[svn:fx-trunk] 16289: Clean up resource bundles in framework and mx projects
Darrell Loverin May 21, 2010 11:48 AMRevision: 16289
Revision: 16289
Author: dloverin@adobe.com
Date: 2010-05-21 11:48:08 -0700 (Fri, 21 May 2010)
Log Message:
Move containers.properties bundle from framework non-en_US locales to mx.
Remove mxControls.properties and mxCore.properties bundles from mx.
QE notes: None
Doc notes: None
Bugs:
Reviewer: Gaurav
Tests run: checkintests
Is noteworthy for integration: No
Modified Paths:
flex/sdk/trunk/frameworks/projects/mx/build.xml
flex/sdk/trunk/frameworks/projects/mx/bundles/da_DK/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/de_DE/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/es_ES/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fi_FI/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fr_FR/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/it_IT/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ja_JP/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ko_KR/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nb_NO/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nl_NL/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/pt_BR/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ru_RU/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/sv_SE/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_CN/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_TW/containers.properties
Removed Paths:
flex/sdk/trunk/frameworks/projects/framework/bundles/da_DK/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/de_DE/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/es_ES/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/fi_FI/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/fr_FR/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/it_IT/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/ja_JP/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/ko_KR/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/nb_NO/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/nl_NL/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/pt_BR/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/ru_RU/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/sv_SE/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/zh_CN/containers.properties
flex/sdk/trunk/frameworks/projects/framework/bundles/zh_TW/containers.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/da_DK/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/da_DK/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/de_DE/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/de_DE/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/en_US/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/en_US/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/en_US/packages.dita
flex/sdk/trunk/frameworks/projects/mx/bundles/es_ES/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/es_ES/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fi_FI/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fi_FI/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fr_FR/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/fr_FR/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/it_IT/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/it_IT/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ja_JP/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ja_JP/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ko_KR/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ko_KR/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nb_NO/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nb_NO/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nl_NL/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/nl_NL/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/pt_BR/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/pt_BR/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ru_RU/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/ru_RU/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/sv_SE/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/sv_SE/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_CN/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_CN/mxCore.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_TW/mxControls.properties
flex/sdk/trunk/frameworks/projects/mx/bundles/zh_TW/mxCore.properties
