1 Reply Latest reply on May 21, 2010 9:06 PM by milligramme
    Color conversion   InDesign CS4 js
    Yuliaart Level 1
      Hi, I need to convert all spot colors in Indd into Process color. Here what I've got that is not working:
      function myConvertColor (){
      var a = 0;
      var myColor = myDoc.colors.item[a];
      for (var a =0; a<myDoc.colors.length; a++){
          myColor.model = ColorModel.PROCESS;
      It stops on the color assigning line.
      Thank you very much for your help.
      Yulia
        • 1. Re: Color conversion   InDesign CS4 js
          milligramme Level 3
          var a = 0;
          Indesign Color-Objects contain reserved colors such as "Paper", "Black", "Registarion", "Cyan", "Magenta", "Yellow".
          You can't change those properties, so use "try ~ catch ~ " statement to escape.
          and expression of myColor  variable is not correct.
          try this code, it will run.
          doc=app.documents[0];
          myConvertColor(doc);
          function myConvertColor (doc){
          var myColor = doc.colors;
          for (var a =0; a<doc.colors.length; a++){
              $.writeln(myColor[a].name);
              try{
                   myColor[a].model = ColorModel.PROCESS;
                   }catch(e){}
