8 Replies Latest reply on May 27, 2010 7:47 PM by Maxijin2
    Flex 4 : List Control Dragging issue
    Maxijin2
      Hi
      Flex 4 List control doesnt allow me to drag an item unless it is selected. OR if i drag an unselected item from a s:List that item becomes selected.
      Is there any way i can drag an item without selecting it?
      <s:List dragEnabled="true"  change="list1_changeHandler(event)" dataProvider="{data}" itemRenderer="components.renderers.customRenderer"/>
        • 1. Re: Flex 4 : List Control Dragging issue
          Flex harUI Adobe Employee
          Doesn't Flex 3 List do the same thing?  I suppose you could detect a change
          to the selectedIndex if a drag-drop is in progress and restore the last
          selectedIndex.
          • 2. Re: Flex 4 : List Control Dragging issue
            Maxijin2 Level 1
            Flex 3 works as expected, Flex 3 doesnt select a list item if a dragndrop is in progress.
            I can detect a change in indexChangeEvent, but dont have any idea of detecting an in-progress Drag n Drop. I think indexChangeEvent occurs first.
            Any guidance?
            • 3. Re: Flex 4 : List Control Dragging issue
              Try IndexChangeEvent.CHANGING to block selection and apply other logic to
              select later if no drag.
              • 4. Re: Flex 4 : List Control Dragging issue
                Maxijin2 Level 1
                But as you know that s:List dragEnabled=true automatically handle dragging, so i dont have any clue how to 'detect' if a dragging is in process? Can you kindly point me to its detection inside IndexChangeEvent.CHANGING handler?
                • 5. Re: Flex 4 : List Control Dragging issue
                  I'm suggesting using IndexChangeEvent.CHANGING to block selection always,
                  and on mouseUp, set selection if there was no drag in between.  If you see a
                  DRAG_START event you know that a drag happened.
                  • 6. Re: Flex 4 : List Control Dragging issue
                    Maxijin2 Level 1
                    I blocked the selection using preventDefault() but now im not even able to initiate dragging.
                    Here is an example code
                                      xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                         <fx:Script>
                              <![CDATA[
                                   import spark.events.IndexChangeEvent;
                                   protected function list1_changingHandler(event:IndexChangeEvent):void
                                        event.preventDefault();
                         </fx:Script>
                         <fx:Declarations>
                              <!-- Place non-visual elements (e.g., services, value objects) here -->
                         </fx:Declarations>
                         <s:layout>
                              <s:VerticalLayout verticalAlign="middle" horizontalAlign="center"/>
                         </s:layout>
                         <s:List dragEnabled="true" changing="list1_changingHandler(event)">
                              <s:ArrayList>
                                   <fx:String>Item One</fx:String>
                                   <fx:String>Item Two</fx:String>
                                   <fx:String>Item Three</fx:String>
                                   <fx:String>Item Four</fx:String>
                              </s:ArrayList>
                         </s:List>
                    </s:Application>
                    • 7. Re: Flex 4 : List Control Dragging issue
                      I'm not clear what you are trying to accomplish. I tried dragging from an
                      mx:List and the thing I moused on and dragged got selected.
                      • 8. Re: Flex 4 : List Control Dragging issue
                        Maxijin2 Level 1
                        I'll make an example with s:List and mx:List and then i'll post here to clear my requirements tonight.
