2 Replies Latest reply on May 27, 2010 9:14 AM by gmh77
    Prompt for export location
    gmh77
      Hello,
      I am creating a simple script to automate exporting a document as a pdf. How can I prompt the user for the export location with a file browser dialog? (Using javascript). Here is the script:
      // choose PDF preset
      var myPDFExportPreset = app.pdfExportPresets.item("PRESS");
      // get document name
      var myDocName = app.activeDocument.name;
      // remove .indd from filename
      var newDocName = myDocName.substring(0,myDocName.length-5);
      // create exported filename
      var myFile = File("/c/"+newDocName+" - PRESS.pdf");
      // export the PDF
      app.activeDocument.exportFile(ExportFormat.pdfType, myFile,false, myPDFExportPreset);
      Right now it exports the PDF to /c/ - but I'd like to be able to browse for the export location. Can this be done?
        • 1. Re: Prompt for export location
          Shonkyin Level 3
          You can select a folder with Folder.selectDialog()
          Try with below code:
          //select output folder
          var myOutputFolder = Folder.selectDialog( 'Select output folder');
          var myFile = File(myOutputFolder + "/" + newDocName + " - PRESS.pdf");
          // export the PDF
          Shonky
          • 2. Re: Prompt for export location
            gmh77 Level 1
            Perfect! Thank you very much.
