4 Replies Latest reply on Jul 9, 2010 6:34 AM by DarkMatter78
    Problem instalation Flash CS5 with Windows 7
    sabaRab Level 1
      I have a problem with Flas CS5 installation...I read a lot of other discussions about this but i cannot find the solution. I have a new asus pc with windows 7, intel core I5 and a Ati radeon grafhic Card. I tried to run as a administrator, install the new Microsoft Visual C++ 2010 redristibutle...and nothing.
      The installation start (image) but in a few seconds stop and appers this  message error:
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 65 error(s), 65 warning(s)
      WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
      WARNING: OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
      WARNING: Payload cannot be installed due to dependent operation failure
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86: Install failed
      ERROR:  - Adobe Media Player: Install failed
      ERROR:  - SiteCatalyst NetAverages: Install failed
      ERROR:  - Adobe Linguistics CS5 x64: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86: Install failed
      ERROR:  - Adobe Bridge CS5: Install failed
      ERROR:  - Microsoft_VC80_ATL_x86: Install failed
      ERROR:  - AdobePDFL x64 CS5: Install failed
      ERROR:  - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
      ERROR:  - Adobe XMP Panels CS5: Install failed
      ERROR:  - Adobe Player for Embedding: Install failed
      ERROR:  - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
      ERROR:  - Suite Shared Configuration CS5: Install failed
      ERROR:  - Photoshop Camera Raw: Install failed
      ERROR:  - AdobeColorCommonSetCMYK: Install failed
      ERROR:  - AdobeHelp: Install failed
      ERROR:  - Camera Profiles Installer: Install failed
      ERROR:  - Adobe Flash Player 10 Plugin: Install failed
      ERROR:  - AdobeColorJA CS5: Install failed
      ERROR:  - Adobe ReviewPanel CS5: Install failed
      ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
      ERROR:  - Adobe BrowserLab CS Live: Install failed
      ERROR:  - Photoshop Camera Raw (64 bit): Install failed
      ERROR:  - iPhone Publishing: Install failed
      ERROR:  - Microsoft_VC90_MFC_x86: Install failed
      ERROR:  - CSXS Story Extension: Install failed
      ERROR:  - Adobe Media Encoder CS5 X64: Install failed
      ERROR:  - Adobe Linguistics CS5: Install failed
      ERROR:  - PDF Settings CS5: Install failed
      ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
      ERROR:  - AdobeTypeSupport CS5: Install failed
      ERROR:  - AdobeColorCommonSetRGB: Install failed
      ERROR:  - Adobe Player for Embedding x64: Install failed
      ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
      ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
      ERROR:  - Adobe CSXS Extensions CS5: Install failed
      ERROR:  - AdobeOutputModule: Install failed
      ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
      ERROR:  - Microsoft_VC80_CRT_x86: Install failed
      ERROR:  - AdobeCMaps x64 CS5: Install failed
      ERROR:  - AdobeTypeSupport x64 CS5: Install failed
      ERROR:  - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
      ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
      ERROR:  - DynamiclinkSupport: Install failed
      ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
      ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
      ERROR:  - AdobeColorEU CS5: Install failed
      ERROR:  - AdobePDFL CS5: Install failed
      ERROR:  - AdobeCMaps CS5: Install failed
      ERROR:  - AdobeColorNA CS5: Install failed
      ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
      ERROR:  - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
      ERROR:  - Adobe SwitchBoard 2.0: Install failed
      ERROR:  - Adobe Flash CS5: Failed due to Language Pack installation failure
      ERROR:  - Microsoft_VC80_MFC_x86: Install failed
      ERROR:  - Pixel Bender Toolkit: Install failed
      ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
      ERROR:  - Players For Adobe Flash Pro: Install failed
      ERROR:  - Adobe Extension Manager CS5: Install failed
      ERROR:  - AdobeJRE: Install failed
      ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
      ERROR:  - TLF For Adobe Flash Pro: Install failed
      ERROR:  - Adobe AIR: Install failed
      I tried a lot of options but i don't know what more i can do.
      Thank you.
      sabaRab.
        • 1. Re: Problem instalation Flash CS5 with Windows 7
          p_c_e Adobe Employee
          Can you please post the complete log. It should be lying at the following location
          on 32 bit
          <drive>\Program Files\Common Files\Adobe\Installers
          on 64 bit
          <drive>\Program Files (x86)\Common Files\Adobe\Installers
          • 2. Re: Problem instalation Flash CS5 with Windows 7
            sabaRab Level 1
            Complete log.
            [    3824] Sun May 30 22:29:08 2010  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 3.0.121.0
            Win OS version: 6.0.0.0 64 bit Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            Create Required Folders
            Assuming install mode
            ::START TIMER:: [Bootstrap]
            Perform Bootstrapping ...
            :: END TIMER :: [Bootstrap] took 10501.2 miliseconds (10.5012 seconds) DTR = 48.7562 KBPS (0.0476135 MBPS)
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 6397.33 miliseconds (6.39733 seconds) DTR = 4666.95 KBPS (4.55757 MBPS)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Adobe Flash Professional CS5
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
            Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
            Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
            Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
            Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll_x64\Install.db
            Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
            Updating media info for: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_CN\Install.db
            Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeBridge4-mul\Install.db
            Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
            Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-en_USLanguagePack\Install.db
            Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
            Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_US\Install.db
            Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_GB\Install.db
            Updating media info for: {1D855870-28A4-11DF-9731-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-de_DE\Install.db
            Updating media info for: {1D87C970-28A4-11DF-BC69-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_FR\Install.db
            Updating media info for: {1D87C971-28A4-11DF-A2FB-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_CA\Install.db
            Updating media info for: {1D87C972-28A4-11DF-B794-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ja_JP\Install.db
            Updating media info for: {1D8A135E-28A4-11DF-B54E-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-it_IT\Install.db
            Updating media info for: {1D8A135F-28A4-11DF-A7C5-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_ES\Install.db
            Updating media info for: {1D8A1360-28A4-11DF-B5B3-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_MX\Install.db
            Updating media info for: {1D8C8461-28A4-11DF-871D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nl_NL\Install.db
            Updating media info for: {1D8EF561-28A4-11DF-9561-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-sv_SE\Install.db
            Updating media info for: {1D8EF562-28A4-11DF-8D7D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fi_FI\Install.db
            Updating media info for: {1D8EF563-28A4-11DF-AF1B-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nb_NO\Install.db
            Updating media info for: {1D913F4F-28A4-11DF-AE84-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-da_DK\Install.db
            Updating media info for: {1D913F50-28A4-11DF-A78A-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pt_BR\Install.db
            Updating media info for: {1D913F51-28A4-11DF-91B7-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_CN\Install.db
            Updating media info for: {1D93B04F-28A4-11DF-AA22-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_TW\Install.db
            Updating media info for: {1D93B050-28A4-11DF-B472-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ko_KR\Install.db
            Updating media info for: {1D93B051-28A4-11DF-A202-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-cs_CZ\Install.db
            Updating media info for: {1D95FA40-28A4-11DF-90FF-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pl_PL\Install.db
            Updating media info for: {1D95FA41-28A4-11DF-85FA-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ru_RU\Install.db
            Updating media info for: {1D95FA42-28A4-11DF-9C38-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-tr_TR\Install.db
            Updating media info for: {1D986B40-28A4-11DF-BD12-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-uk_UA\Install.db
            Updating media info for: {1D986B41-28A4-11DF-BCC6-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-hu_HU\Install.db
            Updating media info for: {1DA90D10-28A4-11DF-937C-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ro_RO\Install.db
            Updating media info for: {1FD5C861-A5F4-4531-A444-149B65FC4DBC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-fr_FRLanguagePack\Install.db
            Updating media info for: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-sv_SELanguagePack\Install.db
            Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-en_US\Install.db
            Updating media info for: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-it_IT\Install.db
            Updating media info for: {2E18F0BB-569A-4788-A276-FAA40BB923F0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ja_JP\Install.db
            Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeXMPPanelsAll\Install.db
            Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3-mul\Install.db
            Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-mul\Install.db
            Updating media info for: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
            Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All\Install.db
            Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
            Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
            Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
            Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
            Updating media info for: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-nl_NL\Install.db
            Updating media info for: {44F29300-6E52-496A-9B77-531A68E8508A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_TW\Install.db
            Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
            Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeReviewPanel2-mul\Install.db
            Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-mul\Install.db
            Updating media info for: {58020FCB-DE00-491A-9414-3C0263C59EC9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-pt_BRLanguagePack\Install.db
            Updating media info for: {593B4750-2F16-4193-A3FA-40F49BD7A906}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ru_RU\Install.db
            Updating media info for: {597059F2-9EC9-46A5-9EA2-BDBDF354732B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ko_KR\Install.db
            Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\BrowserLabCSLive-mul\Install.db
            Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
            Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\iPhone_Flash11-mul\Install.db
            Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
            Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeStoryExtension-mul\Install.db
            Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All_x64\Install.db
            Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All\Install.db
            Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll\Install.db
            Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
            Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDeviceCentral3-all\Install.db
            Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
            Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10-mul\Install.db
            Updating media info for: {7036A0BD-E490-4ECD-8498-F96911539F99}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-nl_NLLanguagePack\Install.db
            Updating media info for: {73083037-24CD-4F25-AE12-100EBE3B198D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-fr_FR\Install.db
            Updating media info for: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_TW\Install.db
            Updating media info for: {76F9EEBC-B28D-475B-921E-84271789649C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-tr_TR\Install.db
            Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
            Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3_x64-mul\Install.db
            Updating media info for: {7B84FFBD-594D-4269-AC87-E19B44417B8F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-de_DE\Install.db
            Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
            Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
            Updating media info for: {880E072B-D613-4D7A-BD22-55AD5D22C2A9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_CN\Install.db
            Updating media info for: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pl_PL\Install.db
            Updating media info for: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-it_ITLanguagePack\Install.db
            Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
            Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeOutputModuleAll\Install.db
            Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
            Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-en_US\Install.db
            Updating media info for: {95648BD5-9496-4BB7-BE93-303FDB5B6B72}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pt_BR\Install.db
            Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3_x64-mul\Install.db
            Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
            Updating media info for: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-de_DELanguagePack\Install.db
            Updating media info for: {9D2819E4-C51E-4C89-8E28-673B9909A536}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-es_ES\Install.db
            Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
            Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
            Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
            Updating media info for: {B2518294-C06E-44F2-8B1E-1002DD41A6B3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-fr_FR\Install.db
            Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
            Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
            Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9-mul\Install.db
            Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3-mul\Install.db
            Updating media info for: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-sv_SE\Install.db
            Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
            Updating media info for: {C26277B5-5561-4C5C-85E9-D777E0386F6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ja_JP\Install.db
            Updating media info for: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-es_ES\Install.db
            Updating media info for: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pt_BR\Install.db
            Updating media info for: {C6EABDA0-8973-4824-B11A-20EF5B07F537}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-es_ESLanguagePack\Install.db
            Updating media info for: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-nl_NL\Install.db
            Updating media info for: {CC62B471-53FE-4451-8867-F3AA43F3FA31}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-cs_CZ\Install.db
            Updating media info for: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ko_KR\Install.db
            Updating media info for: {CE8FB687-571B-4E4B-881B-445824993FC3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-de_DE\Install.db
            Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SwitchBoard2.0All\Install.db
            Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-mul\Install.db
            Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
            Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
            Updating media info for: {D343E9D0-DD59-45CD-8939-896660D70435}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-tr_TR\Install.db
            Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\aifsdk-win\Install.db
            Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
            Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
            Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Players_Flash11-mul\Install.db
            Updating media info for: {E3354D9C-31B9-4391-8004-92B3FF074762}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ru_RU\Install.db
            Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtensionManager5.0All\Install.db
            Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
            Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeJRECS5-mul\Install.db
            Updating media info for: {E796AA2F-D55C-47D6-887F-24B90AC5151B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pl_PL\Install.db
            Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
            Updating media info for: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-cs_CZ\Install.db
            Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\TLF_Flash11-mul\Install.db
            Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
            Updating media info for: {F9E77304-0ACA-454A-AFD5-9B79CF94B184}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-it_IT\Install.db
            Updating media info for: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-sv_SE\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,3.0.121.0]
            ----------------- CreatePayloadSession: machine is x64 ---------------
            [    3824] Sun May 30 22:29:09 2010  INFO
            ______ Verify Dependency Subscribers ______
            Setting property "INSTALLDIR" to: C:\Program Files\Adobe
            Setting property "installLanguage" to: es_ES
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Overwrite property "userASUPath" to: C:\Users\Aleix\AppData\Local\Adobe\OOBE\PDApp\
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: false
            Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
            Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: false
            Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
            Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: false
            Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
            Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: false
            Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
            Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
            Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
            Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: false
            Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
            Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: false
            Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
            Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false
            Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
            Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false
            Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
            Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: false
            Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
            Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: false
            Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
            Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: false
            Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
            Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
            Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
            Value returned on lookup of payload: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 is: false
            Action string for  {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5  is none
            Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: false
            Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
            Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: false
            Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
            Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
            Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
            Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false
            Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
            Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
            Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
            Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false
            Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
            Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
            Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
            Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
            Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
            Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
            Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
            Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false
            Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
            Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
            Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
            Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
            Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
            Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: false
            Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
            Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: false
            Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
            Value returned on lookup of payload: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is: false
            Action string for  {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN  is none
            Payload {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is: false
            Action string for  {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW  is none
            Payload {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is: false
            Action string for  {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES  is none
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is: false
            Action string for  {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE  is none
            Payload {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is: false
            Action string for  {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR  is none
            Payload {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is: false
            Action string for  {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL  is none
            Payload {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is: false
            Action string for  {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ  is none
            Payload {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is: false
            Action string for  {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR  is none
            Payload {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is: false
            Action string for  {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP  is none
            Payload {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is: false
            Action string for  {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR  is none
            Payload {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is: false
            Action string for  {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE  is none
            Payload {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: false
            Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
            Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is: false
            Action string for  {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU  is none
            Payload {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is: false
            Action string for  {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR  is none
            Payload {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is: false
            Action string for  {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL  is none
            Payload {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is: false
            Action string for  {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT  is none
            Payload {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false
            Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
            Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: false
            Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
            Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: false
            Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
            Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
            Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
            Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false
            Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
            Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: false
            Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
            Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: false
            Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
            Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: false
            Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
            Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: false
            Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
            Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: false
            Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
            Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
            Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
            Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
            Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
            Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
            Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
            Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
            Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
            Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
            Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
            Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: false
            Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
            Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: false
            Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
            Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: false
            Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
            Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false
            Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
            Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
            Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
            Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: false
            Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
            Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: false
            Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
            Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: false
            Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
            Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: false
            Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
            Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: false
            Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
            Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false
            Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
            Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: false
            Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
            Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false
            Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
            Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
            Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
            Value returned on lookup of payload: {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is: false
            Action string for  {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA  is none
            Payload {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
            Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
            Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false
            Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
            Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is: false
            Action string for  {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE  is none
            Payload {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is: false
            Action string for  {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR  is none
            Payload {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is: false
            Action string for  {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA  is none
            Payload {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is: false
            Action string for  {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL  is none
            Payload {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is: false
            Action string for  {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR  is none
            Payload {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is: false
            Action string for  {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR  is none
            Payload {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is: false
            Action string for  {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO  is none
            Payload {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is: false
            Action string for  {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW  is none
            Payload {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is: false
            Action string for  {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP  is none
            Payload {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is: false
            Action string for  {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU  is none
            Payload {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is: false
            Action string for  {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN  is none
            Payload {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is: false
            Action string for  {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR  is none
            Payload {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is: false
            Action string for  {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK  is none
            Payload {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is: false
            Action string for  {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO  is none
            Payload {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is: false
            Action string for  {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU  is none
            Payload {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is: false
            Action string for  {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE  is none
            Payload {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is: false
            Action string for  {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL  is none
            Payload {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is: false
            Action string for  {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX  is none
            Payload {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is: false
            Action string for  {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES  is none
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is: false
            Action string for  {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT  is none
            Payload {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is: false
            Action string for  {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ  is none
            Payload {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is: false
            Action string for  {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI  is none
            Payload {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: false
            Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
            Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
            Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
            Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
            Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
            Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
            Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: false
            Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is install
            Value returned on lookup of payload: {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is: false
            Action string for  {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack  is none
            Payload {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is: false
            Action string for  {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL  is none
            Payload {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is: false
            Action string for  {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR  is none
            Payload {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is: false
            Action string for  {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR  is none
            Payload {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: false
            Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
            Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is: false
            Action string for  {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW  is none
            Payload {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is: false
            Action string for  {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack  is none
            Payload {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is: false
            Action string for  {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR  is none
            Payload {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is: false
            Action string for  {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack  is none
            Payload {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is: false
            Action string for  {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE  is none
            Payload {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: false
            Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is: false
            Action string for  {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN  is none
            Payload {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is: false
            Action string for  {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL  is none
            Payload {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is: false
            Action string for  {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack  is none
            Payload {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is: false
            Action string for  {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU  is none
            Payload {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is: false
            Action string for  {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP  is none
            Payload {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: false
            Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
            Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is: false
            Action string for  {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR  is none
            Payload {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is: false
            Action string for  {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack  is none
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is: false
            Action string for  {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack  is none
            Payload {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is: false
            Action string for  {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ  is none
            Payload {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is: false
            Action string for  {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack  is none
            Payload {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is: false
            Action string for  {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE  is none
            Payload {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is: false
            Action string for  {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT  is none
            Payload {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is: false
            Action string for  {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES  is none
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is extension payload. Aligning its action according to parent.
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
            [    3824] Sun May 30 22:29:10 2010  WARN
            OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            [    3824] Sun May 30 22:29:10 2010  INFO
            ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
            In InstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 48.6221 miliseconds (0.0486221 seconds)
            ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
            :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 31.1839 miliseconds (0.0311839 seconds)
            ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
            CustomHooksTester -> In InstallPreSystemCheckProc
            :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 32.3533 miliseconds (0.0323533 seconds)
            [    3824] Sun May 30 22:29:13 2010  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
            [    6048] Sun May 30 22:29:13 2010  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Installing payload
            Attempting to install package from:C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Command line arguments:
            1: 0 2: 1033 3: 1252
            === Logging started: 30/05/2010  22:29:13 ===
            Message type: 0, Argument: 1033
            Message type: 1, Argument: Microsoft_VC80_CRT_x86
            Action 22:29:13: INSTALL.
            Action start 22:29:13: INSTALL.
            Action 22:29:13: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action start 22:29:13: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action ended 22:29:13: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
            Action 22:29:13: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action start 22:29:13: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action ended 22:29:13: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
            Action 22:29:13: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action start 22:29:13: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action ended 22:29:13: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
            Action 22:29:13: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action start 22:29:13: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action ended 22:29:13: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
            Action 22:29:13: AppSearch. Searching for installed applications
            Action start 22:29:13: AppSearch.
            Action ended 22:29:13: AppSearch. Return value 0.
            Action 22:29:13: LaunchConditions. Evaluating launch conditions
            Action start 22:29:13: LaunchConditions.
            Action ended 22:29:13: LaunchConditions. Return value 0.
            Action 22:29:13: FindRelatedProducts. Searching for related applications
            Action start 22:29:13: FindRelatedProducts.
            Action ended 22:29:13: FindRelatedProducts. Return value 0.
            Action 22:29:13: ValidateProductID.
            Action start 22:29:13: ValidateProductID.
            Action ended 22:29:13: ValidateProductID. Return value 1.
            Action 22:29:13: CostInitialize. Computing space requirements
            Action start 22:29:13: CostInitialize.
            Action ended 22:29:13: CostInitialize. Return value 1.
            Action 22:29:13: FileCost. Computing space requirements
            Action start 22:29:13: FileCost.
            Action ended 22:29:13: FileCost. Return value 1.
            Action 22:29:13: IsolateComponents.
            Action start 22:29:13: IsolateComponents.
            Action ended 22:29:13: IsolateComponents. Return value 0.
            Action 22:29:13: CostFinalize. Computing space requirements
            Action start 22:29:13: CostFinalize.
            Action ended 22:29:13: CostFinalize. Return value 1.
            Action 22:29:13: SetARPINSTALLLOCATION.
            Action start 22:29:13: SetARPINSTALLLOCATION.
            Action ended 22:29:13: SetARPINSTALLLOCATION. Return value 1.
            Action 22:29:13: SetODBCFolders. Initializing ODBC directories
            Action start 22:29:13: SetODBCFolders.
            Action ended 22:29:13: SetODBCFolders. Return value 0.
            Action 22:29:13: MigrateFeatureStates. Migrating feature states from related applications
            Action start 22:29:13: MigrateFeatureStates.
            Action ended 22:29:13: MigrateFeatureStates. Return value 0.
            Action 22:29:13: InstallValidate. Validating install
            Action start 22:29:13: InstallValidate.
            Action ended 22:29:13: InstallValidate. Return value 1.
            Action 22:29:13: RemoveExistingProducts. Removing applications
            Action start 22:29:13: RemoveExistingProducts.
            Action ended 22:29:13: RemoveExistingProducts. Return value 0.
