Revision: 16304
Revision: 16304
Author: dloverin@adobe.com
Date: 2010-05-24 13:02:24 -0700 (Mon, 24 May 2010)
Log Message:
Move a couple of classes from mx back to framework
Moved some classes from mx.swc back to framework.swc so that spark.swc does not have any inheritance dependencies on mx.swc. Otherwise the spark RSL would always require the mx RSL. Moved IDropInListItemRenderer, BaseListData, and ITextInput.
Checkintests:
Add a checkintests for the removing unused RSLs feature and the mx split. Verify the Spark-based HelloWord.swf application does not have a definition of ?\226?\128?\156mx.controls.Label?\226?\128?\157 in its ApplicationDomain (verifies the mx RSL was not loaded).
Also fixed compiler ?\226?\128?\156contains an application or module?\226?\128?\157 warnings in:
AnimateConstraintsTests
EasingTests
QE notes: None
Doc notes: None
Bugs:
Reviewer: Alex
Tests run: checkintests
Is noteworthy for integration: No
Modified Paths:
flex/sdk/trunk/build.xml
flex/sdk/trunk/frameworks/projects/framework/src/FrameworkClasses.as
flex/sdk/trunk/frameworks/tests/basicTests/BasicTests-config.xml
flex/sdk/trunk/frameworks/tests/basicTests/BasicTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/AnimateConstraintsTests.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/EasingTests.mxml
Added Paths:
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/BaseListData.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/controls/listClasses/IDropInListItemR enderer.as
flex/sdk/trunk/frameworks/projects/framework/src/mx/core/ITextInput.as
flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/RemoveUnusedRSLsTestScript.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/HelloWorld.mxml
flex/sdk/trunk/frameworks/tests/basicTests/spark/views/RemoveUnusedRSLsTests.mxml
Removed Paths:
flex/sdk/trunk/frameworks/projects/mx/src/mx/controls/listClasses/BaseListData.as
flex/sdk/trunk/frameworks/projects/mx/src/mx/controls/listClasses/IDropInListItemRenderer .as
flex/sdk/trunk/frameworks/projects/mx/src/mx/core/ITextInput.as
