2 Replies Latest reply on Aug 26, 2007 2:59 PM by signcarver
    DW hangs (?) when renaming a folder
    signcarver Level 1
      I have a site with 292 html files in 2 different directories.
      - I select the folder i want to rename and hit F2 (rename)
      - I change the folder name.
      - DW ask me if i want to update the links and i say yes.
      - DW churns for 40 minutes before i finally interrupt it (Windows task manager says it is not responding)
      - Only a few of the links are change (14 of many thousands).
      Are there any known problems in this area?
      Any suggestions?
      edited to say - i have tried this multiple times and occasionally get a sharing violation on a "tmp" file.
      Steve Racz
        • 1. Re: DW hangs (?) when renaming a folder
          Level 7
          "signcarver" <webforumsuser@macromedia.com> wrote in message
          news:faqi7q$dl9$1@forums.macromedia.com...
          > manager
          > Any suggestions?
          > Thanks,
          > Steve Racz
          Enabling the site cache in your site settings should speed up these
          site-wide operations,
          can you try recreating the site cache from the Site menu?
          Joris
          • 2. Re: DW hangs (?) when renaming a folder
            signcarver Level 1
            Thank you Joris. I did this but the results are the same. I am opening a new post discussing my findings.
            Thank you for your help!
            Steve