            Action 22:29:13: InstallInitialize.
            Action start 22:29:13: InstallInitialize.
            [    6048] Sun May 30 22:29:14 2010  INFO
            Action ended 22:29:14: InstallInitialize. Return value 1.
            Action 22:29:14: SxsInstallCA.
            Action start 22:29:14: SxsInstallCA.
            1: sxsdelca 2: traceop 3: 1256 4: 0
            1: sxsdelca 2: traceop 3: 1257 4: 0
            1: sxsdelca 2: traceop 3: 1258 4: 0
            1: sxsdelca 2: traceop 3: 1284 4: 0
            1: sxsdelca 2: traceop 3: 1288 4: 0
            1: sxsdelca 2: traceop 3: 1289 4: 0
            1: sxsdelca 2: traceop 3: 1290 4: 0
            1: sxsdelca 2: traceop 3: 1292 4: 0
            1: sxsdelca 2: traceop 3: 1318 4: 0
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca 2: traceop 3: 1306 4: 0
            1: sxsdelca 2: traceop 3: 1307 4: 0
            1: sxsdelca 2: traceop 3: 796 4: 0
            1: sxsdelca 2: traceop 3: 801 4: 0
            1: sxsdelca 2: traceop 3: 802 4: 0
            1: sxsdelca 2: traceop 3: 803 4: 0
            1: sxsdelca 2: traceop 3: 805 4: 0
            1: sxsdelca 2: traceop 3: 812 4: 0
            1: sxsdelca 2: traceop 3: 813 4: 0
            1: sxsdelca 2: traceop 3: 814 4: 0
            1: sxsdelca 2: traceop 3: 819 4: 0
            1: sxsdelca 2: traceop 3: 820 4: 0
            1: sxsdelca 2: traceop 3: 821 4: 0
            1: sxsdelca 2: traceop 3: 827 4: 0
            1: sxsdelca 2: traceop 3: 831 4: 0
            1: sxsdelca 2: traceop 3: 827 4: 259
            1: sxsdelca 2: traceop 3: 1311 4: 0
            1: sxsdelca 2: traceop 3: 1312 4: 0
            1: sxsdelca 2: traceop 3: 1077 4: 0
            1: sxsdelca 2: traceop 3: 1081 4: 0
            1: sxsdelca 2: traceop 3: 1083 4: 0
            1: sxsdelca 2: traceop 3: 1087 4: 0
            1: sxsdelca 2: traceop 3: 1093 4: 0
            1: sxsdelca 2: traceop 3: 1097 4: 0
            1: sxsdelca 2: traceop 3: 1101 4: 0
            1: sxsdelca 2: traceop 3: 1105 4: 0
            1: sxsdelca 2: traceop 3: 1109 4: 0
            1: sxsdelca 2: traceop 3: 1113 4: 0
            1: sxsdelca 2: traceop 3: 1117 4: 0
            1: sxsdelca 2: traceop 3: 1121 4: 0
            1: sxsdelca 2: traceop 3: 1313 4: 0
            1: sxsdelca 2: traceop 3: 1314 4: 0
            1: sxsdelca: Added reg value for  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Added reg value for  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca 2: traceop 3: 1284 4: 259
            1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
            Action ended 22:29:14: SxsInstallCA. Return value 1.
            Action 22:29:14: AllocateRegistrySpace. Allocating registry space
            Action start 22:29:14: AllocateRegistrySpace.
            Action ended 22:29:14: AllocateRegistrySpace. Return value 1.
            Action 22:29:14: ProcessComponents. Updating component registration
            Action start 22:29:14: ProcessComponents.
            Action 22:29:14: GenerateScript. Generating script operations for action:
            Action ended 22:29:14: ProcessComponents. Return value 1.
            Action 22:29:14: UnpublishComponents. Unpublishing Qualified Components
            Action start 22:29:14: UnpublishComponents.
            Action ended 22:29:14: UnpublishComponents. Return value 0.
            Action 22:29:14: MsiUnpublishAssemblies. Unpublishing assembly information
            Action start 22:29:14: MsiUnpublishAssemblies.
            Action ended 22:29:14: MsiUnpublishAssemblies. Return value 1.
            Action 22:29:14: UnpublishFeatures. Unpublishing product features
            Action start 22:29:14: UnpublishFeatures.
            Action ended 22:29:14: UnpublishFeatures. Return value 1.
            Action 22:29:14: StopServices. Stopping services
            Action start 22:29:14: StopServices.
            Action ended 22:29:14: StopServices. Return value 1.
            Action 22:29:14: DeleteServices. Deleting services
            Action start 22:29:14: DeleteServices.
            Action ended 22:29:14: DeleteServices. Return value 1.
            Action 22:29:14: UnregisterComPlus. Unregistering COM+ Applications and Components
            Action start 22:29:14: UnregisterComPlus.
            Action ended 22:29:14: UnregisterComPlus. Return value 0.
            Action 22:29:14: SelfUnregModules. Unregistering modules
            Action start 22:29:14: SelfUnregModules.
            Action ended 22:29:14: SelfUnregModules. Return value 1.
            Action 22:29:14: UnregisterTypeLibraries. Unregistering type libraries
            Action start 22:29:14: UnregisterTypeLibraries.
            Action ended 22:29:14: UnregisterTypeLibraries. Return value 0.
            Action 22:29:14: RemoveODBC. Removing ODBC components
            Action start 22:29:14: RemoveODBC.
            Action ended 22:29:14: RemoveODBC. Return value 1.
            Action 22:29:14: UnregisterFonts. Unregistering fonts
            Action start 22:29:14: UnregisterFonts.
            Action ended 22:29:14: UnregisterFonts. Return value 1.
            Action 22:29:14: RemoveRegistryValues. Removing system registry values
            Action start 22:29:14: RemoveRegistryValues.
            Action ended 22:29:14: RemoveRegistryValues. Return value 1.
            Action 22:29:14: UnregisterClassInfo. Unregister class servers
            Action start 22:29:14: UnregisterClassInfo.
            Action ended 22:29:14: UnregisterClassInfo. Return value 0.
            Action 22:29:14: UnregisterExtensionInfo. Unregistering extension servers
            Action start 22:29:14: UnregisterExtensionInfo.
            Action ended 22:29:14: UnregisterExtensionInfo. Return value 0.
            Action 22:29:14: UnregisterProgIdInfo. Unregistering program identifiers
            Action start 22:29:14: UnregisterProgIdInfo.
            Action ended 22:29:14: UnregisterProgIdInfo. Return value 0.
            Action 22:29:14: UnregisterMIMEInfo. Unregistering MIME info
            Action start 22:29:14: UnregisterMIMEInfo.
            Action ended 22:29:14: UnregisterMIMEInfo. Return value 0.
            Action 22:29:14: RemoveIniValues. Removing INI file entries
            Action start 22:29:14: RemoveIniValues.
            Action ended 22:29:14: RemoveIniValues. Return value 1.
            Action 22:29:14: RemoveShortcuts. Removing shortcuts
            Action start 22:29:14: RemoveShortcuts.
            Action ended 22:29:14: RemoveShortcuts. Return value 0.
            Action 22:29:14: RemoveEnvironmentStrings. Updating environment strings
            Action start 22:29:14: RemoveEnvironmentStrings.
            Action ended 22:29:14: RemoveEnvironmentStrings. Return value 1.
            Action 22:29:14: RemoveDuplicateFiles. Removing duplicated files
            Action start 22:29:14: RemoveDuplicateFiles.
            Action ended 22:29:14: RemoveDuplicateFiles. Return value 1.
            Action 22:29:14: RemoveFiles. Removing files
            Action start 22:29:14: RemoveFiles.
            Action ended 22:29:14: RemoveFiles. Return value 0.
            Action 22:29:14: RemoveFolders. Removing folders
            Action start 22:29:14: RemoveFolders.
            Action ended 22:29:14: RemoveFolders. Return value 0.
            Action 22:29:14: CreateFolders. Creating folders
            Action start 22:29:14: CreateFolders.
            Action ended 22:29:14: CreateFolders. Return value 0.
            Action 22:29:14: MoveFiles. Moving files
            Action start 22:29:14: MoveFiles.
            Action ended 22:29:14: MoveFiles. Return value 1.
            Action 22:29:14: InstallFiles. Copying new files
            Action start 22:29:14: InstallFiles.
            File: Copying new files,  Directory: ,  Size:
            Action ended 22:29:14: InstallFiles. Return value 1.
            Action 22:29:14: PatchFiles. Patching files
            Action start 22:29:14: PatchFiles.
            Action ended 22:29:14: PatchFiles. Return value 0.
            Action 22:29:14: DuplicateFiles. Creating duplicate files
            Action start 22:29:14: DuplicateFiles.
            Action ended 22:29:14: DuplicateFiles. Return value 1.
            Action 22:29:14: BindImage. Binding executables
            Action start 22:29:14: BindImage.
            Action ended 22:29:14: BindImage. Return value 1.
            Action 22:29:14: CreateShortcuts. Creating shortcuts
            Action start 22:29:14: CreateShortcuts.
            Shortcut: Creating shortcuts
            Action ended 22:29:14: CreateShortcuts. Return value 0.
            Action 22:29:14: RegisterClassInfo. Registering class servers
            Action start 22:29:14: RegisterClassInfo.
            Action ended 22:29:14: RegisterClassInfo. Return value 0.
            Action 22:29:14: RegisterExtensionInfo. Registering extension servers
            Action start 22:29:14: RegisterExtensionInfo.
            Action ended 22:29:14: RegisterExtensionInfo. Return value 0.
            Action 22:29:14: RegisterProgIdInfo. Registering program identifiers
            Action start 22:29:14: RegisterProgIdInfo.
            Action ended 22:29:14: RegisterProgIdInfo. Return value 0.
            Action 22:29:14: RegisterMIMEInfo. Registering MIME info
            Action start 22:29:14: RegisterMIMEInfo.
            Action ended 22:29:14: RegisterMIMEInfo. Return value 0.
            Action 22:29:14: WriteRegistryValues. Writing system registry values
            Action start 22:29:14: WriteRegistryValues.
            Key: Writing system registry values, Name: , Value:
            Action ended 22:29:14: WriteRegistryValues. Return value 1.
            Action 22:29:14: WriteIniValues. Writing INI file values
            Action start 22:29:14: WriteIniValues.
            Action ended 22:29:14: WriteIniValues. Return value 1.
            Action 22:29:14: WriteEnvironmentStrings. Updating environment strings
            Action start 22:29:14: WriteEnvironmentStrings.
            Action ended 22:29:14: WriteEnvironmentStrings. Return value 1.
            Action 22:29:14: RegisterFonts. Registering fonts
            Action start 22:29:14: RegisterFonts.
            Action ended 22:29:14: RegisterFonts. Return value 1.
            Action 22:29:14: InstallODBC. Installing ODBC components
            Action start 22:29:14: InstallODBC.
            Action ended 22:29:14: InstallODBC. Return value 0.
            Action 22:29:14: RegisterTypeLibraries. Registering type libraries
            Action start 22:29:14: RegisterTypeLibraries.
            Action ended 22:29:14: RegisterTypeLibraries. Return value 0.
            Action 22:29:14: SelfRegModules. Registering modules
            Action start 22:29:14: SelfRegModules.
            Action ended 22:29:14: SelfRegModules. Return value 1.
            Action 22:29:14: RegisterComPlus. Registering COM+ Applications and Components
            Action start 22:29:14: RegisterComPlus.
            Action ended 22:29:14: RegisterComPlus. Return value 0.
            Action 22:29:14: InstallServices. Installing new services
            Action start 22:29:14: InstallServices.
            Action ended 22:29:14: InstallServices. Return value 1.
            Action 22:29:14: StartServices. Starting services
            Action start 22:29:14: StartServices.
            Action ended 22:29:14: StartServices. Return value 1.
            Action 22:29:14: RegisterUser. Registering user
            Action start 22:29:14: RegisterUser.
            Registering user
            Action ended 22:29:14: RegisterUser. Return value 1.
            Action 22:29:14: RegisterProduct. Registering product
            Action start 22:29:14: RegisterProduct.
            Registering product
            Action ended 22:29:14: RegisterProduct. Return value 1.
            Action 22:29:14: PublishComponents. Publishing qualified components
            Action start 22:29:14: PublishComponents.
            Action ended 22:29:14: PublishComponents. Return value 0.
            Action 22:29:14: MsiPublishAssemblies. Publishing assembly information
            Action start 22:29:14: MsiPublishAssemblies.
            Application Context:Publishing assembly information, Assembly Name:
            Action ended 22:29:14: MsiPublishAssemblies. Return value 1.
            Action 22:29:14: PublishFeatures. Publishing product features
            Action start 22:29:14: PublishFeatures.
            Feature: Publishing product features
            Action ended 22:29:14: PublishFeatures. Return value 1.
            Action 22:29:14: PublishProduct. Publishing product information
            Action start 22:29:14: PublishProduct.
            Action ended 22:29:14: PublishProduct. Return value 1.
            Action 22:29:14: InstallFinalize.
            Action start 22:29:14: InstallFinalize.
            File: msvcr80.dll,  Directory: ,  Size: 632656
            File: msvcp80.dll,  Directory: ,  Size: 554832
            [    6048] Sun May 30 22:29:15 2010  INFO
            File: x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989.cat,  Directory: ,  Size: 7473
            File: x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989.manifest,  Directory: ,  Size: 1870
            File: msvcm80.dll,  Directory: ,  Size: 479232
            File: 8.0.50727.4053.policy,  Directory: ,  Size: 804
            File: 8.0.50727.4053.cat,  Directory: ,  Size: 7495
            Action 22:29:15: CreateShortcuts. Creating shortcuts
            Shortcut: ARPPRODUCTICON.exe
            Action 22:29:15: WriteRegistryValues. Writing system registry values
            Key: \Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents, Name: {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E}, Value: C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\\8.0.50727.4053.policy
            Key: \Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents, Name: {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}, Value: C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\\msvcr80.dll
            Action 22:29:15: RegisterUser. Registering user
            Action 22:29:15: RegisterProduct. Registering product
            Action 22:29:15: MsiPublishAssemblies. Publishing assembly information
            Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e 18e3b",processorArchitecture="x86"
            Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86"
            Action 22:29:15: PublishFeatures. Publishing product features
            Feature: Microsoft_VC80_CRT_x86_
            Action 22:29:15: PublishProduct. Publishing product information
            Error 1935.An error occurred during the installation of assembly component {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Action ended 22:29:15: InstallFinalize. Return value 3.
            Message type: 2, Argument: 0
            Action 22:29:15: Rollback. Rolling back action:
            Registering product
            Registering user
            Creating shortcuts
            Copying new files
            Info 1935.An error occurred during the installation of assembly component {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Info 1935.An error occurred during the installation of assembly component {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Message type: 2, Argument: 1
            Action ended 22:29:15: INSTALL. Return value 3.
            Property(S): DiskPrompt = [1]
            Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
            Property(S): ProductToBeRegistered = 1
            Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            Property(S): SOURCEDIR = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\
            Property(S): PrimaryVolumeSpaceRemaining = 0
            Property(S): PrimaryVolumeSpaceRequired = 0
            Property(S): PrimaryVolumeSpaceAvailable = 0
            Property(S): OutOfNoRbDiskSpace = 0
            Property(S): OutOfDiskSpace = 0
            Property(S): CostingComplete = 1
            Property(S): ROOTDRIVE = D:\
            Property(S): ACTION = INSTALL
            Property(S): SHIMFLAGS = 512
            Property(S): UILevel = 2
            Property(S): OriginalDatabase = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Property(S): DATABASE = C:\Windows\Installer\6839e24.msi
            Property(S): Privileged = 1
            Property(S): MsiRunningElevated = 1
            Property(S): RedirectedDllSupport = 2
            Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
            Property(S): MsiNetAssemblySupport = 2.0.50727.4927
            Property(S): Date = 30/05/2010
            Property(S): Time = 22:29:15
            Property(S): TTCSupport = 1
            Property(S): ColorBits = 32
            Property(S): TextInternalLeading = 3
            Property(S): TextHeight = 16
            Property(S): BorderSide = 1
            Property(S): BorderTop = 1
            Property(S): CaptionHeight = 22
            Property(S): ScreenY = 768
            Property(S): ScreenX = 1024
            Property(S): SystemLanguageID = 3082
            Property(S): ComputerName = ALEIX-PC
            Property(S): UserLanguageID = 3082
            Property(S): UserSID = S-1-5-21-1716922685-3153901978-1194191871-1002
            Property(S): LogonUser = Aleix
            Property(S): MsiTrueAdminUser = 1
            Property(S): AdminUser = 1
            Property(S): VirtualMemory = 6237
            Property(S): PhysicalMemory = 3949
            Property(S): Intel = 6
            Property(S): Msix64 = 6
            Property(S): MsiAMD64 = 6
            Property(S): ShellAdvtSupport = 1
            Property(S): OLEAdvtSupport = 1
            Property(S): GPTSupport = 1
            Property(S): VersionNT = 601
            Property(S): ProgramFilesFolder = C:\Program Files (x86)\
            Property(S): ADOBE = C:\Program Files (x86)\Adobe\
            Property(S): TARGETDIR = D:\
            Property(S): ALLUSERSPROFILE = D:\
            Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
            Property(S): AppDataFolder = C:\Users\Aleix\AppData\Roaming\
            Property(S): CommonAppDataFolder = C:\ProgramData\
            Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
            Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
            Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
            Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
            Property(S): DesktopFolder = C:\Users\Public\Desktop\
            Property(S): FavoritesFolder = C:\Users\Aleix\Favorites\
            Property(S): FontsFolder = C:\Windows\Fonts\
            Property(S): GlobalAssemblyCache = D:\
            Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
            Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
            Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
            Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
            Property(S): LocalAppDataFolder = C:\Users\Aleix\AppData\Local\
            Property(S): MyPicturesFolder = C:\Users\Aleix\Pictures\
            Property(S): PersonalFolder = C:\Users\Aleix\Documents\
            Property(S): PrimaryVolumePath = D:\
            Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
            Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
            Property(S): SendToFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\SendTo\
            Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
            Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
            Property(S): System16Folder = D:\
            Property(S): System64Folder = C:\Windows\SysWOW64\
            Property(S): SystemFolder = C:\Windows\SysWOW64\
            Property(S): SourceDir = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\
            Property(S): TempFolder = C:\Users\Aleix\AppData\Local\Temp\
            Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
            Property(S): USERPROFILE = D:\
            Property(S): WindowsFolder = C:\Windows\
            Property(S): WindowsVolume = C:\
            Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
            Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
            Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
            Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
            Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
            Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
            Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
            Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
            Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
            Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
            Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
            Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
            Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
            Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
            Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
            Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
            Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
            Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
            Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
            Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
            Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
            Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
            Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
            Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
            Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
            Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
            Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
            Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
            Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
            Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
            Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
            Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
            Property(S): ALLUSERS = 1
            Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
            Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
            Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
            Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
            Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
            Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
            Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
            Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
            Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
            Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
            Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
            Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
            Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
            Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
            Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
            Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
            Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
            Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
            Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
            Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
            Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
            Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
            Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
            Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
            Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
            Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
            Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
            Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
            Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
            Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
            Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
            Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
            Property(S): RecentFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Recent\
            Property(S): PrintHoodFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
            Property(S): NetHoodFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
            Property(S): RemoteAdminTS = 1
            Property(S): MsiNTSuitePersonal = 1
            Property(S): MsiNTProductType = 1
            Property(S): ServicePackLevelMinor = 0
            Property(S): ISCHECKFORPRODUCTUPDATES = 1
            Property(S): ApplicationUsers = AllUsers
            Property(S): AgreeToLicense = No
            Property(S): _IsMaintenance = Change
            Property(S): SetupType = Typical
            Property(S): _IsSetupTypeMin = Typical
            Property(S): IS_SQLSERVER_USERNAME = sa
            Property(S): IS_SQLSERVER_AUTHENTICATION = 0
            Property(S): RestartManagerOption = CloseRestart
            Property(S): Display_IsBitmapDlg = 1
            Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
            Property(S): DefaultUIFont = Tahoma8
            Property(S): DialogCaption = InstallShield for Windows Installer
            Property(S): DisplayNameCustom = Custom
            Property(S): DisplayNameMinimal = Minimal
            Property(S): DisplayNameTypical = Typical
            Property(S): DWUSINTERVAL = 30
            Property(S): ErrorDialog = SetupError
            Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
            Property(S): InstallChoice = AR
            Property(S): INSTALLLEVEL = 100
            Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
            Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
            Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
            Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
            Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
            Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
            Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
            Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
            Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
            Property(S): ISVROOT_PORT_NO = 0
            Property(S): Manufacturer = Adobe
            Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
            Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            Property(S): ProductID = none
            Property(S): ProductLanguage = 1033
            Property(S): ProductName = Microsoft_VC80_CRT_x86
            Property(S): ProductVersion = 8.0.50727.4053
            Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
            Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
            Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
            Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
            Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
            Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
            Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
            Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
            Property(S): ProgressType0 = install
            Property(S): ProgressType1 = Installing
            Property(S): ProgressType2 = installed
            Property(S): ProgressType3 = installs
            Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
            Property(S): RebootYesNo = No
            Property(S): ReinstallModeText = omus
            Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
            Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
            Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
            Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
            Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
            Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
            Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
            Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
            Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
            Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
            Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
            Property(S): ARPURLINFOABOUT = http://www.Adobe.com
            Property(S): SHOWLAUNCHPROGRAM = 0
            Property(S): REBOOT = ReallySuppress
            Property(S): ARPSYSTEMCOMPONENT = 1
            Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): ServicePackLevel = 0
            Property(S): WindowsBuild = 7600
            Property(S): VersionNT64 = 601
            Property(S): VersionMsi = 5.00
            Property(S): VersionDatabase = 200
            Property(S): MsiSystemRebootPending = 1
            Property(S): CLIENTPROCESSID = 3552
            Property(S): MSICLIENTUSESEXTERNALUI = 1
            Property(S): CLIENTUILEVEL = 3
            Property(S): CURRENTDIRECTORY = C:\Users\Aleix\AppData\Local\Adobe\OOBE\PDApp\DWA
            Property(S): USERNAME = Aleix
            Property(S): PackagecodeChanging = 1
            Property(S): ProductState = -1
            Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
            === Logging stopped: 30/05/2010  22:29:15 ===
            1: 2 2: 0
            1: 2 2: 1
            Installation result: 1603
            Third party payload succeded.  Testing return code: 1603
            [    3824] Sun May 30 22:29:16 2010  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 3008.79 miliseconds (3.00879 seconds) DTR = 38.5537 KBPS (0.0376501 MBPS)
            User specified overrideFile:
            Calling the ROLLBACK custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
            [    3824] Sun May 30 22:29:16 2010  WARN
            Payload cannot be installed due to dependent operation failure
            Skipping payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 as payload is not cached
            Skipping payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 as payload is not cached
            Skipping payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 as payload is not cached
            Skipping payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding as payload is not cached
            Skipping payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 as payload is not cached
            Skipping payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 as payload is not cached
            Skipping payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE as payload is not cached
            Skipping payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer as payload is not cached
            Skipping payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport as payload is not cached
            Skipping payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 as payload is not cached
            Skipping payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 as payload is not cached
            Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
            Skipping payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 as payload is not cached
            Skipping payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 as payload is not cached
            Skipping payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 as payload is not cached
            Skipping payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp as payload is not cached
            Skipping payload {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 as payload is not cached
            Skipping payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 as payload is not cached
            Skipping payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule as payload is not cached
            Skipping payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 as payload is not cached
            Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
            Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
            Skipping payload {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 as payload is not cached
            Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
            Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
            Skipping payload {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit as payload is not cached
            Skipping payload {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro as payload is not cached
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} can not be installed due to dependent operation failure.
