1 Reply Latest reply on Aug 13, 2007 7:00 AM by Sambora
    1046: Type was not found
      I'm using some code which I have use in the past to play movie clips when my Flash video hits a cue point, please see code below at end of message.:
      This is working fine in Flash Player 8/Actionscript 2. But I'd like to use the new .xml captioning option in the Flash 9 Player/Actionscript 3 flv playback component along with this code. When I try to publish using the code above in Flash 9 and Actionscript 3 I get the following error:
      "1046: Type was not found or was not a compile-time constant: Void."
      I looked this error up in the support area and found this link - http://kb.adobe.com/selfservice/viewContent.do?externalId=kb401144&sliceId=2
      I have tried publishing with the Export SWC option checked as suggested but still get the same error. Can anyone tell me what I need to do to fix this please?
      Any help from someone would be fantastic.
      Thanks in advance
