4 Replies Latest reply: May 24, 2010 2:51 PM by auctioneer RSS
    Help with a symbol
    auctioneer Community Member
      Hi
      I'm looking for some way to use-reuse a symbol or any other means of inserting a line at 45% the exact same length and width, the symbol needs to be consistent throughout the entire image no matter how many times it's used.  I'm attempting to show dimensions for a fireplace mantel on the back of a brochure.  I've included a part of the image to hopefully better show what I'm trying to achieve.  Anywhere a line meets at 90% I need to insert the 45% line to define the limit of measurement.  Hopefully I'm making sense ;-))
      I'm using PS CS3...I have CS5 Design Ste but I haven't gotten into it just yet, however if I need to use it for this purpose, then so be it.
      Any help will be greatly appreciated.
      Bob
        • 1. Re: Help with a symbol
          c.pfaffenbichler Community Member
          A Smart Object of the object can be copied multiple times and, if need be, they all be edited in one go – might that help?
          • 2. Re: Help with a symbol
            How do I create a smart object?
            I can draw the symbol with my pen tool and save as a symbol but the problem with this method is the symbol is not consistent, I can't draw it 12 times on the spec sheet and cannot get it exact every time.  I need a line on a 45% angel I can use multiple times on the spec sheet and each 45% line is precise.
            Would it be possible a symbol is not what I'm looking for here?
            Maybe create a seperate.psd on transparent background and simply clone for as many times I need to use this line?
            Thanks..
            • 3. Re: Help with a symbol
              Just make a Layer of the element (by filling or applying a stroke the
              path or …) and use Layer – Smart Objects – Convert to Smart Object.
              Then duplicate, transform, warp, filter, whatever the SO-instances; on
              double-clicking one you can edit the content and on saving those
              changes they will be applied to every instance.
              • 4. Re: Help with a symbol
                Thanks....it took me a while to figure out what you suggested, but once I got my head wrapped around it, and give it a try, it worked perfectly.
                Thanks again..
