MovieClip" />
                <ext id="mx.accessibility:PanelAccImpl" />
                <ext id="flash.events:TimerEvent" />
                <ext id="flash.display:Stage" />
                <ext id="mx.core:TextFieldFactory" />
                <ext id="mx.collections:ArrayCollection" />
                <ext id="XML" />
                <ext id="flash.events:ProgressEvent" />
                <ext id="mx.styles:CSSCondition" />
                <ext id="flash.utils:Timer" />
                <ext id="Math" />
                <ext id="mx.events:CloseEvent" />
                <ext id="flash.events:Event" />
                <ext id="mx.skins.spark:BorderSkin" />
                <ext id="flash.display:LoaderInfo" />
                <ext id="mx.messaging.messages:HTTPRequestMessage" />
                <ext id="mx.effects:EffectManager" />
                <ext id="mx.messaging.messages:AsyncMessageExt" />
                <ext id="flash.display:Loader" />
                <ext id="flash.system:LoaderContext" />
                <ext id="mx.accessibility:ButtonAccImpl" />
                <ext id="flash.geom:Matrix" />
                <ext id="mx.binding:BindingManager" />
                <ext id="mx.messaging.messages:CommandMessageExt" />
                <ext id="mx.controls:Alert" />
                <ext id="mx.messaging.messages:CommandMessage" />
                <ext id="mx.skins.spark:DefaultButtonSkin" />
                <ext id="Error" />
                <ext id="mx.skins.spark:ContainerBorderSkin" />
                <ext id="spark.skins.spark:ErrorSkin" />
                <ext id="spark.skins.spark:FocusSkin" />
                <ext id="mx.skins.spark:PanelBorderSkin" />
                <ext id="SecurityError" />
                <ext id="mx.styles:StyleManagerImpl" />
                <ext id="flash.display:Graphics" />
                <ext id="flash.geom:Point" />
                <ext id="flash.utils:getQualifiedClassName" />
                <ext id="flash.utils:getDefinitionByName" />
                <ext id="flash.text:TextFieldAutoSize" />
                <ext id="flash.utils:getTimer" />
                <ext id="flash.utils:ByteArray" />
                <ext id="flash.net:URLRequest" />
                <ext id="flash.display:Shape" />
                <ext id="mx.skins.spark:ScrollBarDownButtonSkin" />
                <ext id="mx.rpc.http.mxml:HTTPService" />
                <ext id="flash.system:Capabilities" />
                <ext id="mx.modules:Module" />
                <ext id="flash.events:EventDispatcher" />
                <ext id="flash.system:SecurityDomain" />
                <ext id="flash.text:TextField" />
                <ext id="mx.utils:ObjectUtil" />
                <ext id="flash.system:Security" />
                <ext id="mx.skins.spark:ScrollBarThumbSkin" />
                <ext id="RegExp" />
                <ext id="flash.system:ApplicationDomain" />
                <ext id="mx.messaging.messages:ErrorMessage" />
                <ext id="mx.rpc.events:FaultEvent" />
                <ext id="mx.events:PropertyChangeEvent" />
                <ext id="flash.events:FocusEvent" />
                <ext id="mx.core:UITextField" />
                <ext id="flash.net:registerClassAlias" />
                <ext id="mx.skins.halo:HaloFocusRect" />
                <ext id="mx.messaging.messages:AsyncMessage" />
                <ext id="mx.collections:ArrayList" />
                <ext id="mx.managers.systemClasses:ChildManager" />
                <ext id="mx.messaging.messages:MessagePerformanceInfo" />
                <ext id="mx.messaging.messages:AcknowledgeMessage" />
                <ext id="flash.net:getClassByAlias" />
                <ext id="flash.display:BitmapData" />
                <ext id="flash.geom:Rectangle" />
                <ext id="flash.events:ErrorEvent" />
                <ext id="trace" />
                <ext id="mx.skins.spark:ButtonSkin" />
                <ext id="mx.skins.spark:ScrollBarUpButtonSkin" />
                <ext id="mx.rpc.events:ResultEvent" />
                <ext id="Object" />
                <ext id="mx.core:SpriteAsset" />
                <ext id="flash.text:TextFormat" />
                <ext id="flash.display:Sprite" />
                <ext id="mx.messaging.config:ConfigMap" />
                <ext id="mx.skins.halo:ToolTipBorder" />
              </external-defs>
            </report>
            • 3. Re: READY event not firing in module (FB4)
              This looks like the link report for modAbout.mxml, which is a module, not
              the main app.
              • 4. Re: READY event not firing in module (FB4)
                freevryheid Level 1
                the main app.
                I generated the link report via a compiler setting for the project:
                -locale en_US -link-report=c:/temp/externs/report.xml
                • 5. Re: READY event not firing in module (FB4)
                  I don't build module projects with the tools (I use ant scripts).  Somehow,
                  the Flex project should already be creating a link-report in order to
                  optimize the modules, but I don't know where it gets stored or if it is
                  temporary.  I believe that when you add in a link-report compiler option,
                  the modules also generate their link-reports with the same file name,
                  overwriting the prior ones.
                  • 6. Re: READY event not firing in module (FB4)
                    freevryheid Level 1
                    I've conceded defeat - this is too frustrating.
                    • 7. Re: READY event not firing in module (FB4)
                      BTW, did you verify that you get PROGRESS and/or COMPLETE events when
                      loading the module?
                      • 8. Re: READY event not firing in module (FB4)
                        freevryheid Level 1
                        I didn't check -
                        I've decided to redesign the app and all is well. I can't prove it but I suspect the problem was related to using spark components in the module. I changed from a s:TitleWindow to an mx:TitleWindow and everything works OK. Thanks for responding.
                        A
                        • 9. Re: READY event not firing in module (FB4)
                          freevryheid Level 1
                          or if you want to use sparks then hack a popup into the main app before calling the module.
                          var pop:msgBox = msgBox(PopUpManager.createPopUp(this, msgBox, false) as msgBox);
                          PopUpManager.centerPopUp(pop);
                          • 10. Re: READY event not firing in module (FB4)
                            Darrell Loverin Level 4
                            I'd recommend folks listen for ModuleEvent.ERROR. You should get this event in you don't get a ready event.
                            -Darrell
