1 Reply Latest reply on May 24, 2010 4:42 PM by Peter Flynn (Adobe)
    Custome components under "wirefreame components" tab???
    dfsafdf434
      Is it possible to create my own components and have them appear under the "wireframe components tab"??
        • 1. Re: Custom components under "wireframe components" tab???
          Peter Flynn (Adobe) Adobe Employee
          Every component you create appears in the Library panel (the tab should be just to the left of the Wireframe Components tab).  If you want to re-use these components in a different project, just right-click in the Library panel and click "Export Library Package" (or use the button in the panel footer).  This will create a component library file (.fxpl) which you can then import into other Catalyst projects.
          - Peter
