7 Replies Latest reply on Nov 19, 2010 1:15 PM by thewhitedog
    Extension Manager no longer works
    thewhitedog Level 2
      Hi -
      While my extensions still seem to be accessible in Dreamweaver CS4, the Extension Manager no longer works. It launches, but no window ever shows up. This is the case whether I launch it from within Dreamweaver, launch it independently or click on an extension I wish to update. I would appreciate any information on what can cause this problem and how it can be solved.
      I tried uninstalling Extension Manager with the Uninstaller app, but the checkbox for Extension Manager is grayed out and I cannot select it. If I click Select All and then uncheck the apps I don't want to touch, Extension Manager is also deselected. The only way to keep it selected is if I also leave Fireworks, Illustrator and InDesign selected. But uninstalling all these apps seems like a radical alternative. If I trash Extension Manager manually, I cannot select it in the CS4 installer. Presumably I would have to uninstall the other three apps and reinstall them at the same time I reinstall Extension Manager. There are obviously some dependencies between these four apps, but uninstalling and reinstalling them all is a lot of work to go to for a solution that may not even work.
        • 1. Re: Extension Manager no longer works
          Ben M Adobe Community Professional
          What OS are you using?  Have you recently attached your computer to multiple monitors?  I'm just wondering if the extension manager is loading off screen.  If you are on a Mac you just need to delete .plist file for the extension and then it should appear back on your primary screen.
          • 2. Re: Extension Manager no longer works
            thewhitedog Level 2
            Sorry, I should have mentioned my operating system. I'm using Mac OS X 10.6.3 on a 3GHz quad core Mac Pro with 8GB of RAM.
            I don't use a second monitor so I don't know how the window could have moved off screen, but I tried using the Gather Windows button in the Displays preference pane just in case it had somehow gotten lost; no joy. It doesn't show up with Expose either, not with F9 or F10. I tried deleting the com.Adobe.ExtensionManager.plist file, but it makes no difference. Interestingly, when I launched ExtensionManager it did not create a new plist file. I replaced the existing plist file with a copy from another user account where ExtensionManager works; this, too, does no good. If I leave ExtensionManager running a few minutes, eventually it shows up in the Force Quit window as "not responding", so it definitely appears to be hanging up at some point. I tried looking at the Console log as I launch EM but I don't see anything that clearly indicates what's happening. It's mostly Greek to me anyway.
            • 3. Re: Extension Manager no longer works
              rwinn01
              Hello,
              I am having this exact problem, where exactly do I find the .plist file on Mac OS X 10.6.5? I would love to get the Extension Manager back onto my main screen since I no longer have the second monitor.
              Rich
              • 4. Re: Extension Manager no longer works
                Brad Lawryk Adobe Community Professional & MVP
                Have you tried deleting your cache file? It solved the same problem for me.
                http://forums.adobe.com/message/2260933#2260933
                Brad Lawryk
                Adobe Community Professional: Dreamweaver
                Northern British Columbia Adobe Usergroup: Manager
                Thompson Rivers University: Dreamweaver Instructor
                My Adobe Blog: http://blog.lawryk.com
                • 5. Re: Extension Manager no longer works
                  thewhitedog Level 2
                  The plist file for the Adobe Extension Manager is at  /Users/user_name/Library/Preferences/com.adobe.ExtensionManager.plist.
                  I should add that the particular problem I was having - the Extensions Manager not working - turned out to be a permissions problem. Somehow the permissions on my user folder had gotten mangled, which affected applications that needed to access my user folder in order to function. The solution is somewhat complex so, since that does not seem to be what's bothering you, I won't detail it here unless you let me know you need it.
                  • 6. Re: Extension Manager no longer works
                    rwinn01 Level 1
                    Thank you so much.  There actually wasn't the .plist file that was mentioned here, but what I found was two folders deeper adobe/Extension Manager2/exman_uiPreferences.xml that had the position of the extension manager as <windowPosition_x>-950</windowPosition_x> and when I changed that line of the XML to a positive number my extension manager then opened on my main screen again.  Thank you for all your help.  The extension manager needs to be closed before the change is made to the XML file as I found out it will rewrite the file with the old numbers if it is already open when you close it.
                    Rich
                    • 7. Re: Extension Manager no longer works
                      thewhitedog Level 2
                      I saw that XML file, too, while I was rooting around in Adobe related files which, unfortunately, are scattered all over the place. Good job of troubleshooting on your part. This looks to me like a flaw in Adobe's coding, that the window location is not updated when the monitor arrangement changes. Of course, the easiest way to solve the problem would probably have been to connect a second monitor again and drag the window back to the main screen. But you may not have access to another monitor at the moment. In any case, if we can afford the time, trial and error troubleshooting is a good way to learn our way around the system. That was certainly the case with my problem, which actually had nothing to do with Adobe software. I guess I'll never know how my user folder permissions got hosed, but now I know how to fix them if they do - or, rather, I know how to find the article I saved that explained how to fix it.
