This content has been marked as final.
Show 6 replies
1. Re: How to load file thru reader which contains non-english char in file name
lrosenth May 24, 2010 12:29 PM (in response to arvindg007)You don't mention what version of Reader? And you are using the AcroPDF.dll, yes?
Sent from my iPad
2. Re: How to load file thru reader which contains non-english char in file name
arvindg007 May 24, 2010 9:23 PM (in response to lrosenth)Reader version is 9.3.2. And yes, I am using AcroPDF.dll for this.
3. Re: How to load file thru reader which contains non-english char in file name
lrosenth May 24, 2010 10:44 PM (in response to arvindg007)Assuming you have a valid Unicode-based string it should work
Sent from my iPad
4. Re: How to load file thru reader which contains non-english char in file name
arvindg007 May 24, 2010 10:50 PM (in response to lrosenth)I have valid unicode string because with the same string, I am able to open document using Acrobat Pro. But Acrobat Reader gives problem.
5. Re: How to load file thru reader which contains non-english char in file name
lrosenth May 25, 2010 2:34 AM (in response to arvindg007)Using the same API or a different one??
6. Re: How to load file thru reader which contains non-english char in file name
arvindg007 May 25, 2010 2:48 AM (in response to lrosenth)In the case of Acrobat Pro, I use another api named OpenInWindowEx.