            Skipping payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES as payload is not cached
            Skipping payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR as payload is not cached
            Skipping payload {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live as payload is not cached
            Skipping payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX as payload is not cached
            Skipping payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin as payload is not cached
            Skipping payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player as payload is not cached
            Skipping payload {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 as payload is not cached
            Skipping payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 as payload is not cached
            Skipping payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 as payload is not cached
            Skipping payload {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 as payload is not cached
            Skipping payload {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 as payload is not cached
            Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
            Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
            Skipping payload {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 as payload is not cached
            Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
            Skipping payload {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 as payload is not cached
            Skipping payload {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 as payload is not cached
            Skipping payload {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 as payload is not cached
            Skipping payload {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension as payload is not cached
            Skipping payload {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 as payload is not cached
            Skipping payload {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) as payload is not cached
            Skipping payload {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro as payload is not cached
            Skipping payload {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages as payload is not cached
            Skipping payload {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro as payload is not cached
            Skipping payload {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing as payload is not cached
            Skipping payload {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 as payload is not cached
            Skipping payload {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 as payload is not cached
            Skipping payload {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 as payload is not cached
            Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} can not be installed due to dependent operation failure.
            Skipping payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES as payload is not cached
            Skipping payload {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 as payload is not cached
            Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
            [    3824] Sun May 30 22:29:17 2010  WARN
            [    3824] Sun May 30 22:29:17 2010  INFO
            Skipping payload {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 as payload is not cached
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} can not be installed due to dependent operation failure.
            Skipping payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul as payload is not cached
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} can not be installed due to dependent operation failure.
            Skipping payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES as payload is not cached
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} can not be installed due to dependent operation failure.
            Skipping payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
            [    3824] Sun May 30 22:29:19 2010  INFO
            Total components installed: 0
            Total components repaired: 0
            Total components removed: 0
            [    3824] Sun May 30 22:29:19 2010 ERROR
            The following payload errors were found during install:
            - Adobe CSXS Infrastructure CS5: Install failed
            - Microsoft_VC90_ATL_x86: Install failed
            - Adobe Media Player: Install failed
            - SiteCatalyst NetAverages: Install failed
            - Adobe Linguistics CS5 x64: Install failed
            - Microsoft_VC90_CRT_x86: Install failed
            - Adobe Bridge CS5: Install failed
            - Microsoft_VC80_ATL_x86: Install failed
            - AdobePDFL x64 CS5: Install failed
            - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            - Adobe XMP Panels CS5: Install failed
            - Adobe Player for Embedding: Install failed
            - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            - Suite Shared Configuration CS5: Install failed
            - Photoshop Camera Raw: Install failed
            - AdobeColorCommonSetCMYK: Install failed
            - AdobeHelp: Install failed
            - Camera Profiles Installer: Install failed
            - Adobe Flash Player 10 Plugin: Install failed
            - AdobeColorJA CS5: Install failed
            - Adobe ReviewPanel CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            - Adobe BrowserLab CS Live: Install failed
            - Photoshop Camera Raw (64 bit): Install failed
            - iPhone Publishing: Install failed
            - Microsoft_VC90_MFC_x86: Install failed
            - CSXS Story Extension: Install failed
            - Adobe Media Encoder CS5 X64: Install failed
            - Adobe Linguistics CS5: Install failed
            - PDF Settings CS5: Install failed
            - DeviceCentral: Failed due to Language Pack installation failure
            - AdobeTypeSupport CS5: Install failed
            - AdobeColorCommonSetRGB: Install failed
            - Adobe Player for Embedding x64: Install failed
            - Adobe Flash Player 10 ActiveX: Install failed
            - Microsoft_VC90_ATL_x86_x64: Install failed
            - Adobe CSXS Extensions CS5: Install failed
            - AdobeOutputModule: Install failed
            - Microsoft_VC90_CRT_x86_x64: Install failed
            - Microsoft_VC80_CRT_x86: Install failed
            - AdobeCMaps x64 CS5: Install failed
            - AdobeTypeSupport x64 CS5: Install failed
            - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            - Microsoft_VC90_MFC_x86_x64: Install failed
            - DynamiclinkSupport: Install failed
            - Adobe WinSoft Linguistics Plugin CS5: Install failed
            - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            - AdobeColorEU CS5: Install failed
            - AdobePDFL CS5: Install failed
            - AdobeCMaps CS5: Install failed
            - AdobeColorNA CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            - Adobe SwitchBoard 2.0: Install failed
            - Adobe Flash CS5: Failed due to Language Pack installation failure
            - Microsoft_VC80_MFC_x86: Install failed
            - Pixel Bender Toolkit: Install failed
            - Microsoft_VC80_MFCLOC_x86: Install failed
            - Players For Adobe Flash Pro: Install failed
            - Adobe Extension Manager CS5: Install failed
            - AdobeJRE: Install failed
            - Adobe ExtendScript Toolkit CS5: Install failed
            - TLF For Adobe Flash Pro: Install failed
            - Adobe AIR: Install failed
            Restarting your computer is recommended:
            In order to complete the installation, please restart the computer
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 29004.3 miliseconds (29.0043 seconds) DTR = 1038.61 KBPS (1.01426 MBPS)
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 65 error(s), 65 warning(s)
            WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            WARNING: OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            WARNING: Payload cannot be installed due to dependent operation failure
            ERROR: The following payload errors were found during install:
            ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86: Install failed
            ERROR:  - Adobe Media Player: Install failed
            ERROR:  - SiteCatalyst NetAverages: Install failed
            ERROR:  - Adobe Linguistics CS5 x64: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86: Install failed
            ERROR:  - Adobe Bridge CS5: Install failed
            ERROR:  - Microsoft_VC80_ATL_x86: Install failed
            ERROR:  - AdobePDFL x64 CS5: Install failed
            ERROR:  - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            ERROR:  - Adobe XMP Panels CS5: Install failed
            ERROR:  - Adobe Player for Embedding: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            ERROR:  - Suite Shared Configuration CS5: Install failed
            ERROR:  - Photoshop Camera Raw: Install failed
            ERROR:  - AdobeColorCommonSetCMYK: Install failed
            ERROR:  - AdobeHelp: Install failed
            ERROR:  - Camera Profiles Installer: Install failed
            ERROR:  - Adobe Flash Player 10 Plugin: Install failed
            ERROR:  - AdobeColorJA CS5: Install failed
            ERROR:  - Adobe ReviewPanel CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            ERROR:  - Adobe BrowserLab CS Live: Install failed
            ERROR:  - Photoshop Camera Raw (64 bit): Install failed
            ERROR:  - iPhone Publishing: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86: Install failed
            ERROR:  - CSXS Story Extension: Install failed
            ERROR:  - Adobe Media Encoder CS5 X64: Install failed
            ERROR:  - Adobe Linguistics CS5: Install failed
            ERROR:  - PDF Settings CS5: Install failed
            ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
            ERROR:  - AdobeTypeSupport CS5: Install failed
            ERROR:  - AdobeColorCommonSetRGB: Install failed
            ERROR:  - Adobe Player for Embedding x64: Install failed
            ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
            ERROR:  - Adobe CSXS Extensions CS5: Install failed
            ERROR:  - AdobeOutputModule: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
            ERROR:  - Microsoft_VC80_CRT_x86: Install failed
            ERROR:  - AdobeCMaps x64 CS5: Install failed
            ERROR:  - AdobeTypeSupport x64 CS5: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
            ERROR:  - DynamiclinkSupport: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            ERROR:  - AdobeColorEU CS5: Install failed
            ERROR:  - AdobePDFL CS5: Install failed
            ERROR:  - AdobeCMaps CS5: Install failed
            ERROR:  - AdobeColorNA CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            ERROR:  - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            ERROR:  - Adobe SwitchBoard 2.0: Install failed
            ERROR:  - Adobe Flash CS5: Failed due to Language Pack installation failure
            ERROR:  - Microsoft_VC80_MFC_x86: Install failed
            ERROR:  - Pixel Bender Toolkit: Install failed
            ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
            ERROR:  - Players For Adobe Flash Pro: Install failed
            ERROR:  - Adobe Extension Manager CS5: Install failed
            ERROR:  - AdobeJRE: Install failed
            ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
            ERROR:  - TLF For Adobe Flash Pro: Install failed
            ERROR:  - Adobe AIR: Install failed
            Search the same string above to find when the error occured.
            Exit Code: 7 - Unable to complete Silent workflow
            END - Installer Session
            [    1196] Sun May 30 23:34:27 2010  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 3.0.121.0
            Win OS version: 6.0.0.0 64 bit Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            Create Required Folders
            Assuming install mode
            ::START TIMER:: [Bootstrap]
            Perform Bootstrapping ...
            :: END TIMER :: [Bootstrap] took 8886.88 miliseconds (8.88688 seconds) DTR = 288.515 KBPS (0.281753 MBPS)
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 6044.49 miliseconds (6.04449 seconds)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Adobe Flash Professional CS5
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
            Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
            Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
            Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
            Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll_x64\Install.db
            Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
            Updating media info for: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_CN\Install.db
            Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeBridge4-mul\Install.db
            Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
            Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-en_USLanguagePack\Install.db
            Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
            Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_US\Install.db
            Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_GB\Install.db
            Updating media info for: {1D855870-28A4-11DF-9731-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-de_DE\Install.db
            Updating media info for: {1D87C970-28A4-11DF-BC69-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_FR\Install.db
            Updating media info for: {1D87C971-28A4-11DF-A2FB-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_CA\Install.db
            Updating media info for: {1D87C972-28A4-11DF-B794-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ja_JP\Install.db
            Updating media info for: {1D8A135E-28A4-11DF-B54E-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-it_IT\Install.db
            Updating media info for: {1D8A135F-28A4-11DF-A7C5-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_ES\Install.db
            Updating media info for: {1D8A1360-28A4-11DF-B5B3-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_MX\Install.db
            Updating media info for: {1D8C8461-28A4-11DF-871D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nl_NL\Install.db
            Updating media info for: {1D8EF561-28A4-11DF-9561-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-sv_SE\Install.db
            Updating media info for: {1D8EF562-28A4-11DF-8D7D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fi_FI\Install.db
            Updating media info for: {1D8EF563-28A4-11DF-AF1B-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nb_NO\Install.db
            Updating media info for: {1D913F4F-28A4-11DF-AE84-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-da_DK\Install.db
            Updating media info for: {1D913F50-28A4-11DF-A78A-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pt_BR\Install.db
            Updating media info for: {1D913F51-28A4-11DF-91B7-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_CN\Install.db
            Updating media info for: {1D93B04F-28A4-11DF-AA22-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_TW\Install.db
            Updating media info for: {1D93B050-28A4-11DF-B472-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ko_KR\Install.db
            Updating media info for: {1D93B051-28A4-11DF-A202-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-cs_CZ\Install.db
            Updating media info for: {1D95FA40-28A4-11DF-90FF-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pl_PL\Install.db
            Updating media info for: {1D95FA41-28A4-11DF-85FA-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ru_RU\Install.db
            Updating media info for: {1D95FA42-28A4-11DF-9C38-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-tr_TR\Install.db
            Updating media info for: {1D986B40-28A4-11DF-BD12-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-uk_UA\Install.db
            Updating media info for: {1D986B41-28A4-11DF-BCC6-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-hu_HU\Install.db
            Updating media info for: {1DA90D10-28A4-11DF-937C-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ro_RO\Install.db
            Updating media info for: {1FD5C861-A5F4-4531-A444-149B65FC4DBC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-fr_FRLanguagePack\Install.db
            Updating media info for: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-sv_SELanguagePack\Install.db
            Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-en_US\Install.db
            Updating media info for: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-it_IT\Install.db
            Updating media info for: {2E18F0BB-569A-4788-A276-FAA40BB923F0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ja_JP\Install.db
            Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeXMPPanelsAll\Install.db
            Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3-mul\Install.db
            Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-mul\Install.db
            Updating media info for: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
            Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All\Install.db
            Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
            Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
            Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
            Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
            Updating media info for: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-nl_NL\Install.db
            Updating media info for: {44F29300-6E52-496A-9B77-531A68E8508A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_TW\Install.db
            Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
            Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeReviewPanel2-mul\Install.db
            Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-mul\Install.db
            Updating media info for: {58020FCB-DE00-491A-9414-3C0263C59EC9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-pt_BRLanguagePack\Install.db
            Updating media info for: {593B4750-2F16-4193-A3FA-40F49BD7A906}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ru_RU\Install.db
            Updating media info for: {597059F2-9EC9-46A5-9EA2-BDBDF354732B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ko_KR\Install.db
            Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\BrowserLabCSLive-mul\Install.db
            Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
            Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\iPhone_Flash11-mul\Install.db
            Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
            Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeStoryExtension-mul\Install.db
            Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All_x64\Install.db
            Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All\Install.db
            Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll\Install.db
            Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
            Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDeviceCentral3-all\Install.db
            Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
            Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10-mul\Install.db
            Updating media info for: {7036A0BD-E490-4ECD-8498-F96911539F99}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-nl_NLLanguagePack\Install.db
            Updating media info for: {73083037-24CD-4F25-AE12-100EBE3B198D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-fr_FR\Install.db
            Updating media info for: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_TW\Install.db
            Updating media info for: {76F9EEBC-B28D-475B-921E-84271789649C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-tr_TR\Install.db
            Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
            Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3_x64-mul\Install.db
            Updating media info for: {7B84FFBD-594D-4269-AC87-E19B44417B8F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-de_DE\Install.db
            Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
            Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
            Updating media info for: {880E072B-D613-4D7A-BD22-55AD5D22C2A9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_CN\Install.db
            Updating media info for: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pl_PL\Install.db
            Updating media info for: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-it_ITLanguagePack\Install.db
            Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
            Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeOutputModuleAll\Install.db
            Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
            Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-en_US\Install.db
            Updating media info for: {95648BD5-9496-4BB7-BE93-303FDB5B6B72}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pt_BR\Install.db
            Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3_x64-mul\Install.db
            Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
            Updating media info for: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-de_DELanguagePack\Install.db
            Updating media info for: {9D2819E4-C51E-4C89-8E28-673B9909A536}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-es_ES\Install.db
            Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
            Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
            Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
            Updating media info for: {B2518294-C06E-44F2-8B1E-1002DD41A6B3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-fr_FR\Install.db
            Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
            Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
            Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9-mul\Install.db
            Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3-mul\Install.db
            Updating media info for: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-sv_SE\Install.db
            Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
            Updating media info for: {C26277B5-5561-4C5C-85E9-D777E0386F6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ja_JP\Install.db
            Updating media info for: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-es_ES\Install.db
            Updating media info for: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pt_BR\Install.db
            Updating media info for: {C6EABDA0-8973-4824-B11A-20EF5B07F537}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-es_ESLanguagePack\Install.db
            Updating media info for: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-nl_NL\Install.db
            Updating media info for: {CC62B471-53FE-4451-8867-F3AA43F3FA31}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-cs_CZ\Install.db
            Updating media info for: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ko_KR\Install.db
            Updating media info for: {CE8FB687-571B-4E4B-881B-445824993FC3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-de_DE\Install.db
            Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SwitchBoard2.0All\Install.db
            Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-mul\Install.db
            Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
            Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
            Updating media info for: {D343E9D0-DD59-45CD-8939-896660D70435}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-tr_TR\Install.db
            Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\aifsdk-win\Install.db
            Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
            Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
            Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Players_Flash11-mul\Install.db
            Updating media info for: {E3354D9C-31B9-4391-8004-92B3FF074762}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ru_RU\Install.db
            Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtensionManager5.0All\Install.db
            Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
            Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeJRECS5-mul\Install.db
            Updating media info for: {E796AA2F-D55C-47D6-887F-24B90AC5151B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pl_PL\Install.db
            Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
            Updating media info for: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-cs_CZ\Install.db
            Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\TLF_Flash11-mul\Install.db
            Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
            Updating media info for: {F9E77304-0ACA-454A-AFD5-9B79CF94B184}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-it_IT\Install.db
            Updating media info for: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-sv_SE\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            Supported RIBS version range: [0.0.66.0,3.0.121.0]
            ----------------- CreatePayloadSession: machine is x64 ---------------
            ______ Verify Dependency Subscribers ______
            Setting property "INSTALLDIR" to: C:\Program Files\Adobe
            Setting property "installLanguage" to: es_ES
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Overwrite property "userASUPath" to: C:\Users\Aleix\AppData\Local\Adobe\OOBE\PDApp\
            Found payload actions:
            Deciding what installer mode to use...
