7 Replies Latest reply on Oct 13, 2006 8:39 AM by La Bestia
    HTML/CSS Layout Help
    La Bestia
      Here is my layout and code. What I am simply trying to accomplish is to position that red div(rightcolumn) over to the right of the gray div (leftcolumn) I have attached the code I currently have in Dreamweaver. Can anyone tell me what I need in the CSS in order to get this position to the right. I would like the content box to shrink the content so the layout is fluid so I dont think absolute positioning will be right here.
      http://i30.photobucket.com/albums/c313/pcproff/layout.gif">
      http://i30.photobucket.com/albums/c313/pcproff/code.gif">
        • 1. Re: HTML/CSS Layout Help
          Level 7
          > <img src=" http://i30.photobucket.com/albums/c313/pcproff/code.gif">
          > <img src=" http://i30.photobucket.com/albums/c313/pcproff/layout.gif">
          #leftcolumn {
          float: left;
          background-color: #666666;
          padding: 10px;
          width: 355px;
          #rightcolumn {
          float: left;
          background-color: #FF9933;
          padding: 10px;
          width: 355px;
          • 2. Re: HTML/CSS Layout Help
            Level 7
            Also:
            Add clear; both; to your #footer as well. That will push it down under
            the floated <divs>
            If the #footer is inserted within the #container <div> then theres no
            need to declare its with. A <div> will expand to take up the width of
            its parent container.
            If the #footer is not within the #container then make its with 730px.
            Padding gets added to the width of the <div> so you need to get rid of 20px.
            A tip: It is nearly always better to add padding to content within the
            <div> like a <p> paragraph. This will stop you having to worry about the
            calculations so much
            Osgood wrote:
            > #leftcolumn {
            > float: left;
            > padding: 10px;
            > width: 355px;
            > #rightcolumn {
            > float: left;
            > padding: 10px;
            > width: 355px;
            • 3. Re: HTML/CSS Layout Help
              La Bestia Level 1
              OK one other question.... How can I center the entire layout??
              • 4. Re: HTML/CSS Layout Help
                Level 7
                Alter the #container margin css to:
                margin: 0 auto;
                If you want it to center in IE5x then you need to add to your css:
                body {
                text-align: center;
                plus add
                text-align: left; to the #container css.
                • 5. Re: HTML/CSS Layout Help
                  Level 7
                  You should end up with this:
                  <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN"
                  " http://www.w3.org/TR/html4/loose.dtd">
                  <html>
                  <head>
                  <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
                  <title>Untitled Document</title>
                  <style type="text/css">
                  body {
                  text-align: center;
                  #container {
                  padding: 10px;
                  width: 750px; /* real width 770px */
                  background-color: #cccccc;
                  text-align:left;
                  #leftcolumn {
                  float: left;
                  padding: 10px;
                  width: 355px; /* real width 375px */
                  #rightcolumn {
                  float: left;
                  background-color: #cc3333;
                  padding: 10px;
                  #footer {
                  background-color: #ff9933;
                  padding: 10px;
                  } </style>
                  </head>
                  <body>
                  <div id="container">
                  <div id="leftcolumn">Left Column</div>
                  <div id="rightcolumn">Right Column</div>
                  <div id="footer">Footer</div>
                  </div>
                  </body>
                  </html>
                  > margin: 0 auto;
                  > body {
                  > text-align: center;
                  > plus add
                  • 6. Re: HTML/CSS Layout Help
                    Level 7
                    Geezz...... apart from I left out margin: 0 auto; from #container <div> css
                    > <html>
                    > <head>
                    > body {
                    > text-align: center;
                    > #container {
                    > padding: 10px;
                    > text-align:left;
                    > #leftcolumn {
                    > float: left;
                    > padding: 10px;
                    > #rightcolumn {
                    > float: left;
                    > padding: 10px;
                    > #footer {
                    > padding: 10px;
                    > } </style>
                    > </head>
                    > <body>
                    > </div>
                    > </body>
                    > </html>
                    >> margin: 0 auto;
                    >> body {
                    >> text-align: center;
                    >> plus add
                    • 7. Re: HTML/CSS Layout Help
                      La Bestia Level 1
                      Great stuff guys real knowledgable people in here! thanks again...
