2 Replies Latest reply on May 23, 2010 6:04 PM by thilgen
    air.swf getApplicationVersion()  not returning
    patelbrijeshn Level 1
      I am using air.swf api to detect installed applications... but this doesn't written any call backs...
      any idea ?
      Regards,
      Brijesh
        • 1. Re: air.swf getApplicationVersion()  not returning
          thilgen Level 4
          Not exactly sure what you are asking...there was an issue with a previous version of the Flash Player that would cause the AIR Badge to work improperly...could this be what you are experiencing? Which version of the Flash Player do you have installer on your machine?
          Chris Thilgen
          AIR Engineering
          • 2. Re: air.swf getApplicationVersion()  not returning
            Hi Chris,
            Thanks for the reply...
            I have 2 air applications... From one application, I need to detect if other air application is installed or not.. Fo this I am using the air.swf file..
            and air.getApplicationVersion() method of air.swf...
            But sometimes it doesn't invoke the callback method..
            Also, I was looking to if this feature can be used in offline mode.. As air.swf needs to be downloaded always.. can this be used for offline mode...
            Regards,
            Brijesh