            [    1196] Sun May 30 23:34:28 2010  INFO
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: false
            Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
            Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: false
            Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
            Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: false
            Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
            Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: false
            Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
            Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
            Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
            Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: false
            Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
            Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: false
            Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
            Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false
            Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
            Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false
            Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
            Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: false
            Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
            Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: false
            Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
            Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: false
            Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
            Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
            Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
            Value returned on lookup of payload: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 is: false
            Action string for  {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5  is none
            Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: false
            Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
            Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: false
            Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
            Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
            Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
            Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false
            Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
            Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
            Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
            Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false
            Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
            Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
            Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
            Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
            Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
            Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
            Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
            Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false
            Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
            Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
            Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
            Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
            Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
            Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: false
            Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
            Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: false
            Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
            Value returned on lookup of payload: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is: false
            Action string for  {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN  is none
            Payload {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is: false
            Action string for  {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW  is none
            Payload {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is: false
            Action string for  {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES  is none
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is: false
            Action string for  {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE  is none
            Payload {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is: false
            Action string for  {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR  is none
            Payload {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is: false
            Action string for  {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL  is none
            Payload {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is: false
            Action string for  {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ  is none
            Payload {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is: false
            Action string for  {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR  is none
            Payload {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is: false
            Action string for  {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP  is none
            Payload {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is: false
            Action string for  {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR  is none
            Payload {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is: false
            Action string for  {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE  is none
            Payload {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: false
            Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
            Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is: false
            Action string for  {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU  is none
            Payload {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is: false
            Action string for  {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR  is none
            Payload {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is: false
            Action string for  {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL  is none
            Payload {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is: false
            Action string for  {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT  is none
            Payload {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false
            Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
            Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: false
            Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
            Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: false
            Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
            Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
            Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
            Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false
            Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
            Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: false
            Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
            Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: false
            Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
            Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: false
            Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
            Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: false
            Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
            Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: false
            Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
            Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
            Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
            Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
            Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
            Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
            Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
            Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
            Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
            Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
            Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
            Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: false
            Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
            Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: false
            Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
            Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: false
            Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
            Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false
            Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
            Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
            Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
            Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: false
            Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
            Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: false
            Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
            Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: false
            Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
            Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: false
            Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
            Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: false
            Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
            Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false
            Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
            Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: false
            Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
            Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false
            Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
            Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
            Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
            Value returned on lookup of payload: {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is: false
            Action string for  {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA  is none
            Payload {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
            Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
            Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false
            Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
            Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is: false
            Action string for  {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE  is none
            Payload {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is: false
            Action string for  {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR  is none
            Payload {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is: false
            Action string for  {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA  is none
            Payload {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is: false
            Action string for  {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL  is none
            Payload {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is: false
            Action string for  {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR  is none
            Payload {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is: false
            Action string for  {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR  is none
            Payload {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is: false
            Action string for  {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO  is none
            Payload {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is: false
            Action string for  {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW  is none
            Payload {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is: false
            Action string for  {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP  is none
            Payload {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is: false
            Action string for  {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU  is none
            Payload {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is: false
            Action string for  {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN  is none
            Payload {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is: false
            Action string for  {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR  is none
            Payload {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is: false
            Action string for  {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK  is none
            Payload {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is: false
            Action string for  {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO  is none
            Payload {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is: false
            Action string for  {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU  is none
            Payload {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is: false
            Action string for  {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE  is none
            Payload {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is: false
            Action string for  {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL  is none
            Payload {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is: false
            Action string for  {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX  is none
            Payload {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is: false
            Action string for  {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES  is none
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is: false
            Action string for  {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT  is none
            Payload {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is: false
            Action string for  {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ  is none
            Payload {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is: false
            Action string for  {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI  is none
            Payload {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: false
            Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
            Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
            Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
            Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
            Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
            Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
            Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: false
            Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is install
            Value returned on lookup of payload: {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is: false
            Action string for  {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack  is none
            Payload {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is: false
            Action string for  {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL  is none
            Payload {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is: false
            Action string for  {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR  is none
            Payload {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is: false
            Action string for  {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR  is none
            Payload {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: false
            Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
            Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is: false
            Action string for  {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW  is none
            Payload {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is: false
            Action string for  {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack  is none
            Payload {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is: false
            Action string for  {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR  is none
            Payload {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is: false
            Action string for  {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack  is none
            Payload {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is: false
            Action string for  {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE  is none
            Payload {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: false
            Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is: false
            Action string for  {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN  is none
            Payload {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is: false
            Action string for  {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL  is none
            Payload {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is: false
            Action string for  {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack  is none
            Payload {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is: false
            Action string for  {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU  is none
            Payload {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is: false
            Action string for  {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP  is none
            Payload {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: false
            Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
            Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is: false
            Action string for  {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR  is none
            Payload {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is: false
            Action string for  {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack  is none
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is: false
            Action string for  {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack  is none
            Payload {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is: false
            Action string for  {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ  is none
            Payload {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is: false
            Action string for  {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack  is none
            Payload {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is: false
            Action string for  {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE  is none
            Payload {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is: false
            Action string for  {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT  is none
            Payload {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is: false
            Action string for  {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES  is none
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is extension payload. Aligning its action according to parent.
            END Setting requested payload actions
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
            [    1196] Sun May 30 23:34:28 2010  WARN
            OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
            In InstallPreSystemCheckProc
            [    1196] Sun May 30 23:34:29 2010  INFO
            Custom action return code: 0
            :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 11.6643 miliseconds (0.0116643 seconds)
            ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
            :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 12.0383 miliseconds (0.0120383 seconds)
            ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
            CustomHooksTester -> In InstallPreSystemCheckProc
            :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 12.2924 miliseconds (0.0122924 seconds)
            [    1196] Sun May 30 23:34:31 2010  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
            [    1568] Sun May 30 23:34:31 2010  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Installing payload
            Attempting to install package from:C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Command line arguments:
            Installation result: 1601
            Third party payload succeded.  Testing return code: 1601
            [    1196] Sun May 30 23:34:32 2010  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 1008.76 miliseconds (1.00876 seconds)
            User specified overrideFile:
            Calling the ROLLBACK custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
            [    1196] Sun May 30 23:34:32 2010  WARN
            Payload cannot be installed due to dependent operation failure
            Skipping payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 as payload is not cached
            Skipping payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 as payload is not cached
            Skipping payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 as payload is not cached
            Skipping payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding as payload is not cached
            Skipping payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 as payload is not cached
            Skipping payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 as payload is not cached
            Skipping payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE as payload is not cached
            Skipping payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer as payload is not cached
            Skipping payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport as payload is not cached
            Skipping payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 as payload is not cached
            Skipping payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 as payload is not cached
            Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
            Skipping payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 as payload is not cached
            Skipping payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 as payload is not cached
            Skipping payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 as payload is not cached
            Skipping payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp as payload is not cached
            Skipping payload {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 as payload is not cached
            Skipping payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 as payload is not cached
            Skipping payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule as payload is not cached
            Skipping payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 as payload is not cached
            Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
            Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
            Skipping payload {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 as payload is not cached
            Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
            Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
            Skipping payload {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit as payload is not cached
            Skipping payload {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro as payload is not cached
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} can not be installed due to dependent operation failure.
            Skipping payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES as payload is not cached
            Skipping payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR as payload is not cached
            Skipping payload {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live as payload is not cached
            Skipping payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX as payload is not cached
            Skipping payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin as payload is not cached
            Skipping payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player as payload is not cached
            Skipping payload {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 as payload is not cached
            Skipping payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 as payload is not cached
            Skipping payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 as payload is not cached
            Skipping payload {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 as payload is not cached
            Skipping payload {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 as payload is not cached
            Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
            Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
            [    1196] Sun May 30 23:34:33 2010  WARN
            [    1196] Sun May 30 23:34:33 2010  INFO
            Skipping payload {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 as payload is not cached
            Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
            Skipping payload {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 as payload is not cached
            Skipping payload {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 as payload is not cached
            Skipping payload {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 as payload is not cached
            Skipping payload {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension as payload is not cached
            Skipping payload {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 as payload is not cached
            Skipping payload {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) as payload is not cached
            Skipping payload {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro as payload is not cached
            Skipping payload {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages as payload is not cached
            Skipping payload {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro as payload is not cached
            Skipping payload {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing as payload is not cached
            Skipping payload {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 as payload is not cached
            Skipping payload {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 as payload is not cached
            Skipping payload {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 as payload is not cached
            Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} can not be installed due to dependent operation failure.
            Skipping payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES as payload is not cached
            Skipping payload {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 as payload is not cached
            Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
            Skipping payload {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 as payload is not cached
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} can not be installed due to dependent operation failure.
            Skipping payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul as payload is not cached
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} can not be installed due to dependent operation failure.
            Skipping payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES as payload is not cached
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} can not be installed due to dependent operation failure.
            Skipping payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
            [    1196] Sun May 30 23:34:35 2010  INFO
            Total components installed: 0
            Total components repaired: 0
            Total components removed: 0
            [    1196] Sun May 30 23:34:35 2010 ERROR
            The following payload errors were found during install:
            - Adobe CSXS Infrastructure CS5: Install failed
            - Microsoft_VC90_ATL_x86: Install failed
            - Adobe Media Player: Install failed
            - SiteCatalyst NetAverages: Install failed
            - Adobe Linguistics CS5 x64: Install failed
            - Microsoft_VC90_CRT_x86: Install failed
            - Adobe Bridge CS5: Install failed
            - Microsoft_VC80_ATL_x86: Install failed
            - AdobePDFL x64 CS5: Install failed
            - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            - Adobe XMP Panels CS5: Install failed
            - Adobe Player for Embedding: Install failed
            - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            - Suite Shared Configuration CS5: Install failed
            - Photoshop Camera Raw: Install failed
            - AdobeColorCommonSetCMYK: Install failed
            - AdobeHelp: Install failed
            - Camera Profiles Installer: Install failed
            - Adobe Flash Player 10 Plugin: Install failed
            - AdobeColorJA CS5: Install failed
            - Adobe ReviewPanel CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            - Adobe BrowserLab CS Live: Install failed
            - Photoshop Camera Raw (64 bit): Install failed
            - iPhone Publishing: Install failed
            - Microsoft_VC90_MFC_x86: Install failed
            - CSXS Story Extension: Install failed
            - Adobe Media Encoder CS5 X64: Install failed
            - Adobe Linguistics CS5: Install failed
            - PDF Settings CS5: Install failed
            - DeviceCentral: Failed due to Language Pack installation failure
            - AdobeTypeSupport CS5: Install failed
            - AdobeColorCommonSetRGB: Install failed
            - Adobe Player for Embedding x64: Install failed
            - Adobe Flash Player 10 ActiveX: Install failed
            - Microsoft_VC90_ATL_x86_x64: Install failed
            - Adobe CSXS Extensions CS5: Install failed
            - AdobeOutputModule: Install failed
            - Microsoft_VC90_CRT_x86_x64: Install failed
            - Microsoft_VC80_CRT_x86: Install failed
            - AdobeCMaps x64 CS5: Install failed
            - AdobeTypeSupport x64 CS5: Install failed
            - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            - Microsoft_VC90_MFC_x86_x64: Install failed
            - DynamiclinkSupport: Install failed
            - Adobe WinSoft Linguistics Plugin CS5: Install failed
            - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            - AdobeColorEU CS5: Install failed
            - AdobePDFL CS5: Install failed
            - AdobeCMaps CS5: Install failed
            - AdobeColorNA CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            - Adobe SwitchBoard 2.0: Install failed
            - Adobe Flash CS5: Failed due to Language Pack installation failure
            - Microsoft_VC80_MFC_x86: Install failed
            - Pixel Bender Toolkit: Install failed
            - Microsoft_VC80_MFCLOC_x86: Install failed
            - Players For Adobe Flash Pro: Install failed
            - Adobe Extension Manager CS5: Install failed
            - AdobeJRE: Install failed
            - Adobe ExtendScript Toolkit CS5: Install failed
            - TLF For Adobe Flash Pro: Install failed
            - Adobe AIR: Install failed
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 25151.6 miliseconds (25.1516 seconds) DTR = 107.031 KBPS (0.104522 MBPS)
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 65 error(s), 65 warning(s)
            WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            WARNING: OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            WARNING: Payload cannot be installed due to dependent operation failure
            ERROR: The following payload errors were found during install:
            ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86: Install failed
            ERROR:  - Adobe Media Player: Install failed
            ERROR:  - SiteCatalyst NetAverages: Install failed
            ERROR:  - Adobe Linguistics CS5 x64: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86: Install failed
            ERROR:  - Adobe Bridge CS5: Install failed
            ERROR:  - Microsoft_VC80_ATL_x86: Install failed
            ERROR:  - AdobePDFL x64 CS5: Install failed
            ERROR:  - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            ERROR:  - Adobe XMP Panels CS5: Install failed
            ERROR:  - Adobe Player for Embedding: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            ERROR:  - Suite Shared Configuration CS5: Install failed
            ERROR:  - Photoshop Camera Raw: Install failed
            ERROR:  - AdobeColorCommonSetCMYK: Install failed
            ERROR:  - AdobeHelp: Install failed
            ERROR:  - Camera Profiles Installer: Install failed
            ERROR:  - Adobe Flash Player 10 Plugin: Install failed
            ERROR:  - AdobeColorJA CS5: Install failed
            ERROR:  - Adobe ReviewPanel CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            ERROR:  - Adobe BrowserLab CS Live: Install failed
            ERROR:  - Photoshop Camera Raw (64 bit): Install failed
            ERROR:  - iPhone Publishing: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86: Install failed
            ERROR:  - CSXS Story Extension: Install failed
            ERROR:  - Adobe Media Encoder CS5 X64: Install failed
            ERROR:  - Adobe Linguistics CS5: Install failed
            ERROR:  - PDF Settings CS5: Install failed
            ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
            ERROR:  - AdobeTypeSupport CS5: Install failed
            ERROR:  - AdobeColorCommonSetRGB: Install failed
            ERROR:  - Adobe Player for Embedding x64: Install failed
            ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
            ERROR:  - Adobe CSXS Extensions CS5: Install failed
            ERROR:  - AdobeOutputModule: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
            ERROR:  - Microsoft_VC80_CRT_x86: Install failed
            ERROR:  - AdobeCMaps x64 CS5: Install failed
            ERROR:  - AdobeTypeSupport x64 CS5: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
            ERROR:  - DynamiclinkSupport: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            ERROR:  - AdobeColorEU CS5: Install failed
            ERROR:  - AdobePDFL CS5: Install failed
            ERROR:  - AdobeCMaps CS5: Install failed
            ERROR:  - AdobeColorNA CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            ERROR:  - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            ERROR:  - Adobe SwitchBoard 2.0: Install failed
            ERROR:  - Adobe Flash CS5: Failed due to Language Pack installation failure
            ERROR:  - Microsoft_VC80_MFC_x86: Install failed
            ERROR:  - Pixel Bender Toolkit: Install failed
            ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
            ERROR:  - Players For Adobe Flash Pro: Install failed
            ERROR:  - Adobe Extension Manager CS5: Install failed
            ERROR:  - AdobeJRE: Install failed
            ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
            ERROR:  - TLF For Adobe Flash Pro: Install failed
            ERROR:  - Adobe AIR: Install failed
            Search the same string above to find when the error occured.
            Exit Code: 7 - Unable to complete Silent workflow
            END - Installer Session
            [    1424] Sun May 30 23:40:37 2010  INFO
            Visit http://www.adobe.com/go/loganalyzer/ for more information
            START - Installer Session
            RIBS version: 3.0.121.0
            Win OS version: 6.0.0.0 64 bit Type: 1
            ::START TIMER:: [Total Timer]
            CHECK: Single instance running
            CHECK : Credentials
            Load Deployment File
            Create Required Folders
            Assuming install mode
            ::START TIMER:: [Bootstrap]
            Perform Bootstrapping ...
            :: END TIMER :: [Bootstrap] took 8645.82 miliseconds (8.64582 seconds) DTR = 26531.2 KBPS (25.9094 MBPS)
            Looking up install source path
            Sync Media DB ...
            ::START TIMER:: [Sync Media DB]
            Pre check media db sync
            End of Pre check media db sync. Exit code: 0
            :: END TIMER :: [Sync Media DB] took 5333.28 miliseconds (5.33328 seconds)
            Ready to initialize session to start with ...
