5 Replies Latest reply on Jul 20, 2010 8:43 PM by mjrjweb
    How to use SOAP in ColdFusion
    Dileep_NR Level 2
      Hi All,
      The code set am using as follows
      index.cfm
      <cfsavecontent variable="soap">
      <?xml version="1.0" encoding="UTF-8"?>
      <soapenv:Envelope
              xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/"
              xmlns:xsd="http://www.w3.org/2001/XMLSchema"
              xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
              xmlns="http://one.dileep.com/soaptest/"><!---1 this is the cfc location--->
          <soapenv:Header>
          <setInit>1</setInit>
          <!--- 2 header param --->
          </soapenv:Header>
          <soapenv:Body>
              <addNumbers soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" >
              <!---3 cfc method name --->
                  <firstNumber>1000</firstNumber>
                  <secondNumber>10</secondNumber>
              </addNumbers>
             </soapenv:Body>
      </soapenv:Envelope>
      </cfsavecontent>
      <cfhttp url="http://one.dileep.com/soaptest/soaptest.cfc" method="post">
          <cfhttpparam type="header" name="content-type" value="text/xml">
          <cfhttpparam type="header" name="SOAPAction" value="">
          <cfhttpparam type="header" name="content-length" value="#len(soap)#">
          <cfhttpparam type="header" name="charset" value="utf-8">
          <cfhttpparam type="xml" name="message" value="#trim(soap)#">
      </cfhttp>
      <cfdump var="#xmlparse(cfhttp.FileContent)#">
      soaptest.cfc
      <cfcomponent output="false" >
          <cffunction name="addNumbers" access="remote" returntype="any" output="false">
              <cfargument name="firstNumber" type="string" required="true"/>
              <cfargument name="secondNumber" type="string" required="true"/>
              <cfset retunVal="NO">
              <cfset username=0>
              <cfif isSOAPRequest()>
                  <cfset username = getSOAPRequestHeader("http://one.dileep.com/soaptest/", "setInit")>
                  <!---4 retrieving  SOAP header value --->
              </cfif>
              <cfreturn arguments.firstNumber + arguments.secondNumber & username   />
          </cffunction>
      </cfcomponent>
      This is the right way for implimenting SOAP in COLDFUSION webservice ?
      More Questios
      1- <!---1 this is the cfc url--->
      What is the relevance of the cfc URL ? I am using sub domains
      eg : one.dileep.com, two.dileep.com,yyy.dileep.com, in this case the cfc url 'http://<<subdomain>>.dileep.com/soaptest/' should changed accordingly?
      2-<!--- 2 header param --->
      We have to give any tag name as Header?
      3- <!---3 cfc method name --->
      SOAP body  tag must be the method name that we need to exicute?
      Here, I have to execute method 'addNumbers'
      4- <!---4 retrieving  SOAP header value --->
      While retrieving the header value should we need to specify the cfc url?('http://<<subdomain>>.dileep.com/soaptest/')
      Please help.
