15 Replies Latest reply on Jul 17, 2013 7:30 AM by gkaiseril
    Custom JavaScript Code for If/Then/Else Statement
    CSScott
      Can someone help me figure out this code. I have a field in a PDF that I need to generate a discount based on original price of an item. If Price is greater than 5000 then I need the discount field to say 1500. Else the discount field needs to be Price* .30.
      I tried this but it didn't work: If price>5000 then discount=1500 else discount=price*.3
      Anyone have some help?
      Thank you!
        • 1. Re: Custom JavaScript Code for If/Then/Else Statement
          Acrobat forms use JavaScript so you need to use the JavaScirpt syntax for the proper JavaScript syntax for the 'if...else' statement. You also need to access the field object as established by the Acrobat JavaScript Object by using the 'getField' method of the doc object, 'this.getField(cName)' and then the 'value' property for that object.
          // custom calculation script for the 'discount field
          // establish the name of the price field
          var cPrice = 'price';
          // get the value of the price field
          var nPrice = this.getField(cPrice).vallue;
          // assume the discount is 30% of price
          event.value = nPrice * 0.30;
          // set discount to 1,500 if price is greater than 5,000
          if(nPrice > 5000) {
          event.value = 1500;
          // end of custom calculation script
          For more information see Conditional Execution by Thom Parker.
          • 2. Re: Custom JavaScript Code for If/Then/Else Statement
            CSScott Level 1
            Outstanding! Worked perfect the first time!
            Thank you SO much for your help!
            • 3. Re: Custom JavaScript Code for If/Then/Else Statement
              vascocenco
              Hello Experts,
              for you i am sure that my problem is quite simple, but for me is a big one because i just starting to learn Javascript.Sothis is the problem:
              i have a PDF form in which i have some fields to calculate  sq feet for some windows; after the calculations are done, i need a code which must display a price per sq feet based on the amount of sq feet.
              The range for price depends of the sq feet amount must be between  7 and 10 $. This price must be generate in a field named " price per sq feet"
              Anybode can help me?
              Thank you all
              • 4. Re: Custom JavaScript Code for If/Then/Else Statement
                You'll need to provide some more information about how the price should be
                calculated.
                • 5. Re: Custom JavaScript Code for If/Then/Else Statement
                  vascocenco Level 1
                  let's say if you have 1-50 sq feet the pricewill be calculated with  10 $/ sq feet. if you have 50-100 feet the price will be calculated with 9 $/ sq feet....and so on until the margin of the range ( 7$ is reached). In fact i need to be able to calculatethe price of the sq feet based of the amount of total sq  feet
                  • 6. Re: Custom JavaScript Code for If/Then/Else Statement
                    So as the custom calculation code for the Price field you can use something like this:
                    var totalSqFt = Number(this.getField("TotalSqFt").value);
                    if (totalSqFt<50) event.value = 10;
                    else if (totalSqFt<100) event.value = 9;
                    else if (totalSqFt<200) event.value = 8; //etc.
                    else event.value = 7; // minimum price
                    Then the Total Price is just Total Sq Ft * Price. You'll just need to make sure that Total Price is calculated after the Price field, to avoid problems.
                    • 7. Re: Custom JavaScript Code for If/Then/Else Statement
                      vascocenco Level 1
                      i understand but is something that is not working...because if we consider that the totalsqft is 40 ...let's say, than,  this means that is smaller than 50 and also smaller than 100 ...in the end,  with which value will be done the calculation?...with 10 or with 9?....also the code is not working...i don't know why, i am absolutely null at javascript so i need a code exactly how must be on my form...sorry for boedering you but if i knew how to do i will never  boeder you guys....that's way i must thank in advance.
                      So if you can help me with a code just to copy paste i will be more than gratful.
                      in other words the code must be construct, i think, based on the expression.... if...7<totalsqft<10....but i repeat myself...i don't know javascript i just think logicaly
                      thank you !
                      • 8. Re: Custom JavaScript Code for If/Then/Else Statement
                        That's why I used the if-else if-else construct... It basically does this:
                        - Is the value smaller than 50? If so, price is 10.
                        - If not, is the value smaller than 100 (ie bigger than or equals to 50 and smaller than 100)? If so, price is 9.
                        - If not, is the value smaller then 200 (ie bigger than or equals to 100 and smaller than 200)? If so, price is 8;
                        - If not (ie bigger or equals to 200), price is 7.
                        If it's not working check the JS console for errors.
                        • 9. Re: Custom JavaScript Code for If/Then/Else Statement
                          Very few programming languages let you test an expression like 7 < X < 10.
                          But most of them let you write it as two tests  7 < X      and also   X < 10
                          How you write the "and also" depends on the progrmaming language. In JavaScrip you can write
                          ( 7 < X  ) && ( X < 10 )
                          Notice it is two ampersands &&. One ampersand is accepted but doesn't do what you want.
                          For more complex cases if ... else if ... else if ... is useful. Notice the else, the crucial thing which means it is only applicable if other tests fail.
                          Please don't ask for code to copy/paste. It's helpful to know you are new to JavaScript, but that doesn't mean you shouldn't be trying to learn... We are here to help you learn how to do something, not to do it for you! (In my opinion).
                          • 10. Re: Custom JavaScript Code for If/Then/Else Statement
                            vascocenco Level 1
                            i can't figure how to do...can i send the form  to you?....maybe you will be able to write the corect code.
                            thank you again!
                            • 11. Re: Custom JavaScript Code for If/Then/Else Statement
                              vascocenco Level 1
                              i understand perfect your oppinion regarding the process of learning and i am agree with you . Sincerely speaking i don't know where to find a turorial which to tell me from zero (begginer) to a user with some knoledge like this kind that i need in this case. I appreciate any help and one again i am agree with you.
                              thank you!
                              • 14. Re: Custom JavaScript Code for If/Then/Else Statement
                                slehmann7
                                I need some help as well. I am trying to input an if statement that says.
                                If the Fieldx is greater than 45, then input 45, otherwise, input the number in Fieldx.
                                I am not good with javascript so I could use some assistance please.
                                Thank you
                                • 15. Re: Custom JavaScript Code for If/Then/Else Statement
                                  There are many ways to use custom JavaScript calculations to perform this task. With custom calculations one needs to know the name of the fields to process.
                                  var nValue = Number(this.getField("Name of field to test").value); // get the value of the field to test as a number;
                                  // test the value of the field
                                  if(nValue > 45) {
                                  // value is greater than 45 - set field value to 45;
                                  event.value = 45;
                                  } else {
                                  // value not greater than 45 set field value to tested field value;
                                  event.value = nValue;
                                  } // end of test
                                  Or one could test for the minimum of the 2 values
                                  // set value to the minimum of 45 of the value of the tested field
                                  event.value = Math.min(45, nValue);
                                  // end of calculation;