            ::START TIMER:: [CreatePayloadSession]
            -------------------- BEGIN - Updating Media Sources - BEGIN --------------------
            Updated source path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Updating media info for: {02731921-5711-4E7A-A898-D6BCF0F2A1CD}
            Ignoring original data since install source is local
              Type: 0, Volume Order: 1, Media Name: Adobe Flash Professional CS5
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSInfrastructure2-mul\Install.db
            Updating media info for: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86\Microsoft_VC90_ATL_x86.msi
            Updating media info for: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAMP1.8-mul\AdobeAIRInstaller.exe
            Updating media info for: {03EEF3DA-71F9-4FE5-92AD-D10142E26459}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SiteCatalystNetAverages1-mul\Install.db
            Updating media info for: {0669F23C-1B69-41B4-A3ED-4F54A5986D66}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll_x64\Install.db
            Updating media info for: {08D2E121-7F6A-43EB-97FD-629B44903403}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86\Microsoft_VC90_CRT_x86.msi
            Updating media info for: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_CN\Install.db
            Updating media info for: {0D067D13-C3D7-4EA6-B346-740CD91FD547}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeBridge4-mul\Install.db
            Updating media info for: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_ATL_x86\Microsoft_VC80_ATL_x86.msi
            Updating media info for: {14A2CC02-4638-405D-8190-ECD7BFD32D6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-en_USLanguagePack\Install.db
            Updating media info for: {17C6080E-F475-4B49-A30C-EEB85673E999}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9_x64-mul\Install.db
            Updating media info for: {1D809D80-28A4-11DF-A816-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_US\Install.db
            Updating media info for: {1D830E80-28A4-11DF-A025-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-en_GB\Install.db
            Updating media info for: {1D855870-28A4-11DF-9731-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-de_DE\Install.db
            Updating media info for: {1D87C970-28A4-11DF-BC69-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_FR\Install.db
            Updating media info for: {1D87C971-28A4-11DF-A2FB-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fr_CA\Install.db
            Updating media info for: {1D87C972-28A4-11DF-B794-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ja_JP\Install.db
            Updating media info for: {1D8A135E-28A4-11DF-B54E-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-it_IT\Install.db
            Updating media info for: {1D8A135F-28A4-11DF-A7C5-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_ES\Install.db
            Updating media info for: {1D8A1360-28A4-11DF-B5B3-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-es_MX\Install.db
            Updating media info for: {1D8C8461-28A4-11DF-871D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nl_NL\Install.db
            Updating media info for: {1D8EF561-28A4-11DF-9561-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-sv_SE\Install.db
            Updating media info for: {1D8EF562-28A4-11DF-8D7D-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-fi_FI\Install.db
            Updating media info for: {1D8EF563-28A4-11DF-AF1B-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-nb_NO\Install.db
            Updating media info for: {1D913F4F-28A4-11DF-AE84-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-da_DK\Install.db
            Updating media info for: {1D913F50-28A4-11DF-A78A-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pt_BR\Install.db
            Updating media info for: {1D913F51-28A4-11DF-91B7-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_CN\Install.db
            Updating media info for: {1D93B04F-28A4-11DF-AA22-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-zh_TW\Install.db
            Updating media info for: {1D93B050-28A4-11DF-B472-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ko_KR\Install.db
            Updating media info for: {1D93B051-28A4-11DF-A202-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-cs_CZ\Install.db
            Updating media info for: {1D95FA40-28A4-11DF-90FF-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-pl_PL\Install.db
            Updating media info for: {1D95FA41-28A4-11DF-85FA-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ru_RU\Install.db
            Updating media info for: {1D95FA42-28A4-11DF-9C38-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-tr_TR\Install.db
            Updating media info for: {1D986B40-28A4-11DF-BD12-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-uk_UA\Install.db
            Updating media info for: {1D986B41-28A4-11DF-BCC6-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-hu_HU\Install.db
            Updating media info for: {1DA90D10-28A4-11DF-937C-0024E8692489}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\DeviceCentral3LP-ro_RO\Install.db
            Updating media info for: {1FD5C861-A5F4-4531-A444-149B65FC4DBC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-fr_FRLanguagePack\Install.db
            Updating media info for: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-sv_SELanguagePack\Install.db
            Updating media info for: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-en_US\Install.db
            Updating media info for: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-it_IT\Install.db
            Updating media info for: {2E18F0BB-569A-4788-A276-FAA40BB923F0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ja_JP\Install.db
            Updating media info for: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeXMPPanelsAll\Install.db
            Updating media info for: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3-mul\Install.db
            Updating media info for: {30221E3E-4C47-4560-A296-DD9ABB500C21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-mul\Install.db
            Updating media info for: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeSuiteSharedConfiguration-mul\Install.db
            Updating media info for: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All\Install.db
            Updating media info for: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetCMYK3-mul\Install.db
            Updating media info for: {3BF96AC2-0CA1-11DF-B07B-459956D89593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeHelp\AIRInstallerRunner.exe
            Updating media info for: {3F023875-4A52-4605-9DB6-A88D4A813E8D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRawProfile6.0All\Install.db
            Updating media info for: {40F95A03-885A-45fb-9A14-486BEFEDDF34}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_plRel_mul\AdobeFlashPlayer10_plRel_mul.msi
            Updating media info for: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-nl_NL\Install.db
            Updating media info for: {44F29300-6E52-496A-9B77-531A68E8508A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-zh_TW\Install.db
            Updating media info for: {54F4466A-091A-46DA-B697-43D55CEF9DF6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_ExtraSettings3-mul\Install.db
            Updating media info for: {56540320-C921-1029-83D9-FE864D1FC1DF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeReviewPanel2-mul\Install.db
            Updating media info for: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-mul\Install.db
            Updating media info for: {58020FCB-DE00-491A-9414-3C0263C59EC9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-pt_BRLanguagePack\Install.db
            Updating media info for: {593B4750-2F16-4193-A3FA-40F49BD7A906}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ru_RU\Install.db
            Updating media info for: {597059F2-9EC9-46A5-9EA2-BDBDF354732B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ko_KR\Install.db
            Updating media info for: {5E08533A-2C1B-469D-AFD5-953C9D00031F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\BrowserLabCSLive-mul\Install.db
            Updating media info for: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCameraRaw6.0All-x64\Install.db
            Updating media info for: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\iPhone_Flash11-mul\Install.db
            Updating media info for: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86\Microsoft_VC90_MFC_x86.msi
            Updating media info for: {66173EC7-974E-4652-9468-4A93D2481BF0}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeStoryExtension-mul\Install.db
            Updating media info for: {68CEA5C9-2964-4ECB-84A4-D77C511332BC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All_x64\Install.db
            Updating media info for: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AMECore5All\Install.db
            Updating media info for: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeLinguisticsAll\Install.db
            Updating media info for: {6D96660C-1444-410E-9A84-681C0AFB8937}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-mul\AdobePDFSettings10-mul.msi
            Updating media info for: {6E505C8F-2896-11DF-9B64-0013724DD917}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDeviceCentral3-all\Install.db
            Updating media info for: {6F29BE46-E5F3-4146-8A84-20301E5C985A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_ExtraSettings3-mul\Install.db
            Updating media info for: {6F3A624B-1B72-4081-96E8-23261F389C5C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10-mul\Install.db
            Updating media info for: {7036A0BD-E490-4ECD-8498-F96911539F99}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-nl_NLLanguagePack\Install.db
            Updating media info for: {73083037-24CD-4F25-AE12-100EBE3B198D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-fr_FR\Install.db
            Updating media info for: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_TW\Install.db
            Updating media info for: {76F9EEBC-B28D-475B-921E-84271789649C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-tr_TR\Install.db
            Updating media info for: {78A53622-CDBA-49D1-A3D0-D563FB398D0C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorCommonSetRGB3-mul\Install.db
            Updating media info for: {7A33510F-1580-42C2-877E-8C5502566292}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAPE3_x64-mul\Install.db
            Updating media info for: {7B84FFBD-594D-4269-AC87-E19B44417B8F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-de_DE\Install.db
            Updating media info for: {7E5AA19B-0B85-4f44-BA26-728851489200}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlashPlayer10_axRel_mul\AdobeFlashPlayer10_axRel_mul.msi
            Updating media info for: {8557397C-A42D-486F-97B3-A2CBC2372593}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_ATL_x86_x64\Microsoft_VC90_ATL_x86_x64.msi
            Updating media info for: {880E072B-D613-4D7A-BD22-55AD5D22C2A9}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-zh_CN\Install.db
            Updating media info for: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pl_PL\Install.db
            Updating media info for: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-it_ITLanguagePack\Install.db
            Updating media info for: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCSXSExtensions2-mul\Install.db
            Updating media info for: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeOutputModuleAll\Install.db
            Updating media info for: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_CRT_x86_x64\Microsoft_VC90_CRT_x86_x64.msi
            Updating media info for: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Updating media info for: {955EB78F-C938-4EA8-8470-C6EA71685834}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-en_US\Install.db
            Updating media info for: {95648BD5-9496-4BB7-BE93-303FDB5B6B72}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-pt_BR\Install.db
            Updating media info for: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3_x64-mul\Install.db
            Updating media info for: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeTypeSupport10_x64-mul\Install.db
            Updating media info for: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-de_DELanguagePack\Install.db
            Updating media info for: {9D2819E4-C51E-4C89-8E28-673B9909A536}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-es_ES\Install.db
            Updating media info for: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC90_MFC_x86_x64\Microsoft_VC90_MFC_x86_x64.msi
            Updating media info for: {A8798E04-96FF-4564-9157-0D4C89CB794C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeDynamiclinkSupport5All\Install.db
            Updating media info for: {AE9B837F-D135-42FC-BE03-33545B5DCBDC}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll\Install.db
            Updating media info for: {B2518294-C06E-44F2-8B1E-1002DD41A6B3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-fr_FR\Install.db
            Updating media info for: {B55FDCCB-8A45-4943-8D90-585C3490A032}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeWinSoftLinguisticsPluginAll_x64\Install.db
            Updating media info for: {B60B8713-F828-44F9-BEEE-7596F814E540}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorEU_Recommended3-mul\Install.db
            Updating media info for: {BAE5212B-6651-4AD8-B26A-1B284D2665C6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFL9.9-mul\Install.db
            Updating media info for: {BD0D6363-E961-410F-8BF4-ECD8795F3923}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeCMaps3-mul\Install.db
            Updating media info for: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-sv_SE\Install.db
            Updating media info for: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_ExtraSettings3-mul\Install.db
            Updating media info for: {C26277B5-5561-4C5C-85E9-D777E0386F6E}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-ja_JP\Install.db
            Updating media info for: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-es_ES\Install.db
            Updating media info for: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pt_BR\Install.db
            Updating media info for: {C6EABDA0-8973-4824-B11A-20EF5B07F537}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-es_ESLanguagePack\Install.db
            Updating media info for: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-nl_NL\Install.db
            Updating media info for: {CC62B471-53FE-4451-8867-F3AA43F3FA31}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-cs_CZ\Install.db
            Updating media info for: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ko_KR\Install.db
            Updating media info for: {CE8FB687-571B-4E4B-881B-445824993FC3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-de_DE\Install.db
            Updating media info for: {CFA46C39-C539-4BE9-9364-495003C714AD}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\SwitchBoard2.0All\Install.db
            Updating media info for: {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeFlash11-mul\Install.db
            Updating media info for: {D1A19B02-817E-4296-A45B-07853FD74D57}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFC_x86\Microsoft_VC80_MFC_x86.msi
            Updating media info for: {D26EEF95-420A-4726-B85D-AFBE752EF526}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorNA_Recommended3-mul\Install.db
            Updating media info for: {D343E9D0-DD59-45CD-8939-896660D70435}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-tr_TR\Install.db
            Updating media info for: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\aifsdk-win\Install.db
            Updating media info for: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_MFCLOC_x86\Microsoft_VC80_MFCLOC_x86.msi
            Updating media info for: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobePDFSettings10-ja_JP\AdobePDFSettings10-ja_JP.msi
            Updating media info for: {E319B9F9-4DE6-462C-970B-77D06C7807EE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Players_Flash11-mul\Install.db
            Updating media info for: {E3354D9C-31B9-4391-8004-92B3FF074762}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-ru_RU\Install.db
            Updating media info for: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtensionManager5.0All\Install.db
            Updating media info for: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeColorJA_Recommended3-mul\Install.db
            Updating media info for: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeJRECS5-mul\Install.db
            Updating media info for: {E796AA2F-D55C-47D6-887F-24B90AC5151B}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-pl_PL\Install.db
            Updating media info for: {E995AC53-954A-48D2-A861-613B8D42A9BE}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeExtendScriptToolkit3.5.0-mul\Install.db
            Updating media info for: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeMobileExtension_Flash11-cs_CZ\Install.db
            Updating media info for: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\TLF_Flash11-mul\Install.db
            Updating media info for: {F6FA54C9-3E8F-4416-905C-DA5398DF9640}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AdobeAIR1.5.3-mul\AdobeAIRInstaller.exe
            Updating media info for: {F9E77304-0ACA-454A-AFD5-9B79CF94B184}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-it_IT\Install.db
            Updating media info for: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6}
              Path: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\AIR2_Flash11-sv_SE\Install.db
            --------------------  END  - Updating Media Sources -  END  --------------------
            [    1424] Sun May 30 23:40:38 2010  INFO
            Supported RIBS version range: [0.0.66.0,3.0.121.0]
            ----------------- CreatePayloadSession: machine is x64 ---------------
            ______ Verify Dependency Subscribers ______
            Setting property "INSTALLDIR" to: C:\Program Files\Adobe
            Setting property "installLanguage" to: es_ES
            Attempting to find the selected language in the set of available payload languages
            Setting property "installSourcePath" to: C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5
            Overwrite property "userASUPath" to: C:\Users\Aleix\AppData\Local\Adobe\OOBE\PDApp\
            Found payload actions:
            Deciding what installer mode to use...
            BEGIN Setting requested payload actions
            Value returned on lookup of payload: {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86 is: false
            Action string for  {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86  is none
            Value returned on lookup of payload: {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 is: false
            Action string for  {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86  is none
            Value returned on lookup of payload: {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 is: false
            Action string for  {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86  is none
            Value returned on lookup of payload: {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 is: false
            Action string for  {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86  is none
            Value returned on lookup of payload: {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding is: false
            Action string for  {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding  is none
            Value returned on lookup of payload: {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 is: false
            Action string for  {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86  is none
            Value returned on lookup of payload: {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 is: false
            Action string for  {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86  is none
            Value returned on lookup of payload: {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE is: false
            Action string for  {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE  is none
            Value returned on lookup of payload: {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer is: false
            Action string for  {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer  is none
            Value returned on lookup of payload: {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport is: false
            Action string for  {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport  is none
            Value returned on lookup of payload: {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 is: false
            Action string for  {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86  is none
            Value returned on lookup of payload: {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 is: false
            Action string for  {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64  is none
            Value returned on lookup of payload: {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 is: false
            Action string for  {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5  is none
            Value returned on lookup of payload: {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 is: false
            Action string for  {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5  is none
            Value returned on lookup of payload: {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 is: false
            Action string for  {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64  is none
            Value returned on lookup of payload: {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 is: false
            Action string for  {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64  is none
            Value returned on lookup of payload: {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp is: false
            Action string for  {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp  is none
            Value returned on lookup of payload: {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 is: false
            Action string for  {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5  is none
            Value returned on lookup of payload: {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 is: false
            Action string for  {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5  is none
            Value returned on lookup of payload: {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule is: false
            Action string for  {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule  is none
            Value returned on lookup of payload: {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 is: false
            Action string for  {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5  is none
            Value returned on lookup of payload: {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 is: false
            Action string for  {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5  is none
            Value returned on lookup of payload: {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw is: false
            Action string for  {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw  is none
            Value returned on lookup of payload: {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 is: false
            Action string for  {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5  is none
            Value returned on lookup of payload: {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 is: false
            Action string for  {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5  is none
            Value returned on lookup of payload: {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 is: false
            Action string for  {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5  is none
            Value returned on lookup of payload: {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit is: false
            Action string for  {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit  is none
            Value returned on lookup of payload: {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro is: false
            Action string for  {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro  is none
            Value returned on lookup of payload: {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is: false
            Action string for  {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN  is none
            Payload {0A7D8837-ABAD-4C29-8F2F-1916B7A07AE2} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is: false
            Action string for  {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW  is none
            Payload {44F29300-6E52-496A-9B77-531A68E8508A} AIR2 For Adobe Flash Pro_AIR2_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is: false
            Action string for  {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES  is none
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is: false
            Action string for  {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE  is none
            Payload {FBF38B3A-1D5D-4CD6-930F-C5B8097011F6} AIR2 For Adobe Flash Pro_AIR2_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is: false
            Action string for  {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR  is none
            Payload {C533676C-7A2F-4BCC-BA04-439C93C6DC0F} AIR2 For Adobe Flash Pro_AIR2_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is: false
            Action string for  {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL  is none
            Payload {4423F304-2C6B-49FB-AB2C-6C7649A5ED21} AIR2 For Adobe Flash Pro_AIR2_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is: false
            Action string for  {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ  is none
            Payload {CC62B471-53FE-4451-8867-F3AA43F3FA31} AIR2 For Adobe Flash Pro_AIR2_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is: false
            Action string for  {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR  is none
            Payload {597059F2-9EC9-46A5-9EA2-BDBDF354732B} AIR2 For Adobe Flash Pro_AIR2_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is: false
            Action string for  {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP  is none
            Payload {C26277B5-5561-4C5C-85E9-D777E0386F6E} AIR2 For Adobe Flash Pro_AIR2_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is: false
            Action string for  {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR  is none
            Payload {73083037-24CD-4F25-AE12-100EBE3B198D} AIR2 For Adobe Flash Pro_AIR2_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is: false
            Action string for  {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE  is none
            Payload {CE8FB687-571B-4E4B-881B-445824993FC3} AIR2 For Adobe Flash Pro_AIR2_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is: false
            Action string for  {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US  is none
            Payload {955EB78F-C938-4EA8-8470-C6EA71685834} AIR2 For Adobe Flash Pro_AIR2_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is: false
            Action string for  {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU  is none
            Payload {593B4750-2F16-4193-A3FA-40F49BD7A906} AIR2 For Adobe Flash Pro_AIR2_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is: false
            Action string for  {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR  is none
            Payload {D343E9D0-DD59-45CD-8939-896660D70435} AIR2 For Adobe Flash Pro_AIR2_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is: false
            Action string for  {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL  is none
            Payload {E796AA2F-D55C-47D6-887F-24B90AC5151B} AIR2 For Adobe Flash Pro_AIR2_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is: false
            Action string for  {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT  is none
            Payload {F9E77304-0ACA-454A-AFD5-9B79CF94B184} AIR2 For Adobe Flash Pro_AIR2_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR is: false
            Action string for  {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR  is none
            Value returned on lookup of payload: {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live is: false
            Action string for  {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live  is none
            Value returned on lookup of payload: {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX is: false
            Action string for  {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX  is none
            Value returned on lookup of payload: {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin is: false
            Action string for  {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin  is none
            Value returned on lookup of payload: {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player is: false
            Action string for  {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player  is none
            Value returned on lookup of payload: {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 is: false
            Action string for  {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64  is none
            Value returned on lookup of payload: {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 is: false
            Action string for  {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5  is none
            Value returned on lookup of payload: {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 is: false
            Action string for  {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5  is none
            Value returned on lookup of payload: {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 is: false
            Action string for  {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64  is none
            Value returned on lookup of payload: {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 is: false
            Action string for  {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5  is none
            Value returned on lookup of payload: {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK is: false
            Action string for  {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK  is none
            Value returned on lookup of payload: {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB is: false
            Action string for  {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB  is none
            Value returned on lookup of payload: {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5 is: false
            Action string for  {6F29BE46-E5F3-4146-8A84-20301E5C985A} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 is: false
            Action string for  {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5  is none
            Value returned on lookup of payload: {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 is: false
            Action string for  {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5 is: false
            Action string for  {E5087BCA-6496-47A7-B9C4-B85D1CF062AE} AdobeColorJA CS5  is none
            Value returned on lookup of payload: {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 is: false
            Action string for  {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5 is: false
            Action string for  {D26EEF95-420A-4726-B85D-AFBE752EF526} AdobeColorNA CS5  is none
            Value returned on lookup of payload: {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 is: false
            Action string for  {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5  is none
            Value returned on lookup of payload: {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 is: false
            Action string for  {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5  is none
            Value returned on lookup of payload: {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension is: false
            Action string for  {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension  is none
            Value returned on lookup of payload: {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 is: false
            Action string for  {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5  is none
            Value returned on lookup of payload: {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5 is: false
            Action string for  {DE99CD25-C87E-499F-AFB8-88D00F0BAEB3} PDF Settings CS5  is none
            Value returned on lookup of payload: {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) is: false
            Action string for  {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit)  is none
            Value returned on lookup of payload: {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro is: false
            Action string for  {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro  is none
            Value returned on lookup of payload: {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages is: false
            Action string for  {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages  is none
            Value returned on lookup of payload: {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro is: false
            Action string for  {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro  is none
            Value returned on lookup of payload: {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing is: false
            Action string for  {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing  is none
            Value returned on lookup of payload: {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 is: false
            Action string for  {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5  is none
            Value returned on lookup of payload: {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 is: false
            Action string for  {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64  is none
            Value returned on lookup of payload: {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 is: false
            Action string for  {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0  is none
            Value returned on lookup of payload: {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral is: false
            Action string for  {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral  is none
            Value returned on lookup of payload: {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is: false
            Action string for  {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA  is none
            Payload {1D986B40-28A4-11DF-BD12-0024E8692489} DeviceCentral_DeviceCentral3LP-uk_UA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is: false
            Action string for  {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US  is none
            Payload {1D809D80-28A4-11DF-A816-0024E8692489} DeviceCentral_DeviceCentral3LP-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is: false
            Action string for  {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB  is none
            Payload {1D830E80-28A4-11DF-A025-0024E8692489} DeviceCentral_DeviceCentral3LP-en_GB is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is: false
            Action string for  {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE  is none
            Payload {1D855870-28A4-11DF-9731-0024E8692489} DeviceCentral_DeviceCentral3LP-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is: false
            Action string for  {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR  is none
            Payload {1D87C970-28A4-11DF-BC69-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is: false
            Action string for  {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA  is none
            Payload {1D87C971-28A4-11DF-A2FB-0024E8692489} DeviceCentral_DeviceCentral3LP-fr_CA is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is: false
            Action string for  {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL  is none
            Payload {1D95FA40-28A4-11DF-90FF-0024E8692489} DeviceCentral_DeviceCentral3LP-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is: false
            Action string for  {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR  is none
            Payload {1D93B050-28A4-11DF-B472-0024E8692489} DeviceCentral_DeviceCentral3LP-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is: false
            Action string for  {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR  is none
            Payload {1D95FA42-28A4-11DF-9C38-0024E8692489} DeviceCentral_DeviceCentral3LP-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is: false
            Action string for  {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO  is none
            Payload {1DA90D10-28A4-11DF-937C-0024E8692489} DeviceCentral_DeviceCentral3LP-ro_RO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is: false
            Action string for  {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW  is none
            Payload {1D93B04F-28A4-11DF-AA22-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is: false
            Action string for  {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP  is none
            Payload {1D87C972-28A4-11DF-B794-0024E8692489} DeviceCentral_DeviceCentral3LP-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is: false
            Action string for  {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU  is none
            Payload {1D95FA41-28A4-11DF-85FA-0024E8692489} DeviceCentral_DeviceCentral3LP-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is: false
            Action string for  {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN  is none
            Payload {1D913F51-28A4-11DF-91B7-0024E8692489} DeviceCentral_DeviceCentral3LP-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is: false
            Action string for  {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR  is none
            Payload {1D913F50-28A4-11DF-A78A-0024E8692489} DeviceCentral_DeviceCentral3LP-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is: false
            Action string for  {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK  is none
            Payload {1D913F4F-28A4-11DF-AE84-0024E8692489} DeviceCentral_DeviceCentral3LP-da_DK is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is: false
            Action string for  {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO  is none
            Payload {1D8EF563-28A4-11DF-AF1B-0024E8692489} DeviceCentral_DeviceCentral3LP-nb_NO is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is: false
            Action string for  {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU  is none
            Payload {1D986B41-28A4-11DF-BCC6-0024E8692489} DeviceCentral_DeviceCentral3LP-hu_HU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is: false
            Action string for  {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE  is none
            Payload {1D8EF561-28A4-11DF-9561-0024E8692489} DeviceCentral_DeviceCentral3LP-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is: false
            Action string for  {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL  is none
            Payload {1D8C8461-28A4-11DF-871D-0024E8692489} DeviceCentral_DeviceCentral3LP-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is: false
            Action string for  {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX  is none
            Payload {1D8A1360-28A4-11DF-B5B3-0024E8692489} DeviceCentral_DeviceCentral3LP-es_MX is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is: false
            Action string for  {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES  is none
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is: false
            Action string for  {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT  is none
            Payload {1D8A135E-28A4-11DF-B54E-0024E8692489} DeviceCentral_DeviceCentral3LP-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is: false
            Action string for  {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ  is none
            Payload {1D93B051-28A4-11DF-A202-0024E8692489} DeviceCentral_DeviceCentral3LP-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is: false
            Action string for  {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI  is none
            Payload {1D8EF562-28A4-11DF-8D7D-0024E8692489} DeviceCentral_DeviceCentral3LP-fi_FI is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 is: false
            Action string for  {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64  is none
            Value returned on lookup of payload: {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is: false
            Action string for  {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5  is donotinstall
            Selection of payload {694213D7-1E0E-4C8F-B822-E2E3680C0FCE} Adobe Media Encoder CS5 is allowed but the user has marked it for not to install
            Value returned on lookup of payload: {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 is: false
            Action string for  {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5  is none
            Value returned on lookup of payload: {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 is: false
            Action string for  {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5  is install
            Value returned on lookup of payload: {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is: false
            Action string for  {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack  is none
            Payload {7036A0BD-E490-4ECD-8498-F96911539F99} Adobe Flash CS5_AdobeFlash11-nl_NLLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is: false
            Action string for  {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL  is none
            Payload {C9A98E0C-B50E-472A-ADCC-2830F48EF91D} Adobe Flash CS5_AdobeMobileExtension_Flash11-nl_NL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is: false
            Action string for  {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR  is none
            Payload {B2518294-C06E-44F2-8B1E-1002DD41A6B3} Adobe Flash CS5_AdobeMobileExtension_Flash11-fr_FR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is: false
            Action string for  {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR  is none
            Payload {CE0BF4F8-F592-4461-91AE-7C15AF19CFDF} Adobe Flash CS5_AdobeMobileExtension_Flash11-ko_KR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is: false
            Action string for  {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack  is none
            Payload {14A2CC02-4638-405D-8190-ECD7BFD32D6E} Adobe Flash CS5_AdobeFlash11-en_USLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is: false
            Action string for  {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW  is none
            Payload {76BF7895-72EB-4DFC-8FF9-2007A8228D9C} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_TW is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is: false
            Action string for  {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack  is none
            Payload {9CEA4BD7-A3A9-40CA-BB68-74CE3C75FA25} Adobe Flash CS5_AdobeFlash11-de_DELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is: false
            Action string for  {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR  is none
            Payload {76F9EEBC-B28D-475B-921E-84271789649C} Adobe Flash CS5_AdobeMobileExtension_Flash11-tr_TR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is: false
            Action string for  {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack  is none
            Payload {58020FCB-DE00-491A-9414-3C0263C59EC9} Adobe Flash CS5_AdobeFlash11-pt_BRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is: false
            Action string for  {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE  is none
            Payload {7B84FFBD-594D-4269-AC87-E19B44417B8F} Adobe Flash CS5_AdobeMobileExtension_Flash11-de_DE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is: false
            Action string for  {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul  is none
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is: false
            Action string for  {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN  is none
            Payload {880E072B-D613-4D7A-BD22-55AD5D22C2A9} Adobe Flash CS5_AdobeMobileExtension_Flash11-zh_CN is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is: false
            Action string for  {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL  is none
            Payload {8B28A565-4AAD-4803-8EE8-F1791E6AD4AC} Adobe Flash CS5_AdobeMobileExtension_Flash11-pl_PL is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is: false
            Action string for  {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack  is none
            Payload {8B33D66D-8839-4EFF-AB7E-8BFD397BA0E6} Adobe Flash CS5_AdobeFlash11-it_ITLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is: false
            Action string for  {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU  is none
            Payload {E3354D9C-31B9-4391-8004-92B3FF074762} Adobe Flash CS5_AdobeMobileExtension_Flash11-ru_RU is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is: false
            Action string for  {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP  is none
            Payload {2E18F0BB-569A-4788-A276-FAA40BB923F0} Adobe Flash CS5_AdobeMobileExtension_Flash11-ja_JP is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is: false
            Action string for  {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US  is none
            Payload {26B0DF8D-3A8D-4BA9-B131-3B0D9EE87655} Adobe Flash CS5_AdobeMobileExtension_Flash11-en_US is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is: false
            Action string for  {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR  is none
            Payload {95648BD5-9496-4BB7-BE93-303FDB5B6B72} Adobe Flash CS5_AdobeMobileExtension_Flash11-pt_BR is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is: false
            Action string for  {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack  is none
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is: false
            Action string for  {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack  is none
            Payload {20BFDB53-46EC-4008-ABA4-4DD8A4F9BA68} Adobe Flash CS5_AdobeFlash11-sv_SELanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is: false
            Action string for  {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ  is none
            Payload {ECB4C6D6-54BF-40FD-96ED-80F36CFE11EA} Adobe Flash CS5_AdobeMobileExtension_Flash11-cs_CZ is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is: false
            Action string for  {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack  is none
            Payload {1FD5C861-A5F4-4531-A444-149B65FC4DBC} Adobe Flash CS5_AdobeFlash11-fr_FRLanguagePack is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is: false
            Action string for  {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE  is none
            Payload {BD4CFD2A-02C1-4FBE-AF9E-863A9981421A} Adobe Flash CS5_AdobeMobileExtension_Flash11-sv_SE is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is: false
            Action string for  {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT  is none
            Payload {2CDBD42B-6184-41BD-9662-A13C3BA09BFA} Adobe Flash CS5_AdobeMobileExtension_Flash11-it_IT is extension payload. Aligning its action according to parent.
