3 Replies Latest reply on May 23, 2010 2:00 PM by Sean_Wilson
    lastClick doesn't work?
    Jhon Carlo Level 1
      I tried  the following behaviors:
      1)
      on mouseUp me
      if the lastClick > 10 * 60 then
          go to frame "3"
        end if
      end
      2)
      on exitFrame me
          go to frame "3"
        end if
      end
      Both doesn't work. Why?
        • 1. Re: lastClick doesn't work?
          Sean_Wilson Adobe Community Professional
          The first can't possibly work since you must have clicked the mouse in order to generate a #mouseUp message, meaning the last click will be a matter of milliseconds ago. The second possibly doesn't work because, if you aren't looping on this frameScript (and I don't see a 'go to the frame' command) then at the exact instant the script runs the lastClick condition isn't met.
          Why not just add a 'go to the frame' command:
          on exitFrame me
              go to frame "3"
            else
              go to the frame
            end if
          end
          If this doesn't satisfy, perhaps you could describe what you're trying to accomplish.
          • 2. Re: lastClick doesn't work?
            Jhon Carlo Level 1
            Thanks Sean for your kind reply.
            I apologize for  my previous examples. I have not explained well, I already tried with "go to the frame".
            I don't understand this: whenever you  click the lastClick start from zero?
            I am currently  testing the lastCick to insert it into a larger script.
            Thanks again.
            • 3. Re: lastClick doesn't work?
              I don't understand where there could be any source of confusion! The docs state:
              returns the time in ticks (1 tick = 1/60 of a second) since the mouse button was last pressed.
              Even the property name is self-explanatory - the time elapsed since the mouse was last clicked. Granted it has to be clicked on the stage window (clicks in other applications aren't registered).
              The frameScript modification I posted works exactly as expected for me, and I explained why your first #mouseUp example was never going to work. What again is the difficulty you're experiencing?
