4 Replies Latest reply on May 21, 2010 5:30 AM by Manystems-Arjen
    Spark textarea in ItemRenderer
    Manystems-Arjen
      I have a problem with text input or text area's in a ItemRenderer.
      I've created an simple ItemRenderer with two textarea's.
      In the creation complete of the ItemRenderer I set the text of the area to an variabele of the data oject of the item renderer.
      Like so:
      chatText.text = this.data.message; (i know for sure that the message string contains text at this point).
      When i use this ItemRenderer in a list it will show rows in the list but the textarea's do not contain any text.
      But when i click on the textarea in one row the text becomes vissible somehow.
      This only happens when is use the spark textarea, the mx textarea shows the text right away.
      Am i missing a setting or so which is new in flex 4?
        • 1. Re: Spark textarea in ItemRenderer
          TeotiGraphix Level 3
          Sounds like a layout issue, can you post the code to your itemRenderer?
          Mike
          • 2. Re: Spark textarea in ItemRenderer
            Manystems-Arjen Level 1
            Yep here's the code:
            <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                                xmlns:mx="library://ns.adobe.com/flex/mx"
                                creationComplete="itemrenderer1_creationCompleteHandler(event)"
                                autoDrawBackground="false"
                 <fx:Script>
                      <![CDATA[
                           import mx.events.FlexEvent;
                           protected function itemrenderer1_creationCompleteHandler(event:FlexEvent):void
                                payload = this.data as ChatMessage;
                                userText.text = this.data.user.name;
                                dateText.text = this.data.date;
                 </fx:Script>
                 <s:HGroup width="100%">
                      <s:TextInput id="userText" editable="false" borderVisible="false"  width="10%"/>
                      <s:TextArea id="chatText" editable="false" borderVisible="false"  width="80%"  />
                      <s:TextInput id="dateText" editable="false" borderVisible="false"  width="10%"/>
                 </s:HGroup>
            </s:ItemRenderer>
            • 3. Re: Spark textarea in ItemRenderer
              Well, looks to me like it's a timing issue, you need to adjust data when the data arrives.
              Try;
                  <fx:Script>
                      <![CDATA[
                          private var payload:ChatMessage;
                          override public function set data(value:Object):void
                              super.data = value;
                              payload = data as ChatMessage;
                              if (!payload)
                                  return;
                              chatText.text = payload.message;
                              userText.text = payload.user.name;
                              dateText.text = payload.date;
                  </fx:Script>
                  </s:HGroup>
              </s:ItemRenderer>
              Mike
              PS If you get a null pointer reply back, you might need invalidation. I can't remeber if the new item renderers have their children created before or after data is set.
              • 4. Re: Spark textarea in ItemRenderer
                Super, this works.
                Thanks a lot.
