3 Replies Latest reply on May 21, 2010 8:54 AM by -BoNzO-
    Bouton.enabled = false; doesn't work
    dhifallah
      hi ,
      I have a datagrid in witch i put button in some culomns.
      I want that when I press a button in one culomn the other buttons in others culmns are disactivated.
      I tried this code , but I have the following error: id attribute is not allowed on the root tag of a component.
      <mx:DataGridColumn
      headerText="Global" dataField="bouton_global" editable="false" width="80">
      <mx:itemRenderer>
      <mx:Component>
      <mx:Button label="B_Global" width="80" id="BoutonGlobal" height="30" click="document.doo1();"/>
      </mx:Component>
      </mx:itemRenderer>
      </mx:DataGridColumn>
      <mx:DataGridColumn headerText="Métier" dataField="metier" editable="false" width="80" >
      <mx:itemRenderer>
      <mx:Component>
      <mx:Button label="B_Métier" width="80" id="BoutonMetier" height="30" click="document.doo2();"/>
      </mx:Component>
      </mx:itemRenderer>
      and in my AS:
      public function doo1(): void
      BoutonMetier.enabled = false;
      Alert.show("coucou1");
      public function doo2(): void
      BoutonGlobal.enabled=false;
      Alert.show("coucou2");
      Can you help me plz
        • 1. Re: Bouton.enabled = false; doesn't work
          -BoNzO- Level 2
          Bonjour,
          The error is correct (!) you are trying to give an id to a root document, even if it's generated by the <mx:component> tag.
          A quick way to unstuck you I can think of is :
          Declare 2 bindable properties :
          [Bindable]
          private boutonMetierEnabled : Boolean;
          [Bindable]
          private boutonGlobalEnabled : Boolean;
          bind to it and update these in the appropriate places.
          Cheers
          • 2. Re: Bouton.enabled = false; doesn't work
            dhifallah Level 1
            Thank you for your reply .
            I tried this:
            in my script :
            Bindable] private var boutonMetierEnabled:Boolean=true;
            Bindable] private var boutonGlobalEnabled:Boolean=true;
            then
            <mx:DataGridColumn
            headerText="Global" dataField="bouton_global" id="BoutonGlobal1" editable="false" width="80">
            <mx:itemRenderer>
            <mx:Component>
            <mx:Button label="B_Global" width="80" height="30" enabled="{(boutonMetierEnabled)?(boutonGlobalEnabled):false}"/>
            </mx:Component>
            </mx:itemRenderer>
            Multiple markers at this line:
            -1120: Accès à la propriété non définie boutonGlobalEnabled.
            -1120: Accès à la propriété non définie boutonMetierEnabled.
            • 3. Re: Bouton.enabled = false; doesn't work
              -BoNzO- Level 2
              Just like you had document.do1, you need to write document.boutonMetierEnabled ( or outerDocument ? Not sure )
              And for the bindable expressions, just enabled="{ document.boutonMetierEnabled }" will be enough.