            Value returned on lookup of payload: {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is: false
            Action string for  {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES  is none
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES is extension payload. Aligning its action according to parent.
            END Setting requested payload actions
            [    1424] Sun May 30 23:40:39 2010  INFO
            Collected advanced path check information for INSTALLDIR
            INSTALLDIR is a well-formed path
            INSTALLDIR is not the root path
            INSTALLDIR is on a local volume
            INSTALLDIR is on a writable volume
            INSTALLDIR is not on a case sensitive volume
            INSTALLDIR passed path basic path validation: C:\Program Files (x86)\Adobe
            [    1424] Sun May 30 23:40:40 2010  WARN
            OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            [    1424] Sun May 30 23:40:40 2010  INFO
            ::START TIMER:: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}]
            In InstallPreSystemCheckProc
            Custom action return code: 0
            :: END TIMER :: [System check :{02731921-5711-4E7A-A898-D6BCF0F2A1CD}] took 12.5636 miliseconds (0.0125636 seconds)
            ::START TIMER:: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}]
            :: END TIMER :: [System check :{8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F}] took 11.6592 miliseconds (0.0116592 seconds)
            ::START TIMER:: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}]
            CustomHooksTester -> In InstallPreSystemCheckProc
            :: END TIMER :: [System check :{0D067D13-C3D7-4EA6-B346-740CD91FD547}] took 13.0827 miliseconds (0.0130827 seconds)
            [    1424] Sun May 30 23:40:44 2010  INFO
            Payloads passed preflight validation.
            Call PreSession Custom Hook
            Calling the custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            ::START TIMER:: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}]
            [    4764] Sun May 30 23:40:44 2010  INFO
            Installer Operation: InstallThirdPartyPayloadOperation
            Installing third party payload
            Installing payload
            Attempting to install package from:C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Command line arguments:
            1: 0 2: 1033 3: 1252
            === Logging started: 30/05/2010  23:40:44 ===
            Message type: 0, Argument: 1033
            Message type: 1, Argument: Microsoft_VC80_CRT_x86
            Action 23:40:44: INSTALL.
            Action start 23:40:44: INSTALL.
            Action 23:40:44: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action start 23:40:44: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action ended 23:40:44: WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
            Action 23:40:44: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action start 23:40:44: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E.
            Action ended 23:40:44: SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E. Return value 1.
            Action 23:40:44: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action start 23:40:44: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action ended 23:40:44: WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
            Action 23:40:44: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action start 23:40:44: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E.
            Action ended 23:40:44: SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E. Return value 1.
            Action 23:40:44: AppSearch. Searching for installed applications
            Action start 23:40:44: AppSearch.
            Action ended 23:40:44: AppSearch. Return value 0.
            Action 23:40:44: LaunchConditions. Evaluating launch conditions
            Action start 23:40:44: LaunchConditions.
            Action ended 23:40:44: LaunchConditions. Return value 0.
            Action 23:40:44: FindRelatedProducts. Searching for related applications
            Action start 23:40:44: FindRelatedProducts.
            Action ended 23:40:44: FindRelatedProducts. Return value 0.
            Action 23:40:44: ValidateProductID.
            Action start 23:40:44: ValidateProductID.
            Action ended 23:40:44: ValidateProductID. Return value 1.
            Action 23:40:44: CostInitialize. Computing space requirements
            Action start 23:40:44: CostInitialize.
            Action ended 23:40:44: CostInitialize. Return value 1.
            Action 23:40:44: FileCost. Computing space requirements
            Action start 23:40:44: FileCost.
            Action ended 23:40:44: FileCost. Return value 1.
            Action 23:40:44: IsolateComponents.
            Action start 23:40:44: IsolateComponents.
            Action ended 23:40:44: IsolateComponents. Return value 0.
            Action 23:40:44: CostFinalize. Computing space requirements
            Action start 23:40:44: CostFinalize.
            Action ended 23:40:44: CostFinalize. Return value 1.
            Action 23:40:44: SetARPINSTALLLOCATION.
            Action start 23:40:44: SetARPINSTALLLOCATION.
            Action ended 23:40:44: SetARPINSTALLLOCATION. Return value 1.
            Action 23:40:44: SetODBCFolders. Initializing ODBC directories
            Action start 23:40:44: SetODBCFolders.
            Action ended 23:40:44: SetODBCFolders. Return value 0.
            Action 23:40:44: MigrateFeatureStates. Migrating feature states from related applications
            Action start 23:40:44: MigrateFeatureStates.
            Action ended 23:40:44: MigrateFeatureStates. Return value 0.
            Action 23:40:44: InstallValidate. Validating install
            Action start 23:40:44: InstallValidate.
            Action ended 23:40:44: InstallValidate. Return value 1.
            Action 23:40:44: RemoveExistingProducts. Removing applications
            Action start 23:40:44: RemoveExistingProducts.
            Action ended 23:40:44: RemoveExistingProducts. Return value 0.
            Action 23:40:44: InstallInitialize.
            Action start 23:40:44: InstallInitialize.
            [    4764] Sun May 30 23:40:46 2010  INFO
            Action ended 23:40:46: InstallInitialize. Return value 1.
            Action 23:40:46: SxsInstallCA.
            Action start 23:40:46: SxsInstallCA.
            1: sxsdelca 2: traceop 3: 1256 4: 0
            1: sxsdelca 2: traceop 3: 1257 4: 0
            1: sxsdelca 2: traceop 3: 1258 4: 0
            1: sxsdelca 2: traceop 3: 1284 4: 0
            1: sxsdelca 2: traceop 3: 1288 4: 0
            1: sxsdelca 2: traceop 3: 1289 4: 0
            1: sxsdelca 2: traceop 3: 1290 4: 0
            1: sxsdelca 2: traceop 3: 1292 4: 0
            1: sxsdelca 2: traceop 3: 1318 4: 0
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca 2: traceop 3: 1306 4: 0
            1: sxsdelca 2: traceop 3: 1307 4: 0
            1: sxsdelca 2: traceop 3: 796 4: 0
            1: sxsdelca 2: traceop 3: 801 4: 0
            1: sxsdelca 2: traceop 3: 802 4: 0
            1: sxsdelca 2: traceop 3: 803 4: 0
            1: sxsdelca 2: traceop 3: 805 4: 0
            1: sxsdelca 2: traceop 3: 812 4: 0
            1: sxsdelca 2: traceop 3: 813 4: 0
            1: sxsdelca 2: traceop 3: 814 4: 0
            1: sxsdelca 2: traceop 3: 819 4: 0
            1: sxsdelca 2: traceop 3: 820 4: 0
            1: sxsdelca 2: traceop 3: 821 4: 0
            1: sxsdelca 2: traceop 3: 827 4: 0
            1: sxsdelca 2: traceop 3: 831 4: 0
            1: sxsdelca 2: traceop 3: 827 4: 259
            1: sxsdelca 2: traceop 3: 1311 4: 0
            1: sxsdelca 2: traceop 3: 1312 4: 0
            1: sxsdelca 2: traceop 3: 1077 4: 0
            1: sxsdelca 2: traceop 3: 1081 4: 0
            1: sxsdelca 2: traceop 3: 1083 4: 0
            1: sxsdelca 2: traceop 3: 1087 4: 0
            1: sxsdelca 2: traceop 3: 1093 4: 0
            1: sxsdelca 2: traceop 3: 1097 4: 0
            1: sxsdelca 2: traceop 3: 1101 4: 0
            1: sxsdelca 2: traceop 3: 1105 4: 0
            1: sxsdelca 2: traceop 3: 1109 4: 0
            1: sxsdelca 2: traceop 3: 1113 4: 0
            1: sxsdelca 2: traceop 3: 1117 4: 0
            1: sxsdelca 2: traceop 3: 1121 4: 0
            1: sxsdelca 2: traceop 3: 1313 4: 0
            1: sxsdelca 2: traceop 3: 1314 4: 0
            1: sxsdelca: Added reg value for  2: uplevel.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E
            1: sxsdelca: Added reg value for  2: uplevel.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca: Skipping component  2: downlevel_manifest.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E
            1: sxsdelca 2: traceop 3: 1284 4: 259
            1: sxsdelca 2: SxsMsmInstall completed 3: 0 4: 0
            Action ended 23:40:46: SxsInstallCA. Return value 1.
            Action 23:40:46: AllocateRegistrySpace. Allocating registry space
            Action start 23:40:46: AllocateRegistrySpace.
            Action ended 23:40:46: AllocateRegistrySpace. Return value 1.
            Action 23:40:46: ProcessComponents. Updating component registration
            Action start 23:40:46: ProcessComponents.
            Action 23:40:46: GenerateScript. Generating script operations for action:
            Action ended 23:40:46: ProcessComponents. Return value 1.
            Action 23:40:46: UnpublishComponents. Unpublishing Qualified Components
            Action start 23:40:46: UnpublishComponents.
            Action ended 23:40:46: UnpublishComponents. Return value 0.
            Action 23:40:46: MsiUnpublishAssemblies. Unpublishing assembly information
            Action start 23:40:46: MsiUnpublishAssemblies.
            Action ended 23:40:46: MsiUnpublishAssemblies. Return value 1.
            Action 23:40:46: UnpublishFeatures. Unpublishing product features
            Action start 23:40:46: UnpublishFeatures.
            Action ended 23:40:46: UnpublishFeatures. Return value 1.
            Action 23:40:46: StopServices. Stopping services
            Action start 23:40:46: StopServices.
            Action ended 23:40:46: StopServices. Return value 1.
            Action 23:40:46: DeleteServices. Deleting services
            Action start 23:40:46: DeleteServices.
            Action ended 23:40:46: DeleteServices. Return value 1.
            Action 23:40:46: UnregisterComPlus. Unregistering COM+ Applications and Components
            Action start 23:40:46: UnregisterComPlus.
            Action ended 23:40:46: UnregisterComPlus. Return value 0.
            Action 23:40:46: SelfUnregModules. Unregistering modules
            Action start 23:40:46: SelfUnregModules.
            Action ended 23:40:46: SelfUnregModules. Return value 1.
            Action 23:40:46: UnregisterTypeLibraries. Unregistering type libraries
            Action start 23:40:46: UnregisterTypeLibraries.
            Action ended 23:40:46: UnregisterTypeLibraries. Return value 0.
            Action 23:40:46: RemoveODBC. Removing ODBC components
            Action start 23:40:46: RemoveODBC.
            Action ended 23:40:46: RemoveODBC. Return value 1.
            Action 23:40:46: UnregisterFonts. Unregistering fonts
            Action start 23:40:46: UnregisterFonts.
            Action ended 23:40:46: UnregisterFonts. Return value 1.
            Action 23:40:46: RemoveRegistryValues. Removing system registry values
            Action start 23:40:46: RemoveRegistryValues.
            Action ended 23:40:46: RemoveRegistryValues. Return value 1.
            Action 23:40:46: UnregisterClassInfo. Unregister class servers
            Action start 23:40:46: UnregisterClassInfo.
            Action ended 23:40:46: UnregisterClassInfo. Return value 0.
            Action 23:40:46: UnregisterExtensionInfo. Unregistering extension servers
            Action start 23:40:46: UnregisterExtensionInfo.
            Action ended 23:40:46: UnregisterExtensionInfo. Return value 0.
            Action 23:40:46: UnregisterProgIdInfo. Unregistering program identifiers
            Action start 23:40:46: UnregisterProgIdInfo.
            Action ended 23:40:46: UnregisterProgIdInfo. Return value 0.
            Action 23:40:46: UnregisterMIMEInfo. Unregistering MIME info
            Action start 23:40:46: UnregisterMIMEInfo.
            Action ended 23:40:46: UnregisterMIMEInfo. Return value 0.
            Action 23:40:46: RemoveIniValues. Removing INI file entries
            Action start 23:40:46: RemoveIniValues.
            Action ended 23:40:46: RemoveIniValues. Return value 1.
            Action 23:40:46: RemoveShortcuts. Removing shortcuts
            Action start 23:40:46: RemoveShortcuts.
            Action ended 23:40:46: RemoveShortcuts. Return value 0.
            Action 23:40:46: RemoveEnvironmentStrings. Updating environment strings
            Action start 23:40:46: RemoveEnvironmentStrings.
            Action ended 23:40:46: RemoveEnvironmentStrings. Return value 1.
            Action 23:40:46: RemoveDuplicateFiles. Removing duplicated files
            Action start 23:40:46: RemoveDuplicateFiles.
            Action ended 23:40:46: RemoveDuplicateFiles. Return value 1.
            Action 23:40:46: RemoveFiles. Removing files
            Action start 23:40:46: RemoveFiles.
            Action ended 23:40:46: RemoveFiles. Return value 0.
            Action 23:40:46: RemoveFolders. Removing folders
            Action start 23:40:46: RemoveFolders.
            Action ended 23:40:46: RemoveFolders. Return value 0.
            Action 23:40:46: CreateFolders. Creating folders
            Action start 23:40:46: CreateFolders.
            Action ended 23:40:46: CreateFolders. Return value 0.
            Action 23:40:46: MoveFiles. Moving files
            Action start 23:40:46: MoveFiles.
            Action ended 23:40:46: MoveFiles. Return value 1.
            Action 23:40:46: InstallFiles. Copying new files
            Action start 23:40:46: InstallFiles.
            File: Copying new files,  Directory: ,  Size:
            [    4764] Sun May 30 23:40:47 2010  INFO
            Action ended 23:40:47: InstallFiles. Return value 1.
            Action 23:40:47: PatchFiles. Patching files
            Action start 23:40:47: PatchFiles.
            Action ended 23:40:47: PatchFiles. Return value 0.
            Action 23:40:47: DuplicateFiles. Creating duplicate files
            Action start 23:40:47: DuplicateFiles.
            Action ended 23:40:47: DuplicateFiles. Return value 1.
            Action 23:40:47: BindImage. Binding executables
            Action start 23:40:47: BindImage.
            Action ended 23:40:47: BindImage. Return value 1.
            Action 23:40:47: CreateShortcuts. Creating shortcuts
            Action start 23:40:47: CreateShortcuts.
            Shortcut: Creating shortcuts
            Action ended 23:40:47: CreateShortcuts. Return value 0.
            Action 23:40:47: RegisterClassInfo. Registering class servers
            Action start 23:40:47: RegisterClassInfo.
            Action ended 23:40:47: RegisterClassInfo. Return value 0.
            Action 23:40:47: RegisterExtensionInfo. Registering extension servers
            Action start 23:40:47: RegisterExtensionInfo.
            Action ended 23:40:47: RegisterExtensionInfo. Return value 0.
            Action 23:40:47: RegisterProgIdInfo. Registering program identifiers
            Action start 23:40:47: RegisterProgIdInfo.
            Action ended 23:40:47: RegisterProgIdInfo. Return value 0.
            Action 23:40:47: RegisterMIMEInfo. Registering MIME info
            Action start 23:40:47: RegisterMIMEInfo.
            Action ended 23:40:47: RegisterMIMEInfo. Return value 0.
            Action 23:40:47: WriteRegistryValues. Writing system registry values
            Action start 23:40:47: WriteRegistryValues.
            Key: Writing system registry values, Name: , Value:
            Action ended 23:40:47: WriteRegistryValues. Return value 1.
            Action 23:40:47: WriteIniValues. Writing INI file values
            Action start 23:40:47: WriteIniValues.
            Action ended 23:40:47: WriteIniValues. Return value 1.
            Action 23:40:47: WriteEnvironmentStrings. Updating environment strings
            Action start 23:40:47: WriteEnvironmentStrings.
            Action ended 23:40:47: WriteEnvironmentStrings. Return value 1.
            Action 23:40:47: RegisterFonts. Registering fonts
            Action start 23:40:47: RegisterFonts.
            Action ended 23:40:47: RegisterFonts. Return value 1.
            Action 23:40:47: InstallODBC. Installing ODBC components
            Action start 23:40:47: InstallODBC.
            Action ended 23:40:47: InstallODBC. Return value 0.
            Action 23:40:47: RegisterTypeLibraries. Registering type libraries
            Action start 23:40:47: RegisterTypeLibraries.
            Action ended 23:40:47: RegisterTypeLibraries. Return value 0.
            Action 23:40:47: SelfRegModules. Registering modules
            Action start 23:40:47: SelfRegModules.
            Action ended 23:40:47: SelfRegModules. Return value 1.
            Action 23:40:47: RegisterComPlus. Registering COM+ Applications and Components
            Action start 23:40:47: RegisterComPlus.
            Action ended 23:40:47: RegisterComPlus. Return value 0.
            Action 23:40:47: InstallServices. Installing new services
            Action start 23:40:47: InstallServices.
