1 Reply Latest reply on May 24, 2010 5:05 PM by GordonSmith
    compc task
    athiroy Level 1
      hi
      i use compc task to compile mxml files.
      the ant build file is
      <target name="appcompile">
                  <compc
                      output="${catalina.home}/webapps/${app.name}/CampusPage.swf">
                       <compiler.library-path dir="${FLEX_HOME}/frameworks" append="true">
                          <include name="${web.home}/WEB-INF/lib/" />
                          <include name="${flexsrc.home}/example/" />
                         </compiler.library-path>
                         <load-config filename="${FLEX_HOME}/frameworks/flex-config.xml" />
                         <source-path path-element="${FLEX_HOME}/frameworks" />
                  </compc>
              </target>
      <target name="createHtmlWrapper" depends="appcompile">
        <html-wrapper application="${APP_ROOT}/CampusPage.mxml" height="1000" width="1000"  output="${catalina.home}/webapps/${app.name}" swf="CampusPage" />
      </target>
      but the error is
      [compc] Error: nothing was specified to be included in the library
          [compc] Use 'compc -help' for information about using the command line.
      any body help me
      regards
      athi
        • 1. Re: compc task
          GordonSmith Level 4
          You need to use options like -include-namespaces or -include-classes to tell compc what to put into the SWC. Are you expecting it to put everything on the source path into the SWC? It doesn't work that way.
          Gordon Smith
          Adobe Flex SDK Team
