This content has been marked as final.
Show 9 replies
1. Re: Application error - an exception unknown software exception occurred
Peter Grainge Apr 28, 2006 12:34 AM (in response to Reckingerq)Welcome to the forum.
1] Was RH installed on your PC using your login with admin rights attached at the time of installation or was it installed by IT using one of their logins?
2] Is your project on your hard disk or a network drive?
2. Re: Application error - an exception unknown software exception occurred
Reckingerq Apr 28, 2006 12:43 AM (in response to Reckingerq)Hi Peter,
Thanks for your quick response.
1. I installed Robo with Admin rights (and I'm also using Windows XP on administrator mode);
2. My project is on my hard disk --> local mode.
Maybe my XPJ file is corrupted therefore, I am following your advices to regenerate the XPJ and CPD files (found on your website) : I have already generated a CHM file, I have deleted the CPD and XPJ files and my computer is now opening the HHP file. Maybe this will help... I will keep you posted.
In the meantime, if you have other ideas, they are welcome! -
3. Re: Application error - an exception unknown software exception occurred
Peter Grainge Apr 28, 2006 1:43 AM (in response to Reckingerq)If you still have problems, try opening one of the supplied projects and see if that has the same problems.
4. Re: Application error - an exception unknown software exception occurred
OLH_DEVELOPER Aug 8, 2007 3:40 AM (in response to Reckingerq)Hello,
I have the same problem with RH 6 it terminates, the following is displayed:"the exception unknown software exception (0x4000005) occurred in the application at location0x781346b6" and the only option is click OK to terminate the program.
Any ideas? -
6. Re: Application error - an exception unknown software exception occurred
OLH_DEVELOPER Aug 8, 2007 6:39 AM (in response to Reckingerq)No. -
7. Re: Application error - an exception unknown software exception occurred
Linux Rules Aug 8, 2007 9:45 AM (in response to Reckingerq)Hello OLH DEVELOPER -
Try reloading .NET 1.1 Framework plus all of the updates and security patches (will require numerous reboots/restarts) and see if that helps.
Regards,
GEWB -
8. Application error - an exception unknown software exception occurred
OLH_DEVELOPER Aug 10, 2007 1:44 AM (in response to Reckingerq)Hi all,
I removed the process"CiceroUIWndFrame." responsible for "Speech and Handwriting Recognition" part of Office XP.I do not receive this error anymore.
Take a look at this site for the instruction on how to remove it:
http://www.attention-to-details.com/newslog/391-remove-cicerouiwndframe-to-avoid-crashes.a sp -
9. Re: Application error - an exception unknown software exception occurred
Linux Rules Aug 10, 2007 10:32 AM (in response to Reckingerq)Great work OLH!!!!
Please consider marking your solution so others can search/find/benefit a little easier.
Regards,
GEWB
