0 Replies Latest reply on May 24, 2010 7:39 AM by RicardoFressa
    Flex 3 + Java + Blazeds + SqlServer
    RicardoFressa
      Hello, how are you?
      I have a big problem for my flex interconnect with the database using BlazeDS. Can anyone help me?
      Console server is showing these messages:
      May 24, 2010 11:33:57 AM org.apache.catalina.core.AprLifecycleListener init
      INFO: The APR based Apache Tomcat Native library which allows optimal performance in production environments was not found on the java.library.path: C:\Program Files\Java\jre6\bin;.;C:\Windows\Sun\Java\bin;C:\Windows\system32;C:\Windows;C:/Program Files/Java/jre6/bin/client;C:/Program Files/Java/jre6/bin;C:\Windows\system32;C:\Windows;C:\Windows\System32\Wbem;C:\Windows\Sy stem32\WindowsPowerShell\v1.0\;C:\Program Files\QuickTime\QTSystem\;C:\Program Files\Microsoft SQL Server\100\Tools\Binn\;C:\Program Files\Microsoft SQL Server\100\DTS\Binn\;c:\Program Files\Microsoft SQL Server\100\Tools\Binn\VSShell\Common7\IDE\;C:\Program Files\Common Files\Ahead\Lib\
      May 24, 2010 11:33:57 AM org.apache.tomcat.util.digester.SetPropertiesRule begin
      WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.j2ee.server:BancoJavaFlexBlazeds' did not find a matching property.
      WARNING: [SetPropertiesRule]{Server/Service/Engine/Host/Context} Setting property 'source' to 'org.eclipse.jst.j2ee.server:Integra_java_flex_blazeds' did not find a matching property.
      May 24, 2010 11:33:57 AM org.apache.coyote.http11.Http11Protocol init
      INFO: Initializing Coyote HTTP/1.1 on http-8080
      May 24, 2010 11:33:57 AM org.apache.catalina.startup.Catalina load
      INFO: Initialization processed in 785 ms
      May 24, 2010 11:33:57 AM org.apache.catalina.core.StandardService start
      INFO: Starting service Catalina
      May 24, 2010 11:33:57 AM org.apache.catalina.core.StandardEngine start
      INFO: Starting Servlet Engine: Apache Tomcat/6.0.26
      May 24, 2010 11:33:58 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
      INFO: validateJarFile(C:\eclipse\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\ wtpwebapps\Integra_java_flex_blazeds\WEB-INF\lib\servlet.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
      May 24, 2010 11:33:59 AM org.apache.catalina.loader.WebappClassLoader validateJarFile
      INFO: validateJarFile(C:\eclipse\workspace\.metadata\.plugins\org.eclipse.wst.server.core\tmp0\ wtpwebapps\BancoJavaFlexBlazeds\WEB-INF\lib\servlet.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2. Offending class: javax/servlet/Servlet.class
      May 24, 2010 11:34:00 AM org.apache.coyote.http11.Http11Protocol start
      INFO: Starting Coyote HTTP/1.1 on http-8080
      May 24, 2010 11:34:00 AM org.apache.jk.common.ChannelSocket init
      INFO: JK: ajp13 listening on /0.0.0.0:8009
      May 24, 2010 11:34:00 AM org.apache.jk.server.JkMain start
      INFO: Jk running ID=0 time=0/45  config=null
      May 24, 2010 11:34:00 AM org.apache.catalina.startup.Catalina start
      INFO: Server startup in 2790 ms
      So did my class to list people like this:
      package br.com.ricardo.bancojavaflexblazeds;
      import java.sql.*;
      import javax.swing.JOptionPane;
      public class ServicoJavaPessoa {
      public void listar_pessoas(){
      String driver = "com.microsoft.jdbc.sqlserver.SQLServerDriver";
      String url = "jdbc:microsoft:sqlserver://localhost:1433;DatabaseName=flex";
      String usuario = "Ricardo-PC\\Ricardo";
      String senha = "";
      Connection conexao;
      Statement statement;
      ResultSet resultset;
      try
      Class.forName(driver);
      conexao = DriverManager.getConnection(url, usuario, senha);
      JOptionPane.showMessageDialog(null, "Conexão efetuada com sucesso!");
      catch(ClassNotFoundException Driver)
      JOptionPane.showMessageDialog(null, "Classe do banco de dados não encontrada "+Driver);
      catch(SQLException Banco)
      JOptionPane.showMessageDialog(null, "Erro ao manipular o banco de dados "+Banco);
      My remoting-config.xml file looks like this:
      <?xml version="1.0" encoding="UTF-8"?>
      <service id="remoting-service"
          class="flex.messaging.services.RemotingService">
          <adapters>
              <adapter-definition id="java-object" class="flex.messaging.services.remoting.adapters.JavaAdapter" default="true"/>
          </adapters>
          <default-channels>
              <channel ref="my-amf"/>
          </default-channels>
          <destination id="ServicoJavaPessoa">
          <properties>
          <source>br.com.ricardo.bancojavaflexblazeds.ServicoJavaPessoa</source>
          </properties>
          </destination>
      </service>
      And the error message so when I try to call the java class through the BlazeDS:
      Error: [MessagingError message = 'Destination' ServicoJavaPessoa 'either does not exist for the destination has no channels defined (and the application does not define any default channels.)']
      And my application is like this:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
      <mx:RemoteObject id="ServicoJavaPessoa" destination="ServicoJavaPessoa" fault="faultServicoPessoa(event)">
      <mx:method name="listar_pessoas" fault="faultServicoPessoa(event)"/>
      </mx:RemoteObject>
      <mx:Script>
      <![CDATA[
      import mx.rpc.events.FaultEvent;
      import mx.controls.Alert;
      public function chama_lista_pessoa():void{
      ServicoJavaPessoa.listar_pessoas();
      public function faultServicoPessoa(event:FaultEvent):void{
      Alert.show("Erro: "+event.fault.faultString);
      </mx:Script>
      <mx:Panel x="10" y="10" width="566" height="352" layout="absolute">
      <mx:Button x="10" y="10" label="Popular" width="89" click="{chama_lista_pessoa();}"/>
      <mx:DataGrid x="10" y="56" width="526" height="246">
      <mx:columns>
      <mx:DataGridColumn headerText="Column 1" dataField="col1"/>
      <mx:DataGridColumn headerText="Column 2" dataField="col2"/>
      <mx:DataGridColumn headerText="Column 3" dataField="col3"/>
      </mx:columns>
      </mx:DataGrid>
      </mx:Panel>
      </mx:Application>
      Can someone please help me?
