Since updating to CFB update 1 I have been getting frequent "Unhandled event loop exception java.lang.StackOverflowError" errors when trying to copy/paste text. It only happens (so far) when I use CTL+C to copy, but once it does happens I have to restart CFB to work. I've tried with syntax checking on and off, same effect. It doesn't happen every time, but it happens enough that I can reproduce it every few minutes.
I'm running CFB as a plugin inside of FB4 running on Windows 7 Pro 64bit. This just started happening since the update.
Update: Though it is odd that I didn't get the error until applying the update (and the update specifically fixes this issue), it seems to be gone now. Being that I have installed CFB inside of FB as a plugin I launched FB with the "-clean" parameter. Since then I have not seen the error.
The release notes explain:
(For plug-in Installation) Start ColdFusion Builder using the following command:
eclipse –clean
However, perhpas this should also explain the need to run FlashBuilder.exe with the -clean option if installed as a plugin to FB. For dummies like me this would be helpful
