7 Replies Latest reply on May 24, 2010 2:17 AM by PHANTOMIASA
    Prefix fx for element fx:Script not bound
    PHANTOMIASA Level 1
      Hello!
      I am using Flash Builder 4 with SDK 4 of Flex. Now I get the error that "the prefix "fx" for element "fx:Style" is not bound" in row number 4.
      I have this file called "UserStory.mxml" in the folder "components" to place it via the main.mxml with
      <fx:Script>
              <![CDATA[
                  import components.UserStory;
                  private function init():void {
                      var userStory1:UserStory = new UserStory();
                      userStory1.x = 100;
                      userStory1.y = 100;
                      userStory1.userStoryText = "test";
                      this.addChild(userStory1);
          </fx:Script>
      to place this component onto the screen.
      The file in which the error occurs in row number 4:
      <mx:Canvas xmlns:mx="http://www.adobe.com/2006/mxml" width="300" height="150" styleName="userstory">
          <fx:Style source="styles/styles.css"/>
          <fx:Text x="5" y="5" width="275" height="135" text="{userStoryText}" fontFamily="notes" fontSize="24"/>
          <mx:Script>
              <![CDATA[
                  public var userStoryText:String;
                  private function handleDown(e:Event):void {
                      this.startDrag();
                  private function handleUp(e:Event):void {
                      this.stopDrag();
                  override protected function createChildren():void {
                      super.createChildren();
                      super.addEventListener(MouseEvent.MOUSE_DOWN,handleDown);
                      super.addEventListener(MouseEvent.MOUSE_UP,handleUp);
          </mx:Script>
      </mx:Canvas>
      Can someone tell me what's wrong?
      Thanks a lot in advance & Best Regards.
        • 1. Re: Prefix fx for element fx:Script not bound
          David_F57 Level 5
          hi,
          A see a couple of errors, firstly in flex4 applications you use addElement not addChild, with the component you are applying a variable to the component without making it bindable. Also there is no such thing as fx:Text.
          [Bindable] public var userStoryText:String;
          Also wouldn't it be preferable to use spark components rather than mx components when you are using flex 4. Rather than canvas use SkinnableContainer,
          I also don't understand why you have structured the code the way you have, try something like this
          <s:SkinnableContainer xmlns:fx="http://ns.adobe.com/mxml/2009"
            xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300"
            mouseUp="skinnablecontainer1_mouseUpHandler(event)" mouseDown="skinnablecontainer1_mouseDownHandler(event)">
          <fx:Script>
          <![CDATA[
          [Bindable] public var textStory:String;
          protected function skinnablecontainer1_mouseUpHandler(event:MouseEvent):void
          // TODO Auto-generated method stub
          protected function skinnablecontainer1_mouseDownHandler(event:MouseEvent):void
          </fx:Script>
          <s:TextArea  x="5" y="5" width="275" height="135" text="{userStoryText}" fontFamily="notes" fontSize="24"/>
          </s:SkinnableContainer>
          • 2. Re: Prefix fx for element fx:Script not bound
            David_F57 Level 5
            hi,
            I missed this as well
            <fx:Declarations>
            <fx:Style source="mine.css"/>
            </fx:Declarations>
            things like styles and filters have to be placed in a declaration block.
            David.
            • 3. Re: Prefix fx for element fx:Script not bound
              David_F57 Level 5
              hi,
              Ignore the last post styles are not one of the things you need to place in a declaration block, (its 3am I should be sleeping , brain is malfunctioning slightly)
              I think a lot of your problems are due to not including the fx namespace...
              David.
              • 4. Re: Prefix fx for element fx:Script not bound
                PHANTOMIASA Level 1
                Thanks a lot for your answer.
                I  integrated this, so I have:
                                      xmlns:mx="library://ns.adobe.com/flex/mx" width="300" height="150"
                    <fx:Script>
                        <![CDATA[
                            [Bindable]
                            protected function skinnablecontainer1_mouseUpHandler(event:MouseEvent):void {
                                this.stopDrag();
                            protected function skinnablecontainer1_mouseDownHandler(event:MouseEvent):void {
                                this.startDrag();
                    </fx:Script>
                Now  I get the warning:
                "CSS type selectors are not supported in components:  'spark.components.Application'". It is in the line with mouseUp="" What  has this line to do with CSS? But with CSS there is my problem. I have  in styles.css defined:
                .userstory {
                    borderSkin: Embed(source="assets/story.png");
                But  this css class is not used, so this component does not have this  background image.
                I think the main problem for me is,  that first I start learning flex version 3, but only do some basic  stuff. So I have a little knowledge, and now I have to use Flex 4,  because one flex library, needs Flex 4 and I will test it before I will  buy it.
                So thanks a lot for your help!
                Best  Regards PHANTOMIAS
                • 5. Re: Prefix fx for element fx:Script not bound
                  PHANTOMIASA Level 1
                  The warning "CSS type selectors are not supported in components:   'spark.components.Application'" still exists, but I did this with a skin:
                                        skinClass="skin.SkinBackgroundImageUserStory"
                                        width="300" height="150">
                  So I create a SkinBackgroundImageUserStory with this content:
                  <s:Skin xmlns:fx="http://ns.adobe.com/mxml/2009"
                          xmlns:s="library://ns.adobe.com/flex/spark">
                      <fx:Metadata>
                          [HostComponent("spark.components.SkinnableContainer")]
                      </fx:Metadata>
                      <s:states>
                          <s:State name="normal" />
                          <s:State name="disabled" />
                      </s:states>
                      <s:BitmapImage source="@Embed('styles/assets/story.png')" left="0" right="0" top="0" bottom="0"/>
                      <s:Group id="contentGroup" left="0" right="0" top="0" bottom="0" />
                  </s:Skin>
                  So I have a background, but there is a problem. Attached a screenshot:
                  http://img85.imageshack.us/img85/8080/bimg.jpg
                  The problem is, the background image is in the background, but I want, that the text of userStoryText is in front and you can see the full background image and not the white area of this text. I can change from
                  <s:TextArea />
                  to
                  <s:Label />
                  Then it works. Is this okay?
                  Also, because the CSS does not work, the font family is not used. For that, I do not have a solution and for thar error with the CSS
                  Perhaps someone has an idea how to solve?
                  • 6. Re: Prefix fx for element fx:Script not bound
                    David_F57 Level 5
                    hi,
                    CSS works differently in flex 4, I don't really use css so I haven't looked into it., You can use a label thats fine, you don't need css to set a font to a label or a text area. Look at font embedding if you want to ensure that the font is always available.
                    http://blog.flexexamples.com/2008/10/15/embedding-fonts-in-flex-gumbo/
                    this is an example of using embedded font.
                    David.
                    • 7. Re: Prefix fx for element fx:Script not bound
                      PHANTOMIASA Level 1
                      I think I did this in this way.
                      In my CSS:
                      @font-face {
                          src: url("fonts/rabiohead.ttf");
                          fontFamily: "notes";
                      And then I connect it to the Label:
                      <s:Label x="5" y="5" width="275" height="135" text="{userStoryText}" fontFamily="notes" fontSize="24" color="#FFFFFF"/>
                      But the fontFamily is not used.
                      Update:
                      If I change the
                      <s:Label ... />
                      to
                      <mx:Label ... />
                      then it is working. So this would be a work-around. But how to make this with the Spark component?
                      Best Regards.
