3 Replies Latest reply on Aug 13, 2007 7:35 PM by James Newton, ACP
    checking what cursor has specific sprite
    Level 7
      Hi
      I have some animated cursors in my applications
      they are set with command
      global handCursor, defaultCursor
      on beginSprite me
      sprite(me.spriteNum).cursor=handCursor
      end
      on endSprite me
      sprite(me.spriteNum).cursor=defaultCursor
      end
      on mouseDown me
      if random (2)=2 then
      else
      end if
      end
      Everything works fine
      But I can not define in runtime which cursor is set now to this sprite
      following line of code
      if sprite(me.spriteNum).cursor=handCursor then
      is always false, no difference which of 2 cursors is set now to this sprite
      Therefore the question: how can I define what of 2 cursors is active now for
      current sprite
      Any help will be appreciated
        • 1. Re: checking what cursor has specific sprite
          Level 7
          Are you setting the cursor and checking the cursor in the same behavior?
          If you have a behavior that looks like this:
          on beginSprite me
          end
          on endSprite me
          end
          on mouseDown me
          else
          end if
          end
          If you are setting the cursor on a mouseDown event, are you changing the
          cursor on any other action?
          Where are you asking the sprite what its cursor is?
          Rob
          ___________
          Rob Dillon
          Adobe Community Expert
          http://www.ddg-designs.com
          412.243.9119
          • 2. Re: checking what cursor has specific sprite
            Level 7
            I'm asking it from the same script or from another script
            The result is something like "[131080]"
            "Rob Dillon" <rob@-remove-ddg-designs.com> wrote in message
            news:f9pjoe$4q6$1@forums.macromedia.com...
            > on beginSprite me
            > end
            > on endSprite me
            > end
            > on mouseDown me
            > else
            > end if
            > end
            > Rob
            > ___________
            > Rob Dillon
            > 412.243.9119
            • 3. Re: checking what cursor has specific sprite
              James Newton, ACP Level 3
              It sounds as if you are using a cursor member which lives in member 8 of castLib 2. You are doing something like this...
              sprite(1).cursor = member(8, 2)
              ... and Director is understanding this:
              sprite(1).cursor = [member(8, 2).number]
              Note that, for members in castLib 1, Director adds 65536 to the member's .number. If you place a cursor member in member(1, 1), then use...
              sprite(1).cursor = member 1
              ... Director will translate this to:
              sprite(1).cursor = [65537]
              So: you need to make sure that handCursor and defaultCursor are in the format that Director expects. The conversion process is highly convoluted. The handler below does its best to return a value that Director can usefully and safely use, but there may be cases that I haven't tested.
              I suggest that you try:
              handCursor = ConvertToCursor(<whatever value you are currently using for handCursor>)
              defaultCursor = ConvertToCursor(<whatever value you are currently using for defaultCursor>)