            Action ended 23:40:47: InstallServices. Return value 1.
            Action 23:40:47: StartServices. Starting services
            Action start 23:40:47: StartServices.
            Action ended 23:40:47: StartServices. Return value 1.
            Action 23:40:47: RegisterUser. Registering user
            Action start 23:40:47: RegisterUser.
            Registering user
            Action ended 23:40:47: RegisterUser. Return value 1.
            Action 23:40:47: RegisterProduct. Registering product
            Action start 23:40:47: RegisterProduct.
            Registering product
            Action ended 23:40:47: RegisterProduct. Return value 1.
            Action 23:40:47: PublishComponents. Publishing qualified components
            Action start 23:40:47: PublishComponents.
            Action ended 23:40:47: PublishComponents. Return value 0.
            Action 23:40:47: MsiPublishAssemblies. Publishing assembly information
            Action start 23:40:47: MsiPublishAssemblies.
            Application Context:Publishing assembly information, Assembly Name:
            Action ended 23:40:47: MsiPublishAssemblies. Return value 1.
            Action 23:40:47: PublishFeatures. Publishing product features
            Action start 23:40:47: PublishFeatures.
            Feature: Publishing product features
            Action ended 23:40:47: PublishFeatures. Return value 1.
            Action 23:40:47: PublishProduct. Publishing product information
            Action start 23:40:47: PublishProduct.
            Action ended 23:40:47: PublishProduct. Return value 1.
            Action 23:40:47: InstallFinalize.
            Action start 23:40:47: InstallFinalize.
            Action 23:40:47: ProcessComponents. Updating component registration
            Action 23:40:47: RemoveODBC. Removing ODBC components
            Action 23:40:47: InstallFiles. Copying new files
            File: msvcr80.dll,  Directory: ,  Size: 632656
            File: msvcp80.dll,  Directory: ,  Size: 554832
            File: x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989.cat,  Directory: ,  Size: 7473
            File: x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989.manifest,  Directory: ,  Size: 1870
            File: msvcm80.dll,  Directory: ,  Size: 479232
            File: 8.0.50727.4053.policy,  Directory: ,  Size: 804
            File: 8.0.50727.4053.cat,  Directory: ,  Size: 7495
            Shortcut: ARPPRODUCTICON.exe
            Key: \Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents, Name: {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E}, Value: C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\\8.0.50727.4053.policy
            Key: \Software\Microsoft\Windows\CurrentVersion\SideBySide\PatchedComponents, Name: {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}, Value: C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\\msvcr80.dll
            Application Context:Global, Assembly Name:Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32",publicKeyToken="1fc8b3b9a1e 18e3b",processorArchitecture="x86"
            Application Context:Global, Assembly Name:policy.8.0.Microsoft.VC80.CRT,version="8.0.50727.4053",type="win32-policy",publicKey Token="1fc8b3b9a1e18e3b",processorArchitecture="x86"
            Feature: Microsoft_VC80_CRT_x86_
            Error 1935.An error occurred during the installation of assembly component {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Action ended 23:40:47: InstallFinalize. Return value 3.
            Message type: 2, Argument: 0
            Action 23:40:47: Rollback. Rolling back action:
            Registering product
            Registering user
            Creating shortcuts
            Copying new files
            [    4764] Sun May 30 23:40:48 2010  INFO
            Info 1935.An error occurred during the installation of assembly component {63E949F6-03BC-5C40-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Info 1935.An error occurred during the installation of assembly component {98CB24AD-52FB-DB5F-A01F-C8B3B9A1E18E}. HRESULT: 0x80070002.
            Message type: 2, Argument: 1
            Action ended 23:40:48: INSTALL. Return value 3.
            Property(S): DiskPrompt = [1]
            Property(S): UpgradeCode = {662366D8-8FF7-4EA3-92A8-C7FEA8AC8032}
            Property(S): ProductToBeRegistered = 1
            Property(S): SourcedirProduct = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            Property(S): SOURCEDIR = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\
            Property(S): PrimaryVolumeSpaceRemaining = 0
            Property(S): PrimaryVolumeSpaceRequired = 0
            Property(S): PrimaryVolumeSpaceAvailable = 0
            Property(S): OutOfNoRbDiskSpace = 0
            Property(S): OutOfDiskSpace = 0
            Property(S): CostingComplete = 1
            Property(S): ROOTDRIVE = D:\
            Property(S): ACTION = INSTALL
            Property(S): SHIMFLAGS = 512
            Property(S): UILevel = 2
            Property(S): OriginalDatabase = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\Microsoft_VC80_CRT_x86.msi
            Property(S): DATABASE = C:\Windows\Installer\18510.msi
            Property(S): Privileged = 1
            Property(S): MsiRunningElevated = 1
            Property(S): RedirectedDllSupport = 2
            Property(S): MsiWin32AssemblySupport = 6.1.7600.16385
            Property(S): MsiNetAssemblySupport = 2.0.50727.4927
            Property(S): Date = 30/05/2010
            Property(S): Time = 23:40:48
            Property(S): TTCSupport = 1
            Property(S): ColorBits = 32
            Property(S): TextInternalLeading = 3
            Property(S): TextHeight = 16
            Property(S): BorderSide = 1
            Property(S): BorderTop = 1
            Property(S): CaptionHeight = 22
            Property(S): ScreenY = 768
            Property(S): ScreenX = 1024
            Property(S): SystemLanguageID = 3082
            Property(S): ComputerName = ALEIX-PC
            Property(S): UserLanguageID = 3082
            Property(S): UserSID = S-1-5-21-1716922685-3153901978-1194191871-1002
            Property(S): LogonUser = Aleix
            Property(S): MsiTrueAdminUser = 1
            Property(S): AdminUser = 1
            Property(S): VirtualMemory = 6374
            Property(S): PhysicalMemory = 3949
            Property(S): Intel = 6
            Property(S): Msix64 = 6
            Property(S): MsiAMD64 = 6
            Property(S): ShellAdvtSupport = 1
            Property(S): OLEAdvtSupport = 1
            Property(S): GPTSupport = 1
            Property(S): VersionNT = 601
            Property(S): ProgramFilesFolder = C:\Program Files (x86)\
            Property(S): ADOBE = C:\Program Files (x86)\Adobe\
            Property(S): TARGETDIR = D:\
            Property(S): ALLUSERSPROFILE = D:\
            Property(S): AdminToolsFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Administrative Tools\
            Property(S): AppDataFolder = C:\Users\Aleix\AppData\Roaming\
            Property(S): CommonAppDataFolder = C:\ProgramData\
            Property(S): CommonFiles64Folder = C:\Program Files (x86)\Common Files\
            Property(S): CommonFilesFolder = C:\Program Files (x86)\Common Files\
            Property(S): ISYourDataBaseDir = C:\Program Files (x86)\Adobe\My Product Name\Database\
            Property(S): DATABASEDIR = C:\Program Files (x86)\Adobe\My Product Name\Database\
            Property(S): DesktopFolder = C:\Users\Public\Desktop\
            Property(S): FavoritesFolder = C:\Users\Aleix\Favorites\
            Property(S): FontsFolder = C:\Windows\Fonts\
            Property(S): GlobalAssemblyCache = D:\
            Property(S): MY_PRODUCT_NAME = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): INSTALLDIR = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): ISCommonFilesFolder = C:\Program Files (x86)\Common Files\InstallShield\
            Property(S): ISMyCompanyDir = C:\Program Files (x86)\My Company Name\
            Property(S): ISMyProductDir = C:\Program Files (x86)\My Company Name\My Product Name\
            Property(S): ISUpdateServiceFolder = C:\Program Files (x86)\Common Files\InstallShield\UpdateService\
            Property(S): LocalAppDataFolder = C:\Users\Aleix\AppData\Local\
            Property(S): MyPicturesFolder = C:\Users\Aleix\Pictures\
            Property(S): PersonalFolder = C:\Users\Aleix\Documents\
            Property(S): PrimaryVolumePath = D:\
            Property(S): ProgramFiles64Folder = C:\Program Files (x86)\
            Property(S): ProgramMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\
            Property(S): SendToFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\SendTo\
            Property(S): StartMenuFolder = C:\ProgramData\Microsoft\Windows\Start Menu\
            Property(S): StartupFolder = C:\ProgramData\Microsoft\Windows\Start Menu\Programs\Startup\
            Property(S): System16Folder = D:\
            Property(S): System64Folder = C:\Windows\SysWOW64\
            Property(S): SystemFolder = C:\Windows\SysWOW64\
            Property(S): SourceDir = C:\Users\Aleix\Downloads\Flash Pro CS5\Adobe Flash Professional CS5\payloads\Microsoft_VC80_CRT_x86\
            Property(S): TempFolder = C:\Users\Aleix\AppData\Local\Temp\
            Property(S): TemplateFolder = C:\ProgramData\Microsoft\Windows\Templates\
            Property(S): USERPROFILE = D:\
            Property(S): WindowsFolder = C:\Windows\
            Property(S): WindowsVolume = C:\
            Property(S): WinSxsDirectory.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
            Property(S): payload_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_d08d7da0442 a985d\
            Property(S): payload.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_0de06acd\
            Property(S): WindowsFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\
            Property(S): SystemFolder.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
            Property(S): WinSxsManifests.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
            Property(S): WinSxsPolicies.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
            Property(S): policydir.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir_ul.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
            Property(S): policydir.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.89.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_0de46bd0\
            Property(S): policydir.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.94.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_0de56c0a\
            Property(S): payload.8.0.50727.93.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_0de56c09\
            Property(S): policydir.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.95.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_0de56c0b\
            Property(S): payload.8.0.50727.96.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_0de56c0c\
            Property(S): policydir.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.97.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_0de56c0d\
            Property(S): policydir.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.98.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_0de56c0e\
            Property(S): payload.8.0.50727.99.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_0de56c0f\
            Property(S): policydir.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): policydir.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.100.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_6818287e\
            Property(S): policydir.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.101.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_6818287f\
            Property(S): payload.8.0.50727.103.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_68182881\
            Property(S): policydir.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.104.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_68182882\
            Property(S): payload.8.0.50727.193.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_68212ab8\
            Property(S): policydir.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.238.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_689938c4\
            Property(S): policydir.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3044.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_b80ea88c\
            Property(S): policydir.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3051.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_b80fa8c8\
            Property(S): policydir.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.3069.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_b810a90f\
            Property(S): payload.8.0.50727.1833.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_5ef082d6\
            Property(S): payload.8.0.50727.4027.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_e69378d0\
            Property(S): policydir.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_4428b63a\
            Property(S): payload.8.0.50727.4028.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_e69378d1\
            Property(S): payload.8.0.50727.4029.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_e69378d2\
            Property(S): payload.8.0.50727.4045.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_e695794c\
            Property(S): payload.8.0.50727.4052.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_e6967988\
            Property(S): payload.8.0.50727.4053.98CB24AD_52FB_DB5F_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_e6967989\
            Property(S): ALLUSERS = 1
            Property(S): WinSxsDirectory.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\
            Property(S): payload_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.microsoft.vc80.crt_1fc8b3b9a1e18e3b_8.0.50727.4053_none_ 516e2e610f48bda6\
            Property(S): WinSxsPolicies.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\
            Property(S): policydir.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): WindowsFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\
            Property(S): SystemFolder.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\SysWOW64\
            Property(S): WinSxsManifests.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Manifests\
            Property(S): payload.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.42_x-ww_51 e427d4\
            Property(S): policydir.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir_ul.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
            Property(S): policydir.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.94.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.94_x-ww_51 e92911\
            Property(S): policydir.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.89.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.89_x-ww_51 e828d7\
            Property(S): policydir.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.93.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.93_x-ww_51 e92910\
            Property(S): policydir.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.95.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.95_x-ww_51 e92912\
            Property(S): policydir.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.96.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.96_x-ww_51 e92913\
            Property(S): policydir.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.97.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.97_x-ww_51 e92914\
            Property(S): policydir.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.98.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.98_x-ww_51 e92915\
            Property(S): policydir.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.99.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.99_x-ww_51 e92916\
            Property(S): policydir.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.100.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.100_x-ww_a c1be585\
            Property(S): payload.8.0.50727.101.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.101_x-ww_a c1be586\
            Property(S): policydir.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.103.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.103_x-ww_a c1be588\
            Property(S): payload.8.0.50727.104.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.104_x-ww_a c1be589\
            Property(S): policydir.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.193.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.193_x-ww_a c24e7bf\
            Property(S): policydir.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): policydir.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\Policies\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_x-ww_77c247 73\
            Property(S): payload.8.0.50727.238.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.238_x-ww_a c9cf5cb\
            Property(S): payload.8.0.50727.3044.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3044_x-ww_ fc126593\
            Property(S): payload.8.0.50727.3051.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3051_x-ww_ fc1365cf\
            Property(S): payload.8.0.50727.3069.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.3069_x-ww_ fc146616\
            Property(S): payload.8.0.50727.1833.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.1833_x-ww_ a2f43fdd\
            Property(S): payload.8.0.50727.4027.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4027_x-ww_ 2a9735d7\
            Property(S): payload.8.0.50727.4028.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4028_x-ww_ 2a9735d8\
            Property(S): payload.8.0.50727.4029.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4029_x-ww_ 2a9735d9\
            Property(S): payload.8.0.50727.4045.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4045_x-ww_ 2a993653\
            Property(S): payload.8.0.50727.4052.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4052_x-ww_ 2a9a368f\
            Property(S): payload.8.0.50727.4053.63E949F6_03BC_5C40_FF1F_C8B3B9A1E18E = C:\Windows\winsxs\x86_policy.8.0.Microsoft.VC80.CRT_1fc8b3b9a1e18e3b_8.0.50727.4053_x-ww_ 2a9a3690\
            Property(S): RecentFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Recent\
            Property(S): PrintHoodFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Printer Shortcuts\
            Property(S): NetHoodFolder = C:\Users\Aleix\AppData\Roaming\Microsoft\Windows\Network Shortcuts\
            Property(S): RemoteAdminTS = 1
            Property(S): MsiNTSuitePersonal = 1
            Property(S): MsiNTProductType = 1
            Property(S): ISCHECKFORPRODUCTUPDATES = 1
            Property(S): ApplicationUsers = AllUsers
            Property(S): AgreeToLicense = No
            Property(S): _IsMaintenance = Change
            Property(S): SetupType = Typical
            Property(S): _IsSetupTypeMin = Typical
            Property(S): IS_SQLSERVER_USERNAME = sa
            Property(S): IS_SQLSERVER_AUTHENTICATION = 0
            Property(S): RestartManagerOption = CloseRestart
            Property(S): Display_IsBitmapDlg = 1
            Property(S): ARPPRODUCTICON = ARPPRODUCTICON.exe
            Property(S): DefaultUIFont = Tahoma8
            Property(S): DialogCaption = InstallShield for Windows Installer
            Property(S): DisplayNameCustom = Custom
            Property(S): DisplayNameMinimal = Minimal
            Property(S): DisplayNameTypical = Typical
            Property(S): DWUSINTERVAL = 30
            Property(S): ErrorDialog = SetupError
            Property(S): PROGMSG_IIS_EXTRACTzDONE = Extracted information for IIS virtual directories...
            Property(S): InstallChoice = AR
            Property(S): INSTALLLEVEL = 100
            Property(S): IS_COMPLUS_PROGRESSTEXT_COST = Costing COM+ application: [1]
            Property(S): IS_COMPLUS_PROGRESSTEXT_INSTALL = Installing COM+ application: [1]
            Property(S): IS_COMPLUS_PROGRESSTEXT_UNINSTALL = Uninstalling COM+ application: [1]
            Property(S): IS_PROGMSG_XML_COSTING = Costing XML files...
            Property(S): IS_PROGMSG_XML_CREATE_FILE = Creating XML file %s...
            Property(S): IS_PROGMSG_XML_FILES = Performing XML file changes...
            Property(S): IS_PROGMSG_XML_REMOVE_FILE = Removing XML file %s...
            Property(S): IS_PROGMSG_XML_ROLLBACK_FILES = Rolling back XML file changes...
            Property(S): IS_PROGMSG_XML_UPDATE_FILE = Updating XML file %s...
            Property(S): ISVROOT_PORT_NO = 0
            Property(S): Manufacturer = Adobe
            Property(S): PIDTemplate = 12345<###-%%%%%%%>@@@@@
            Property(S): ProductCode = {92D58719-BBC1-4CC3-A08B-56C9E884CC2C}
            Property(S): ProductID = none
            Property(S): ProductLanguage = 1033
            Property(S): ProductName = Microsoft_VC80_CRT_x86
            Property(S): ProductVersion = 8.0.50727.4053
            Property(S): PROGMSG_IIS_CREATEVROOT = Creating IIS virtual directory %s
            Property(S): PROGMSG_IIS_CREATEVROOTS = Creating IIS virtual directories...
            Property(S): PROGMSG_IIS_EXTRACT = Extracting information for IIS virtual directories...
            Property(S): PROGMSG_IIS_EXTRACTDONE = Extracted information for IIS virtual directories...
            Property(S): PROGMSG_IIS_REMOVESITE = Removing web site at port %d
            Property(S): PROGMSG_IIS_REMOVEVROOT = Removing IIS virtual directory %s
            Property(S): PROGMSG_IIS_REMOVEVROOTS = Removing IIS virtual directories...
            Property(S): PROGMSG_IIS_ROLLBACKVROOTS = Rolling back virtual directory and web site changes...
            Property(S): ProgressType0 = install
            Property(S): ProgressType1 = Installing
            Property(S): ProgressType2 = installed
            Property(S): ProgressType3 = installs
            Property(S): PROGMSG_IIS_EXTRACTDONEz = Extracted information for IIS virtual directories...
            Property(S): RebootYesNo = No
            Property(S): ReinstallModeText = omus
            Property(S): PROGMSG_IIS_CREATEAPPPOOLS = Creating application Pools...
            Property(S): PROGMSG_IIS_CREATEAPPPOOL = Creating application pool %s
            Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSION = Creating web service extension
            Property(S): PROGMSG_IIS_CREATEWEBSERVICEEXTENSIONS = Creating web service extensions...
            Property(S): PROGMSG_IIS_REMOVEAPPPOOL = Removing application pool
            Property(S): PROGMSG_IIS_REMOVEAPPPOOLS = Removing application pools...
            Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSION = Removing web service extension
            Property(S): PROGMSG_IIS_REMOVEWEBSERVICEEXTENSIONS = Removing web service extensions...
            Property(S): PROGMSG_IIS_ROLLBACKAPPPOOLS = Rolling back application pools...
            Property(S): PROGMSG_IIS_ROLLBACKWEBSERVICEEXTENSIONS = Rolling back web service extensions...
