2 Replies Latest reply on May 27, 2010 7:07 AM by Nytcia
    Dreamweaver as code generator for use in other applications?
    Nytcia
      Hello and thank you in advance for your time and your help!
      I realize and apologize for this lengthy post but I had to explain my issue thoroughly...
      I've just begun teaching myself to use Dreamweaver CS3 (on an iMac running OS X 10.5.8 - Leopard) with the  "Dreamweaver CS3 Missing Manual". I don't know HTML or CSS but am very  willing to learn as much as I can. In the near future, I hope to create a  new website for my domain in Dreamweaver. However, I have an urgent and  immediate need and would like to know whether Dreamweaver can serve a specific purpose...
      My question is whether I will still be able to accomplish the following (even if it is by different means) once I convert to Dreamweaver from FrontPage AND whether or not I should abolish all of the current files at my web server and remove FrontPage extensions before I invest any time into making Dreamweaver my new tool for website development and maintenance.
      I have a domain hosted by GoDaddy and a rather old website that I created using FrontPage 2002 (on a Windows XP desktop). For over 5 years now, I've used FrontPage so that I can work WYSIWYG to generate HTML code that I use in my eBay auction listings. Recently, however, the "network folder" for my web server (on the Windows XP desktop) stopped accepting my password and I cannot find a fix for it. It's my opportunity to finally break from FrontPage but I'm hoping that, before I do, someone can tell me whether or not Dreamweaver can serve my interim and long-term purposes.
      I've been uploading image files using the "network folder" in Windows XP that I set up with FrontPage over 5 years ago. I "drag and drop" or "cut and paste" image files from my computer to my web server in Windows Explorer via the "network folder". Once the images are on the web server, I open FrontPage and ensure that the images show up in my web server files. I then open an existing .html document that I have saved on my hard drive, replace text and images within the file, save the file under a different file name, and then switch to code view where I copy the code directly from FrontPage into my eBay listing. This works perfectly well and has for over 5 years. I do not publish these .html files to the web, nor do I upload the .html files to my web server. They exist only on my hard drive and simply to provide the underlying HTML code for the eBay listings and nothing more. This method allows the images in my eBay auctions to be automatically sourced to their location on my web server without requiring me to do anything more than insert the image(s) from my web server into the .html document/file.
      I think I'm discovering that Dreamweaver works specifically with websites and I'm wondering whether I can use it more generically in this way. If I'm learning correctly, Dreamweaver is quite particular about web server files having an exact match to a root folder on my hard drive. I've defined my site within Dreamweaver and I've since downloaded all existing files from my web server to my hard drive within a folder that is designated as the root folder. However, when I now open an existing .html document (one originally created in FrontPage and stored on my hard drive only) and replace an image (by cutting the existing image and dragging the other from the "remote view" of the "files" pane) with one that exists both on my web server and in my root folder, Dreamweaver makes the source/reference path point to the image file on my hard drive and, as you know, that won't do if I transfer that code to my eBay listing. So I've uploaded the actual .html file to the web server within Dreamweaver (something that I never had to do with FrontPage) and now I can change the HTML code manually (or the source in the "properties" panel for the image) for the image source to include "http://mydomain/..." (it doesn't include that automatically as FrontPage did). That now seems to make the code work but I have to store my .html files on the server and I have to make that manual change.
      My question is whether I will still be able to do accomplish  the following (even if it is by different means) once I convert to  Dreamweaver from FrontPage AND whether or not I should abolish all of  the current files at my web server and remove FrontPage extensions  before I invest any time into making Dreamweaver my new tool for website  development and maintenance.
      Thank you very sincerely for taking the time to read this and for your response and good advice!
        • 1. Re: Dreamweaver as code generator for use in other applications?
          Get Turbo Lister (a free page editing and listing tool from eBay).
          http://pages.ebay.com/turbo_lister/
          eBay uses some seriously flawed markup on their auction pages.  In fact, they don't even ALLOW you to use good code. You're better off using their proprietary tools for this.   IMO, DW is not the right tool for creating eBay pages.
          When you're ready to build a serious web site, come back to Dreamweaver.
          Nancy O.
          Alt-Web Design & Publishing
          Web | Graphics | Print | Media  Specialists
          http://alt-web.com/
          http://twitter.com/altweb
          http://alt-web.blogspot.com
          • 2. Re: Dreamweaver as code generator for use in other applications?
            Nytcia Level 1
            Thank you for your opinion and for the alternate suggestion, Nancy! I've used TurboLister before but I hoped that I might be able to use one program for everything. I now do believe that I will be able to use Dreamweaver in the way that I used to use FrontPage... it's just that I wasn't actually uploading the .html document to my web server and that's why the source for my image wasn't pointing to my web server but to my local drive instead. In any case, uploading the .html file to the web server allowed me to edit the source that was then pointing to the file on the web server. I expect that the underlying code will be sufficient for my eBay listings but will find out later today for certain. If everything works, I'll continue to use DW for this minor function but I'll be wary based on your advice. I'm most eager to spend the time teaching myself DW and to start replacing the pages on my site with the new site that I'll create in DW.
            I truly appreciate your time and attention, Nancy... thank you again!
