2 Replies Latest reply on May 26, 2010 6:59 AM by the_wine_snob
    Prmiere Slideshow
    PhotoPSD
      I have 100 photos that I need to put into a slideshow through premiere.  I just have a question about the output quality.  I will be playing this mainly on a projector through my laptop (and eventually, on an HD TV).  The photos were taken on a DSLR camera at 3504x2336.  I just want the highest quality export possible.
      But I noticed that the aspect ratio of the photos is different than the video export settings.  I can't crop these pictures (they are portraits), so when I resize them, they will still have the 3:2 aspect ration.  Will this affect the quality of the output video?  If I get it close to the 16:9 aspect ratio, is that good enough?  What settings should I use in premiere to get the best possible output.  I really don't care about black bars on the sides, as long as the video is crystal clear.
        • 1. Re: Prmiere Slideshow
          shooternz Level 6
          Your images will only be as "crystal clea"r as the resolution of your playback or display device.
          Video kind of works in a "fixed resolution" unlike  print media  or a photograph.
          Set up your project to match your display/playback device.
          It will pay to down rez your photos in another application to match the PPRO sequence before you import them.
          There are alternative apps to make Slide shows.
          • 2. Re: Prmiere Slideshow
            the_wine_snob Level 9
            I would set up your Project to match the output of your projector, as Craig suggests. I would also Scale your images in Photoshop (or similar), to match that Frame Size. This ARTICLE will give you tips on automating that Scaling process. Note: I used the SD DV Project pixel x pixel dimensions, but your Project will be HD, so just use the figures from your projector as your guide.
            As for your portrait images, this TUTORIAL might prove useful.