            Property(S): DWUSLINK = CE2BC78F6EACC0E8D9AC408FEEFC978F8EBCE78FCE9CA7F8CE4B878F7EBC2738E98CA7A8F9AC
            Property(S): ARPURLINFOABOUT = http://www.Adobe.com
            Property(S): SHOWLAUNCHPROGRAM = 0
            Property(S): REBOOT = ReallySuppress
            Property(S): ARPSYSTEMCOMPONENT = 1
            Property(S): ARPINSTALLLOCATION = C:\Program Files (x86)\Adobe\My Product Name\
            Property(S): ServicePackLevelMinor = 0
            Property(S): ServicePackLevel = 0
            Property(S): WindowsBuild = 7600
            Property(S): VersionNT64 = 601
            Property(S): VersionMsi = 5.00
            Property(S): VersionDatabase = 200
            Property(S): CLIENTPROCESSID = 3256
            Property(S): MSICLIENTUSESEXTERNALUI = 1
            Property(S): CLIENTUILEVEL = 3
            Property(S): CURRENTDIRECTORY = C:\Users\Aleix\AppData\Local\Adobe\OOBE\PDApp\DWA
            Property(S): USERNAME = Aleix
            Property(S): PackagecodeChanging = 1
            Property(S): ProductState = -1
            Property(S): PackageCode = {FA041436-73B8-40C4-97F3-249E037C89EE}
            === Logging stopped: 30/05/2010  23:40:48 ===
            1: 2 2: 0
            1: 2 2: 1
            Installation result: 1603
            Third party payload succeded.  Testing return code: 1603
            [    1424] Sun May 30 23:40:48 2010  INFO
            *=*=*=*=*=*=*=*=*=*=*=*=*=*=*=* Operation complete. Setting status: 2 =*=*=*=*=*=*=*=*=*=*=*=*=*
            :: END TIMER :: [Payload Operation :{92D58719-BBC1-4CC3-A08B-56C9E884CC2C}] took 4016.86 miliseconds (4.01686 seconds) DTR = 97.5886 KBPS (0.0953013 MBPS)
            User specified overrideFile:
            Calling the ROLLBACK custom action code for pre-install for payload {92D58719-BBC1-4CC3-A08B-56C9E884CC2C} Microsoft_VC80_CRT_x86
            [    1424] Sun May 30 23:40:48 2010  WARN
            Payload cannot be installed due to dependent operation failure
            Skipping payload {08D2E121-7F6A-43EB-97FD-629B44903403} Microsoft_VC90_CRT_x86 as payload is not cached
            Skipping payload {D92BBB52-82FF-42ED-8A3C-4E062F944AB7} Microsoft_VC80_MFCLOC_x86 as payload is not cached
            Skipping payload {D1A19B02-817E-4296-A45B-07853FD74D57} Microsoft_VC80_MFC_x86 as payload is not cached
            Skipping payload {2F6B67F4-A2BB-45D7-A80C-25FF646CC1C5} Adobe Player for Embedding as payload is not cached
            Skipping payload {033E378E-6AD3-4AD5-BDEB-CBD69B31046C} Microsoft_VC90_ATL_x86 as payload is not cached
            Skipping payload {635FED5B-2C6D-49BE-87E6-7A6FCD22BC5A} Microsoft_VC90_MFC_x86 as payload is not cached
            Skipping payload {E5DD149F-8370-48F9-A32C-2E3DC776CFFB} AdobeJRE as payload is not cached
            Skipping payload {3F023875-4A52-4605-9DB6-A88D4A813E8D} Camera Profiles Installer as payload is not cached
            Skipping payload {A8798E04-96FF-4564-9157-0D4C89CB794C} DynamiclinkSupport as payload is not cached
            Skipping payload {0F3647F8-E51D-4FCC-8862-9A8D0C5ACF25} Microsoft_VC80_ATL_x86 as payload is not cached
            Skipping payload {92A3CA0D-55CD-4C5D-BA95-5C2600C20F26} Microsoft_VC90_CRT_x86_x64 as payload is not cached
            Skipping payload {02731921-5711-4E7A-A898-D6BCF0F2A1CD} Adobe CSXS Infrastructure CS5 as payload is not cached
            Skipping payload {3423F36D-004F-4DFC-8BCE-07A20B8DFBDE} Suite Shared Configuration CS5 as payload is not cached
            Skipping payload {8557397C-A42D-486F-97B3-A2CBC2372593} Microsoft_VC90_ATL_x86_x64 as payload is not cached
            Skipping payload {A472B9E4-0AFF-4F7B-B25D-F64F8E928AAB} Microsoft_VC90_MFC_x86_x64 as payload is not cached
            Skipping payload {3BF96AC2-0CA1-11DF-B07B-459956D89593} AdobeHelp as payload is not cached
            Skipping payload {2EBE92C3-F9D8-48B5-A32B-04FA5D1709FA} Adobe XMP Panels CS5 as payload is not cached
            Skipping payload {BD0D6363-E961-410F-8BF4-ECD8795F3923} AdobeCMaps CS5 as payload is not cached
            Skipping payload {925ED7E4-E1B6-4544-8141-1C98A18D2E2E} AdobeOutputModule as payload is not cached
            Skipping payload {BAE5212B-6651-4AD8-B26A-1B284D2665C6} AdobePDFL CS5 as payload is not cached
            Skipping payload {6F3A624B-1B72-4081-96E8-23261F389C5C} AdobeTypeSupport CS5 as payload is not cached
            Skipping payload {37AB3C65-E02C-4DCF-B0E0-4C2E253D8FA3} Photoshop Camera Raw as payload is not cached
            Skipping payload {E995AC53-954A-48D2-A861-613B8D42A9BE} Adobe ExtendScript Toolkit CS5 as payload is not cached
            Skipping payload {E4E188D2-27D5-4E4C-92CE-87F9D24AD2F6} Adobe Extension Manager CS5 as payload is not cached
            Skipping payload {8CCA90E1-F5BA-456F-84BF-AD5FB2CCE13F} Adobe CSXS Extensions CS5 as payload is not cached
            Skipping payload {D5CC77BE-BC5B-424E-8E45-DF60AFF7BE9C} Pixel Bender Toolkit as payload is not cached
            Skipping payload {30221E3E-4C47-4560-A296-DD9ABB500C21} AIR2 For Adobe Flash Pro as payload is not cached
            Payload {9D2819E4-C51E-4C89-8E28-673B9909A536} can not be installed due to dependent operation failure.
            Skipping payload {9D2819E4-C51E-4C89-8E28-673B9909A536} AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES as payload is not cached
            Skipping payload {F6FA54C9-3E8F-4416-905C-DA5398DF9640} Adobe AIR as payload is not cached
            Skipping payload {5E08533A-2C1B-469D-AFD5-953C9D00031F} Adobe BrowserLab CS Live as payload is not cached
            Skipping payload {7E5AA19B-0B85-4f44-BA26-728851489200} Adobe Flash Player 10 ActiveX as payload is not cached
            Skipping payload {40F95A03-885A-45fb-9A14-486BEFEDDF34} Adobe Flash Player 10 Plugin as payload is not cached
            Skipping payload {03B6AF5B-A024-43DE-8DD2-8FB7B6A4149A} Adobe Media Player as payload is not cached
            Skipping payload {7A33510F-1580-42C2-877E-8C5502566292} Adobe Player for Embedding x64 as payload is not cached
            Skipping payload {56540320-C921-1029-83D9-FE864D1FC1DF} Adobe ReviewPanel CS5 as payload is not cached
            Skipping payload {AE9B837F-D135-42FC-BE03-33545B5DCBDC} Adobe WinSoft Linguistics Plugin CS5 as payload is not cached
            Skipping payload {B55FDCCB-8A45-4943-8D90-585C3490A032} Adobe WinSoft Linguistics Plugin CS5 x64 as payload is not cached
            Skipping payload {98DD55B6-C58C-462F-B8A4-F0585BFEBB15} AdobeCMaps x64 CS5 as payload is not cached
            Skipping payload {39CB2E53-5326-4939-8B5A-0402C6EFBFE3} AdobeColorCommonSetCMYK as payload is not cached
            Skipping payload {78A53622-CDBA-49D1-A3D0-D563FB398D0C} AdobeColorCommonSetRGB as payload is not cached
            Skipping payload {B60B8713-F828-44F9-BEEE-7596F814E540} AdobeColorEU CS5 as payload is not cached
            Skipping payload {54F4466A-091A-46DA-B697-43D55CEF9DF6} AdobeColorJA CS5 as payload is not cached
            Skipping payload {BEC5B482-32A1-43E0-B7F7-9BF9592A1069} AdobeColorNA CS5 as payload is not cached
            [    1424] Sun May 30 23:40:49 2010  WARN
            [    1424] Sun May 30 23:40:49 2010  INFO
            Skipping payload {17C6080E-F475-4B49-A30C-EEB85673E999} AdobePDFL x64 CS5 as payload is not cached
            Skipping payload {9A8B01C5-78D1-465F-B5F6-BD59B7800EC7} AdobeTypeSupport x64 CS5 as payload is not cached
            Skipping payload {66173EC7-974E-4652-9468-4A93D2481BF0} CSXS Story Extension as payload is not cached
            Skipping payload {6D96660C-1444-410E-9A84-681C0AFB8937} PDF Settings CS5 as payload is not cached
            Skipping payload {61A3D10A-AA4D-4E4C-B9DB-6A08D318EA41} Photoshop Camera Raw (64 bit) as payload is not cached
            Skipping payload {E319B9F9-4DE6-462C-970B-77D06C7807EE} Players For Adobe Flash Pro as payload is not cached
            Skipping payload {03EEF3DA-71F9-4FE5-92AD-D10142E26459} SiteCatalyst NetAverages as payload is not cached
            Skipping payload {F1599C36-2EAB-448F-B8F9-7DBEE9D5B345} TLF For Adobe Flash Pro as payload is not cached
            Skipping payload {635DCFA5-3A47-4452-AEC7-D3B23FFE929D} iPhone Publishing as payload is not cached
            Skipping payload {6C7D437A-D2E9-4FE9-A4D9-A6329860835C} Adobe Linguistics CS5 as payload is not cached
            Skipping payload {0669F23C-1B69-41B4-A3ED-4F54A5986D66} Adobe Linguistics CS5 x64 as payload is not cached
            Skipping payload {CFA46C39-C539-4BE9-9364-495003C714AD} Adobe SwitchBoard 2.0 as payload is not cached
            Skipping payload {6E505C8F-2896-11DF-9B64-0013724DD917} DeviceCentral as payload is not cached
            Payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} can not be installed due to dependent operation failure.
            Skipping payload {1D8A135F-28A4-11DF-A7C5-0024E8692489} DeviceCentral_DeviceCentral3LP-es_ES as payload is not cached
            Skipping payload {68CEA5C9-2964-4ECB-84A4-D77C511332BC} Adobe Media Encoder CS5 X64 as payload is not cached
            Skipping payload {0D067D13-C3D7-4EA6-B346-740CD91FD547} Adobe Bridge CS5 as payload is not cached
            Skipping payload {CFC9F871-7C40-40B6-BE4A-B98A5B309716} Adobe Flash CS5 as payload is not cached
            Payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} can not be installed due to dependent operation failure.
            Skipping payload {579FDC01-BA85-49E7-B16A-2C4CB55F7ACD} Adobe Flash CS5_AdobeMobileExtension_Flash11-mul as payload is not cached
            Payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} can not be installed due to dependent operation failure.
            Skipping payload {C52DC2CA-7BEE-440A-8A0F-23EBA0D3A00D} Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES as payload is not cached
            Payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} can not be installed due to dependent operation failure.
            Skipping payload {C6EABDA0-8973-4824-B11A-20EF5B07F537} Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack as payload is not cached
            No operation.  We're done:
            Updating driver data - Action: Remove driver entry
            Updating driver data successful. Driver entry was removed. ARP estimated size 0KB
            [    1424] Sun May 30 23:40:51 2010  INFO
            Total components installed: 0
            Total components repaired: 0
            Total components removed: 0
            [    1424] Sun May 30 23:40:51 2010 ERROR
            The following payload errors were found during install:
            - Adobe CSXS Infrastructure CS5: Install failed
            - Microsoft_VC90_ATL_x86: Install failed
            - Adobe Media Player: Install failed
            - SiteCatalyst NetAverages: Install failed
            - Adobe Linguistics CS5 x64: Install failed
            - Microsoft_VC90_CRT_x86: Install failed
            - Adobe Bridge CS5: Install failed
            - Microsoft_VC80_ATL_x86: Install failed
            - AdobePDFL x64 CS5: Install failed
            - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            - Adobe XMP Panels CS5: Install failed
            - Adobe Player for Embedding: Install failed
            - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            - Suite Shared Configuration CS5: Install failed
            - Photoshop Camera Raw: Install failed
            - AdobeColorCommonSetCMYK: Install failed
            - AdobeHelp: Install failed
            - Camera Profiles Installer: Install failed
            - Adobe Flash Player 10 Plugin: Install failed
            - AdobeColorJA CS5: Install failed
            - Adobe ReviewPanel CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            - Adobe BrowserLab CS Live: Install failed
            - Photoshop Camera Raw (64 bit): Install failed
            - iPhone Publishing: Install failed
            - Microsoft_VC90_MFC_x86: Install failed
            - CSXS Story Extension: Install failed
            - Adobe Media Encoder CS5 X64: Install failed
            - Adobe Linguistics CS5: Install failed
            - PDF Settings CS5: Install failed
            - DeviceCentral: Failed due to Language Pack installation failure
            - AdobeTypeSupport CS5: Install failed
            - AdobeColorCommonSetRGB: Install failed
            - Adobe Player for Embedding x64: Install failed
            - Adobe Flash Player 10 ActiveX: Install failed
            - Microsoft_VC90_ATL_x86_x64: Install failed
            - Adobe CSXS Extensions CS5: Install failed
            - AdobeOutputModule: Install failed
            - Microsoft_VC90_CRT_x86_x64: Install failed
            - Microsoft_VC80_CRT_x86: Install failed
            - AdobeCMaps x64 CS5: Install failed
            - AdobeTypeSupport x64 CS5: Install failed
            - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            - Microsoft_VC90_MFC_x86_x64: Install failed
            - DynamiclinkSupport: Install failed
            - Adobe WinSoft Linguistics Plugin CS5: Install failed
            - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            - AdobeColorEU CS5: Install failed
            - AdobePDFL CS5: Install failed
            - AdobeCMaps CS5: Install failed
            - AdobeColorNA CS5: Install failed
            - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            - Adobe SwitchBoard 2.0: Install failed
            - Adobe Flash CS5: Failed due to Language Pack installation failure
            - Microsoft_VC80_MFC_x86: Install failed
            - Pixel Bender Toolkit: Install failed
            - Microsoft_VC80_MFCLOC_x86: Install failed
            - Players For Adobe Flash Pro: Install failed
            - Adobe Extension Manager CS5: Install failed
            - AdobeJRE: Install failed
            - Adobe ExtendScript Toolkit CS5: Install failed
            - TLF For Adobe Flash Pro: Install failed
            - Adobe AIR: Install failed
            Call PostSession Custom Hook
            :: END TIMER :: [Total Timer] took 30047.6 miliseconds (30.0476 seconds) DTR = 7668.36 KBPS (7.48863 MBPS)
            -------------------------------------- Summary --------------------------------------
            - 0 fatal error(s), 65 error(s), 65 warning(s)
            WARNING: OS requirements not met for {694213D7-1E0E-4C8F-B822-E2E3680C0FCE}
            WARNING: OS requirements not met for {CFC9F871-7C40-40B6-BE4A-B98A5B309716}
            WARNING: Payload cannot be installed due to dependent operation failure
            ERROR: The following payload errors were found during install:
            ERROR:  - Adobe CSXS Infrastructure CS5: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86: Install failed
            ERROR:  - Adobe Media Player: Install failed
            ERROR:  - SiteCatalyst NetAverages: Install failed
            ERROR:  - Adobe Linguistics CS5 x64: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86: Install failed
            ERROR:  - Adobe Bridge CS5: Install failed
            ERROR:  - Microsoft_VC80_ATL_x86: Install failed
            ERROR:  - AdobePDFL x64 CS5: Install failed
            ERROR:  - DeviceCentral_DeviceCentral3LP-es_ES: Install failed
            ERROR:  - Adobe XMP Panels CS5: Install failed
            ERROR:  - Adobe Player for Embedding: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro: Failed due to Language Pack installation failure
            ERROR:  - Suite Shared Configuration CS5: Install failed
            ERROR:  - Photoshop Camera Raw: Install failed
            ERROR:  - AdobeColorCommonSetCMYK: Install failed
            ERROR:  - AdobeHelp: Install failed
            ERROR:  - Camera Profiles Installer: Install failed
            ERROR:  - Adobe Flash Player 10 Plugin: Install failed
            ERROR:  - AdobeColorJA CS5: Install failed
            ERROR:  - Adobe ReviewPanel CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-mul: Install failed
            ERROR:  - Adobe BrowserLab CS Live: Install failed
            ERROR:  - Photoshop Camera Raw (64 bit): Install failed
            ERROR:  - iPhone Publishing: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86: Install failed
            ERROR:  - CSXS Story Extension: Install failed
            ERROR:  - Adobe Media Encoder CS5 X64: Install failed
            ERROR:  - Adobe Linguistics CS5: Install failed
            ERROR:  - PDF Settings CS5: Install failed
            ERROR:  - DeviceCentral: Failed due to Language Pack installation failure
            ERROR:  - AdobeTypeSupport CS5: Install failed
            ERROR:  - AdobeColorCommonSetRGB: Install failed
            ERROR:  - Adobe Player for Embedding x64: Install failed
            ERROR:  - Adobe Flash Player 10 ActiveX: Install failed
            ERROR:  - Microsoft_VC90_ATL_x86_x64: Install failed
            ERROR:  - Adobe CSXS Extensions CS5: Install failed
            ERROR:  - AdobeOutputModule: Install failed
            ERROR:  - Microsoft_VC90_CRT_x86_x64: Install failed
            ERROR:  - Microsoft_VC80_CRT_x86: Install failed
            ERROR:  - AdobeCMaps x64 CS5: Install failed
            ERROR:  - AdobeTypeSupport x64 CS5: Install failed
            ERROR:  - AIR2 For Adobe Flash Pro_AIR2_Flash11-es_ES: Install failed
            ERROR:  - Microsoft_VC90_MFC_x86_x64: Install failed
            ERROR:  - DynamiclinkSupport: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5: Install failed
            ERROR:  - Adobe WinSoft Linguistics Plugin CS5 x64: Install failed
            ERROR:  - AdobeColorEU CS5: Install failed
            ERROR:  - AdobePDFL CS5: Install failed
            ERROR:  - AdobeCMaps CS5: Install failed
            ERROR:  - AdobeColorNA CS5: Install failed
            ERROR:  - Adobe Flash CS5_AdobeMobileExtension_Flash11-es_ES: Install failed
            ERROR:  - Adobe Flash CS5_AdobeFlash11-es_ESLanguagePack: Install failed
            ERROR:  - Adobe SwitchBoard 2.0: Install failed
            ERROR:  - Adobe Flash CS5: Failed due to Language Pack installation failure
            ERROR:  - Microsoft_VC80_MFC_x86: Install failed
            ERROR:  - Pixel Bender Toolkit: Install failed
            ERROR:  - Microsoft_VC80_MFCLOC_x86: Install failed
            ERROR:  - Players For Adobe Flash Pro: Install failed
            ERROR:  - Adobe Extension Manager CS5: Install failed
            ERROR:  - AdobeJRE: Install failed
            ERROR:  - Adobe ExtendScript Toolkit CS5: Install failed
            ERROR:  - TLF For Adobe Flash Pro: Install failed
            ERROR:  - Adobe AIR: Install failed
            Search the same string above to find when the error occured.
            Exit Code: 7 - Unable to complete Silent workflow
            END - Installer Session
            • 3. Re: Problem instalation Flash CS5 with Windows 7
              p_c_e Adobe Employee
              Your main problem appears to be
              Error 1935.An error occurred during the installation of assembly component...
              during the CRT installation due to which the complete installation is failing. You may want to try out some of the fixes as mentioned in the msdn support site. You will be able to choose the fix based on your machine state.
              • 4. Re: Problem instalation Flash CS5 with Windows 7
                DarkMatter78 Level 1
                PROBLEM SOLVED!!!!!!!!!!!!
                I just spent 9 hours straight on this, but will was stronger than "its". Now I have both cs4 and cs5, but hopefully it will work if you just have cs5 as well. I also did not try runnning cs5 installer first after implementing the fix, maybe that will work too..And when getting the cs5 error, I went to re-install cs4 but got an error as well so that is why I took the steps I did. On 7x64 do the followin
                First run the cs5 cleanup tool and reboot.
                Second, go into c:\program file(x86)\common files\adobe\installers . Delete everything in it
                Then go into you registry (start, run, then type regedit) and expand to this registry key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Installer\UserData\S-1-5-18\ Components ...(if this isnt there, go to the folder that you deleted the files from a moment ago and extract the log from the zip file and open it and go to the end. where it says error 1402 will be followed by a unknown\components\(a bunch of numebers right here)\(more numbers)  ...
                Copy the numbers directly after the components\ and go back into registry and click edit then "find" paste those numbers into the box and hit find..when you get to the key, scroll ALL the way back up to components again. Right click components and hit permissions.. Go to advanced and then the ownership tab up top.. click edit, hightlight administrator(s), check the box to "replace subcontainers" and click apply. respond yes to everything and close that and hit apply again if asked. then click the add button above the advanced button you just clicked. when the new box appears, click advanced and then click find now. Highlight Administrators and SYSTEM and hit OK. Then give both of them full rights and hit apply. Then click advanced again and in the first window check the box that says "replace all child objects...." and hit apply. accept the prompts and hit okay. Now give Administrators, SYSTEM, AND TrustedInstaller full rights by clicking edit above the advanced tab in the first properties box.. Then click advanced again and in the first window click "replace all child object....." again and hit apply....
                Now do the same for the winsxs folder and (for good measure i did syswow64 but not sure if its necessary)...
                Now you should be able to install both versions..(as i said, I installed cs4 first, maybe it was not necessary)...
                If you dont like the idea of just blindly giving administrators full rights to all system folders, you can spend MANY MANY hours running the installs over and over and getting the faulty registry value that caused it to fail and create specific permissions for that and then go on to the next value that fails......what a pain
                Now go into c:\windows and on the system32 folder, right click and go to properties. Go to the security tab. Click advanced and then "owner" and click edit. highlght administrators and check the box
