1 Reply Latest reply on May 24, 2010 7:26 PM by Amebr
    HTML code missing from .chm file
    ashb22 Level 1
      I'm having an issue with HTML code in a source topic that is not in the .chm file. Here is the code from the source topic:
      <img
      name=imEx
          src="../../../plusCold.gif"
          alt="Expand or collapse item"
      Here is the code from the .chm file:
      <img name="imEx" src alt="Expand or collapse item"
      Note that the src attribute is not pointing to the image; therefore, the image is missing from the .chm file.
      Any idea why this might be happening?
      Ashley
        • 1. Re: HTML code missing from .chm file
          Amebr Level 4
          Is it possible you are linking to a graphic that is outside your project?
          For example, the topic is:
          c:\Help\MyProject\MyFolder\MyTopic.htm
          In this case, the path '../../../MyImage.gif' points to the Help directory, which would be outside the project. (Or maybe it points to C: - I get confused, but you get the picture. )
          I'm not sure if this would strip out the code on compile, but it's something that should be easy to check.
          Amber
