9 Replies Latest reply on May 27, 2010 7:20 AM by habaki1
    Bug in event manager ?
    habaki1 Level 1
      Hello !
      I installed a JS script that is called on all events by the event manager.
      It works very well, but as soon as i try to print a document, Photoshop seems to be blocked. No tools can be used any more, but some menus work.
      The event manager menu answers: General I/O Error
      In this state, the photoshop process must be deleted with the task manager.
      I already listened a lot of different events with this scrpt and the problem occurs only on print so far.
      The script itself seems not to be the cause. I tested several scripts with less ans less code inside until a simple try catch. Even an empty JSX file shows the problem.
      My version is CS4.
      Does someone know this problem ?
      Is there a work around ?
      Thank you for your help !
      P.S: Could someone make a simple test ? Just add an empty .JSX file into the event manager for all events, and try to print a document ?
        • 1. Re: Bug in event manager ?
          habaki1 Level 1
          Hello  again !
          In fact Photoshop detects and rejects the case of a totally empty script file (0 byte).
          So the test must be made with a JSX file containing at least a space char !
          Thank you again for answers about this problem.
          • 2. Re: Bug in event manager ?
            Michael L Hale Level 5
            I did a quick test for you using CS4 Extended 32bit on WinXP and an Epson printer. The event script I used was a simple alert noting the event being handled. When I  print either to Adobe PDF( Acrobat driver ) or my Epson Photoshop ends up in a similar state. Most but nor all of the menu items are disabled including exit. So I am seeing the same problem.
            • 3. Re: Bug in event manager ?
              I also just did a quick test in CS5 using the same event scirpt and it works as exppected so it looks like the bug/problem is fixed in that version.
              • 4. Re: Bug in event manager ?
                habaki1 Level 1
                Thank you Micheal for all your tests !
                The good news is CS5 seems to fix the problem.
                The very bad news is that it is in fact impossible to execute correctly a script on all events in CS4 and probably in all previous versions!
                • 5. Re: Bug in event manager ?
                  c.pfaffenbichler Level 9
                  Out of curiosity: what kind of Script do you run on all events?
                  • 6. Re: Bug in event manager ?
                    habaki1 Level 1
                    Hello c.pfaffenbichler !
                    My script only needs to catch some events: open, close, select, set, etc...(not all), but it is simplier to install it once for all events.
                    Because :
                    - It can be installed by hand (To install it for each event an installer is needed with a 2nd script).
                    - To catch an additional event, only the script must be modified, not the install process.
                    For this development, i also wrote an "eventviewer" (that prints an event with all arguments into an alert box) to see exactly what is the pattern to match for each action i needed to catch.  This script must be installed for all events.
                    The purpose of the main script is to assign a private context to a document and to each layer of a document: for instance a brush with its diameter, FG and BG colors, etc...
                    • 7. Re: Bug in event manager ?
                      Ah; thanks for the explanation.
                      • 8. Re: Bug in event manager ?
                        You can have the script itself handle the events. And because each event handler slows Photoshop a little I would just register the events needed. Just put the code to register the events near the top of you script and wrap each notifiers.add in a try/catch.
                        if(!app.notifiersEnabled) app.notifiersEnabled = true;// enable notifiers if needed
                        try{// wrap each notifier in a try/catch statement to avoid error if already registered
                             app.notifiers.add("placedLayerEditContents", new File("C:\\editPlacedEvent.jsx"));
                        }catch(e){}
                             app.notifiers.add("slct", new File("C:\\selectLayerEvent.jsx"), "Lyr " );
                        }catch(e){}
                        • 9. Re: Bug in event manager ?
                          habaki1 Level 1
                          Thank you Michael !
                          It's a good idea but there is a fowl-egg problem ! The script must be started to be installed and installed to be started.
                          I was kidding ! It is easy to detect an execution by hand (arguments.length==0) and to call app.notifiers.add only in this case.
                          Nevertheless an uninstaller is also needed to remove the notifiers added for this script. So i wrote a 2nd script with a user interface to install/uninstall the first. It's better because the drop down list of the event manager is also bugged. Removing only some notifiers often does not work properly.
                          Thanks again.
