4 Replies Latest reply on May 26, 2010 11:31 PM by Kasyan Servetsky
    How to find decendent xml element (ID CS4)
    gopaljay78 Level 1
      I have the following xml structure in Indesign document.
      <X>
           <A>
                <B>
                     <C>  </C>
                </B>
           </A>
           <E>
                <F>
                     <C>  </C>
                </F>
           </E>
           <B>
                <C>  </C>
           </B>
      </X>
      I want to find the xml element <C> under <B> tag only. Can anybody suggest me how to get this.
      Gopal
        • 1. Re: How to find decendent xml element (ID CS4)
          PankChat Level 1
          Look Into the XMLRules.
          </X
          • 2. Re: How to find decendent xml element (ID CS4)
            Kasyan Servetsky Level 5
            #target indesign
            #include "/Applications/Adobe InDesign CS3/Scripts/Xml Rules/glue code.jsx"
            var myDocument = app.activeDocument;
            var myCounter = 0;
            var myRuleSet = new Array (new ProcessProduct);
            with(myDocument){
                var elements = xmlElements;
                __processRuleSet(elements.item(0), myRuleSet);
            alert("Found " + myCounter + " \"C\" elements under \"B\" element");
            function ProcessProduct(){
                this.name = "ProcessElements";
                this.xpath = "//B/C";
                this.apply = function(myElement, myRuleProcessor){
                    with(myElement){
                        myCounter++;
                return true;
            • 3. Re: How to find decendent xml element (ID CS4)
              PankChat Level 1
              Apology for bu** in, but my general practice (or for that matter mentioned scripting manual) is that
              should be
                  this.name = "ProcessProduct";
              name of the rule and matches the
              RuleName,but both of them seems to be working fine here.
              Defining correctly in ruleset does the trick
              Does it not matter for having the same name or I am missing something.
              --PC
              • 4. Re: How to find decendent xml element (ID CS4)
                Yes, I agree with you — I just modified an example I posted long ago on this forum and failed to rename the function, although it works this way too.That's what happens when my left eye looks at one computer where I am making color correction, and my right eye reads scripting forum on another.
                Kasyan
