4 Replies Latest reply on May 24, 2010 6:16 AM by mlmadque
    HELP PLEASE - loading external swf scale problem
    mlmadque Level 1
      I have a Flex 3 Actionscript Project. Basically all it does it take some flash vars, set the sound volume,  and load an external swf using a loader and add the loader as a child. The problem is I want the loaded external swf to be scaled to fill the entire stage, even if it distorts it, and that doesn't seem to be happening.
      I really need to resolve this. ANY HELP APPRECIATED.
      Marcus
        • 1. Re: HELP PLEASE - loading external swf scale problem
          Flex harUI Adobe Employee
          What is happening, and what does your code look like?
          • 2. Re: HELP PLEASE - loading external swf scale problem
            mlmadque Level 1
            Thanks for the reply!
            Here's basically what my code looks like (note: I cut some stuff out that wasn't relevant for the sake of clarity).
            private var swfLoader:Loader = null;
            public function MySwfContainer()
                stage.scaleMode = StageScaleMode.EXACT_FIT;
                stage.align = StageAlign.TOP_LEFT;
                var request:URLRequest = new URLRequest(swfUrl);
                swfLoader = new Loader();
                swfLoader.contentLoaderInfo.addEventListener(Event.COMPLETE,SWFLoader_Complete);
                swfLoader.load(request);
            private function SWFLoader_Complete(event:Event):void
                addChild(swfLoader);
            What I am observing is that if a swf larger than the stage area is loaded it clips it rather than scale it down and make it fit.
            Marcus
            • 3. Re: HELP PLEASE - loading external swf scale problem
              I don't think StageScaleMode will work on a child SWF.  IIRC, the main SWF
              has a size given to it (500x375) unless you use metadata in your
              project and that is the dimensions that are scaled to fit.  Child content
              doesn't matter.  There is a scalemode post on my blog.
              You will have to set the scaleX/Y on the loader.
              Alex Harui
              Flex SDK Team
              Adobe System, Inc.
              http://blogs.adobe.com/aharui
              • 4. Re: HELP PLEASE - loading external swf scale problem
                mlmadque Level 1
                Ok, I think I have this working as desired now.
                I calculated the desired scaleX/scaleY based on the parent stage width/height and the child width/height. I then set the swfLoader scaleX/scaleY to these calculated values.
                At first the scaleX/scaleY had no affect.
                I finally figured out that I needed to set the stage scaleMode to NO_SCALE. Once I did that the scaleY and scaleY worked.
                Thanks very much for the help.
                Marcus
