1 Reply Latest reply on May 22, 2010 10:56 AM by Bobby.s
    NetStream.Publish.Failed
    Bobby.s Level 1
      I'm trying to connect 2 swfs over Stratus and the second client is getting NetStream.Publish.Failed when I try to publish a stream. They both have connected to Stratus via the NetConnection and one can publish a stream but the second can not. I've made sue that each swf is using a different name to publish. I can't find this error listed anywhere in the documentation it only listed NetStream.Publish.BadName. I'm using the AIR 2 RC1 beta sdk from adobe labs set to publish for 10.1.
      Are there any other reasons why i would be getting NetStream.Publish.Failed?
        • 1. Re: NetStream.Publish.Failed
          Bobby.s Level 1
          I found out why it was failing. I was entering the peerID I wanted to allow connection from instead of allowing any direction connection.
          so I had:
          stream = new NetStream(connection, farID);
          stream.publish( channel );
          where is should be:
          stream = new NetStream(connection, NetStream.DIRECT_CONNECTIONS);
          then the other client needs to use both my farID and name of my stream in order to connect
