The Multiple Image Upload script seems to handle .jpg images
without problems.
However, .gif files return the error:
"Error converting image (image resize). Image processing
library not available or does not support operation. (imagemagick
library is not working or not found)."
The problem is caused by the fact that script that I'm using
tries to pass a parameter that is not valid for gif processing:
myimage.gif' '-quality' '80'
The "quality" parameter works only for jpeg and .png files as
described here:
http://www.imagemagick.org/script/command-line-options.php#quality
and .jpeg files and use the correct parameters so we can resize the
images properly.
Thanks in advance,
Márcio
