2 Replies Latest reply on Jun 18, 2010 4:33 AM by sureshdavid
    strange issue in flash cs4.. please ans.. ist BUG?....
    sureshdavid
      Hi I'm using flash cs4.
      Now I got a different strange issue when using mask, which is I'm not  met in my previous experience in flash,
      I have a movieclip in stage, which is contain two layers, that are mask  and maskee, I make the mask object as a movieclip and it'll be animated,  then I returned to stage, It strangely animated in the movieclip  without using play/export option.
      How this possible?...
      I have attached the bug, Please check this and reply me again thanks,
      If this is not issue, please explain why adobe given the mask only play  without export in flash application./....
      I have attached the file, you can also create this again in your flash  also...
      check the attached file here http://www.actionscript.org/forums/attachment.php3?attachmentid=34686&d=1274792512
