3 Replies Latest reply on May 26, 2010 5:04 PM by bringrags
    Seeking and Buffering events
    fallenCEO
      I have a fully loaded http video and every time I use a seek function the MediaPlayerStateChangeEvent fires off a MediaPlayerState.BUFFERING event.
      This confuses me a little because I don't expect any Buffering events in a fully loaded http video.
      Is it right for OSMF to fire these buffering events for all 'seeking' ?
      regards
        • 1. Re: Seeking and Buffering events
          bringrags Level 4
          This is intentional.  The "buffering" state is meant to map to the UI being inactive -- we map seek events and buffering events into that one state, so that at the UI level you don't need to check for multiple states.  (We debated this a bit, and ultimately felt that it was better to make things easy for the UI developer, rather than being overly precise with the semantic of the event/state.)
          • 2. Re: Seeking and Buffering events
            fallenCEO Level 1
            Brian, thanks for the fast response,
            That's probably a good thing - I have often got into a mess with buffering events firing off in all directions leading to
            crazy UI effects.
            However in this case I don't want the buffering view to show when the user seeks.
            So how best to handle this whilst still coding to the OSMF api ?
            I'd like to avoid the flags and suchlike:
            if (seeking == false) {
            showBufferAnimation()
            regards
            • 3. Re: Seeking and Buffering events
              bringrags Level 4
              In that case, you would need to check the seeking state to determine whether to show the animation (i.e. the approach you're hoping to avoid).  I don't see a problem with this, as the state is managed by the MediaPlayer, so it's only one additional line of code on your side.
