4 Replies Latest reply on May 25, 2010 8:36 AM by [Jongware]
    Replace overset text
    Pontus Uggla Level 1
      When I search and replace text in a specific text box I have to make it bigger since I can´t get it to replace overset text.
      Is it possible or do you do the same?
        • 1. Re: Replace overset text
          That is correct; if you use changeText on a text frame, it only works on what's visible.
          But it should be possible to use the same changeText on the entire story in that text box (yourFrame.stories[0]) -- that will include overset text.
          • 2. Re: Replace overset text
            textFrame.stories doesn´t seem to work, only application has stories as far as I can tell. But it does work to loop the paragrahs of the textframe and it seems to be fast enough for me.
            var my_frame = app.documents[0].selection[0];
            app.findTextPreferences = NothingEnum.nothing;
            app.changeTextPreferences = NothingEnum.nothing;
            app.findTextPreferences.findWhat = "find";
            app.changeTextPreferences.changeTo = "replace";
            for(i = 0; i < my_frame.paragraphs.length; i++) {
                my_frame.paragraphs[i].changeText();
            • 3. Re: Replace overset text
              Shonkyin Level 3
              You need to use my_frame.parentStory instead of my_frame.stories.
              Here is working code.
              my_frame.parentStory.changeText()
              Shonky
              • 4. Re: Replace overset text
                Of course
                Each story can have multiple text frames but each frame can only be associated with one single story ... (I should have checked the Help.)
