0 Replies Latest reply on May 21, 2010 1:48 AM by ami078
    swf increase size mystery publishing into Flash 8 and Flash CS4
    ami078
      Hello,
      i discovered recently that a swf build with Flash 8 IDE, published for Flash Player 8 get a different size when published with Flash CS4 IDE.
      You can reproduce that effect with all sort of swf.
      I did a report for each publish (same .fla into Flash 8 IDE and Flash CS4 IDE)
      The result was : all vector graphics, all fonts, all bitmaps, all actionscript code increased
      From test.fla, i did one key frame with :
      - a dynamic TextField with some simple chars in it = "Test Chars",
      - a simple shape with brush tool
      - and one movieclip with an ordinary circle
      Size report from Flash 8 :
      test.swf Rapport sur l'animation
      Image #    Image octets    Total octets    Séquence
            1          14419          14419    Séquence 1 (Image d'exportation des classes AS 2.0)
      Séquence                        Forme octets    Texte octets    ActionScript octets
      Séquence 1                           86           132                     0
      Symbole                       Forme octets    Texte octets    ActionScript octets
      clip_circle                           69             0                     0
      Nom de la police                 octets        Caractères
      Arial                         14056     !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxy z{|}~ˆ˜–—‘’‚“”„†‡•…‰‹›€™
      Size report from Flash CS4 :
            1          18932          18932    Séquence 1 (Image d'exportation des classes AS 2.0)
      Séquence 1                          103           174                     0
      clip_circle                           91             0                     0
      ArialMT                       18467     !"#$%&'()*+,-./0123456789:;<=>?@ABCDEFGHIJKLMNOPQRSTUVWXYZ[\]^_`abcdefghijklmnopqrstuvwxy z{|}~ˆ˜–—‘’‚“”„†‡•…‰‹›€™
      Does somebody knows something about this strange phenomen ?
