0 Replies Latest reply on May 26, 2010 5:20 PM by Jason Szeto
    [svn:fx-trunk] 16331: Form Bug Fixes
    Jason Szeto Level 3
      Revision: 16331
      Revision: 16331
      Author:   jszeto@adobe.com
      Date:     2010-05-26 17:20:51 -0700 (Wed, 26 May 2010)
      Log Message:
      Form Bug Fixes
      SDK-26517 - Form should take into account includeInLayout property when calculating baselineElementPosition
      Added logic into Group to find the first element that has includeInLayout == true.
      SDK-26509 - Spark Form shows dual error strings in non-stacked layout
      Removed error string from FormSkin. Created a StackedFormSKin skin which includes the error string.
      SDK-26499 - Spark Form skin should use errorStringDisplay skin part instead of errorStringText
      Changed name to errorTextDisplay
      SDK-26498 - Spark Form needs more padding around error strings
      Added padding to the entire Form
      SDK-26503 - Difficult to create custom Spark FormItem skin due to embedded required/error icon assets
      Added new requiredIndicatorSource and errorIndicatorSource styles to FormItem. FormItem skins now grab the icons from these styles. Custom skin also have access to these icons.
      QE notes: Form layout has changed
      Doc notes: none
      Bugs: SDK-26517, SDK-26509, SDK-26499, SDK-26498, SDK-26503
      Reviewer: Kevin
      Tests run: checkintests
      Is noteworthy for integration: no
      Ticket Links:
          http://bugs.adobe.com/jira/browse/SDK-26517
          http://bugs.adobe.com/jira/browse/SDK-26509
          http://bugs.adobe.com/jira/browse/SDK-26499
          http://bugs.adobe.com/jira/browse/SDK-26498
          http://bugs.adobe.com/jira/browse/SDK-26503
      Modified Paths:
          flex/sdk/trunk/frameworks/build_framework.xml
          flex/sdk/trunk/frameworks/projects/spark/build.xml
          flex/sdk/trunk/frameworks/projects/spark/defaults.css
          flex/sdk/trunk/frameworks/projects/spark/src/SparkClasses.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/FormItem.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/components/Group.as
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormHeadingSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormItemSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/FormSkin.mxml
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/StackedFormHeadingSkin.mxm l
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/StackedFormItemSkin.mxml
          flex/sdk/trunk/frameworks/tests/basicTests/spark/scripts/FormTestScript.mxml
      Added Paths:
          flex/sdk/trunk/frameworks/projects/spark/assets/
          flex/sdk/trunk/frameworks/projects/spark/assets/ErrorIndicator.png
          flex/sdk/trunk/frameworks/projects/spark/assets/RequiredIndicator.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/StackedFormSkin.mxml
      Removed Paths:
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/assets/ErrorIndicator.png
          flex/sdk/trunk/frameworks/projects/spark/src/spark/skins/spark/assets/RequiredIndicator.p ng
