7 Replies Latest reply on May 22, 2010 1:55 PM by Subaroo15
    Fast moving objects get "cropped"
    Subaroo15
      I have got this annoying problem with Flash. Whenever I tween an object fast across the screen the part which points to the direction of the movement of the object gets cropped.
      Here is an example:
      The circle is moving across the screen roughly 3 times every second and as you can see, the front has magically disappeared for some reason. Same thing happens for objects moving slower aswell but the cropped off part is smaller. I could not printscreen this as the screen pauses on the current frame when you do that so that is why I used an external camera. Updating my graphic card drivers has not solved the problem.
      Has anyone else ever had this problem?
      Any help is appreciated.
