1. Re: Photoshop menu color change?
Stan Jones May 24, 2010 10:09 AM (in response to eVatrik)It depends....
You need to understand color sets:
http://help.adobe.com/en_US/EncoreDVD/4.0/WS59BED893-683B-492e-847C-254257E34581.html
and also button subpictures.
http://help.adobe.com/en_US/EncoreDVD/4.0/WS2CF5669B-310A-4fa7-A52F-7D01AB25A846.html
2. Re: Photoshop menu color change?
eVatrik May 24, 2010 11:03 AM (in response to eVatrik)Thanks, but the problem is not with the buttons, but with my background picture
3. Re: Photoshop menu color change?
Stan Jones May 24, 2010 11:36 AM (in response to eVatrik)Hmmm. No clue. You're doing a "Edit in Photoshop" from Encore, right? so that can't change the color space or somethign like that. Also, as you note, a printscreen back to PS is the same as the appearance in PS.
If you get no better idea, I'd do a test build and see which it looks like on a TV or on the computer from the build.
Are you seeing the same color in Encore in the menu viewer and also in the preview?
4. Re: Photoshop menu color change?
eVatrik May 24, 2010 12:58 PM (in response to eVatrik)I tried to do a test build, and I got the same color that I have in Encore - which is slightly different than photoshop.
Yes I have the same colors in menu viewer and in preview
You can just try this yourself.
Btw, I was using the sunset encore template, if that means anything
5. Re: Photoshop menu color change?
Stan Jones May 24, 2010 1:18 PM (in response to eVatrik)I have never noticed the sort of thing you are seeing.
Are you using any kind of color managed workspace in PS?
I'll have to look at that.
6. Re: Photoshop menu color change?
eVatrik May 25, 2010 6:05 AM (in response to eVatrik)Everything in photoshop is default
The only thing that may be in a relation to this is that I have calibrated my monitor, and set the settings under the color management
btw, I am using Windows 7
7. Re: Photoshop menu color change?
Bill Hunt May 25, 2010 5:43 PM (in response to eVatrik)Remember, PS is a color-managed space, while with Video (Encore here), you do NOT have color management. That difference can be noticeable.
8. Re: Photoshop menu color change?
raj2ashok May 26, 2010 6:14 AM (in response to eVatrik)Hmm.. wild guess: Your menu may contain some sorts of adjustment layers or any other properties which are not imported properly by Encore. Merge all the background layers except buttons and texts in Photoshop and import into Encore and see if this works for you.
