2 Replies Latest reply on May 30, 2010 5:10 AM by Flex_
    Editable Datagrid Column
    Flex_
      I have to make a datagrid column editable during runtime based on the data. If the column has a specific data then the column should not be editable otherwise it should be editable. Can we do it in flex ? please show some pointers.
        • 1. Re: Editable Datagrid Column
          UbuntuPenguin Level 4
          I don't have any examples , but you should probably have a custom itemrenderer for your datagrid which contains a textarea. In the itemrenderer should override set data( value:Object ):void.  In that function you check a condition to see if the textarea "editable" value should be set to true or false.  Below I have some pseudo-code.
          <s:Itemrenderer>
          override public function set data( value:Object ):void
            if( object.decidingValue > 0  )
               TnA.editable = false;
            else
               TnA.editable = true;
          <s:TextArea id="TnA" />
          </s:Itemrenderer>
          or you could just put the code in the TextArea declaration
          <s:TextArea id="TnA" editable="{data.decidingValue > 0}" />
          (TextInput area is probably more appropriate than a textarea , but the logic is the same )
          If this response was helpful please mark it as such.
          • 2. Re: Editable Datagrid Column
            Flex_ Level 1
            Thanks for the response.
            The editable property did not work .. but enable="false" worked
