1 Reply Latest reply on Aug 14, 2007 10:51 AM by kglad
    Flash components
    pwmiller Level 1
      I'm looking to create a component that I can drag on to a MC and change the behavior of that clip.
      I'm not looking to create a component that you drag to the stage and appears visually similar to the built in Flash components.
      In a nutshell, I want to be able to drag a component on to an image which has been converted to a MC, and tell it when to appear in the movie by defining start and end frames. The MC (image) will already be on the stage. For example, I may have the MC on frames 100 to 200, but I want to tell the component to fade-in at frame 125 and then fade out at frame 175.
      BTW, I would also like to set the number of frames for the fade-in and fade-out.
      I hope that wasn't too confusing. I would even consider paying for such a component. It would save me a ton of time. I did some searching and could find anything that I thought met the requirements.
      If anyone can help me out, I'd appreciate it.
