2 Replies Latest reply on May 26, 2010 7:51 PM by UbuntuPenguin
    XML-based dataprovider of Combobox / Dropdownlist (spark)
    Yogi_K
      Hey guys,
      I am struggling a bit with a problem...
      I have an XML file which I use as a dataprovider for a combobox / dropdownlist. If I do that just in Flex with MXML (with a HTTP Service call and using its last result) it is working fine. However I need to replace that XML file dynamically.
      But if I assign a a section of a dynamically loaded XML file (loading is successful (e.g. xmlFile.Sensors) as dataprovider I get that message:
      Type Coercion failed: cannot convert XMLList@18d8b629 to mx.collections.IList.
      Well, I came around by that:
      var collection:XMLListCollection = new XMLListCollection();
      for each (var t:XML in sensorXml.Sensors)
           collection.addItem(t);
      ...and using the collection as a dataprovider. But seems a bit unuseful...isn't there a faster / more direct approach to populate the dropdownlist with its contents? Especially since e.g. the dataGrid offers to use XML files directly as dataproviders...
        • 1. Re: XML-based dataprovider of Combobox / Dropdownlist (spark)
          UbuntuPenguin Level 4
          Try ,
          collection.source = sensorXml.Sensors;
          Here is a link that goes into more depth ,
          http://thanksmister.com/index.php/archive/binding-xml-to-combobox/
          • 2. Re: XML-based dataprovider of Combobox / Dropdownlist (spark)
            David_F57 Level 5
            The following is a basic app that will dynamically load your xml result into your comboboxes dataprovider.
            hope it helps
            David.
               xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="955" minHeight="600" creationComplete="app_creationCompleteHandler(event)"">
            <fx:Script>
            <![CDATA[
            import mx.events.FlexEvent;
            import mx.rpc.events.FaultEvent;
            import mx.rpc.events.ResultEvent;
            protected function myXML_resultHandler(event:ResultEvent):void
            xmlMainMenu.source = event.result.children();
            protected function myXML_faultHandler(event:FaultEvent):void
            //Alert.show("Sorry Couldn't load XML","Error Message");
            protected function app_creationCompleteHandler(event:FlexEvent):void
            myXML.send();
            </fx:Script>
            <fx:Declarations>
            <s:HTTPService id="myXML" url="data.xml" resultFormat="e4x"
               result="myXML_resultHandler(event)" fault="myXML_faultHandler(event)"/>
            </fx:Declarations>
            <s:ComboBox x="57" y="142" width="150" labelField="@label">
            <s:dataProvider>
            <s:XMLListCollection id="xmlMainMenu" />
            </s:dataProvider>
            </s:ComboBox>
            </s:Application>
            the xml
            <?xml version="1.0" encoding="UTF-8" standalone="no" ?>
            <menu>
            <item label="Group One">
            <img url="images/img02.jpg"/>
            </item>
            <item label="Group Two">
            <img url="images/img05.jpg"/>
            <img url="images/img06.jpg"/>
            <img url="images/img07.jpg"/>
            </item>
            <item label="Group Three">
            <img url="images/img08.jpg"/>
            <img url="images/img09.jpg"/>
            <img url="images/img10.jpg"/>
            <img url="images/img04.jpg"/>
            </item>
            <item label="Group Four">
            </item>
            <item label="Group Five">
            </item>
            </menu>
