11 Replies Latest reply on Jul 18, 2010 8:55 PM by kibobella
    MediaLayer.dll crashes when using PE 7
    kibobella
      I have spent hours trying to overcome the problem of frequent crashing at MediaLayer and hours reading through the forum articles but no where can I find out what, how and why crashes occur in this file, does anyone know?
        • 1. Re: MediaLayer.dll crashes when using PE 7
          the_wine_snob Level 9
          Unfortunately, we will need a lot more info on your system, your OS, your Project Preset, your source footage, and what you are doing, when you get the crash. This ARTICLE will give you tips on what would be very useful.
          Good luck, and let us have more info please.
          • 2. Re: MediaLayer.dll crashes when using PE 7
            kibobella Level 1
            Dear Bill, How do I send you all the information you ask for, it is too much to retype but I have it in Wordpad but cannot find a way of posting it on this forum.   Do you have an email address I can send to?
            • 3. Re: MediaLayer.dll crashes when using PE 7
              That would be called "copy and paste" and don't send to Hunt... post here so everyone may view and come up with ideas
              • 4. Re: MediaLayer.dll crashes when using PE 7
                At one time, we had a Attach File feature, that worked perfectly for this sort of data transfer. Unfortunately, some users were attaching all sorts of nefarious files, so Adobe disabled it, and is working to patch the security aspect of it. That is a work in progress, and obviously Adobe has not felt that they have completed the work, as we do not yet have it back.
                In the meantime, I'd do as John T. suggests, and just Ctrl+C/Ctrl+V to get the highlights of your DOC file into a reply. We'll just read down and try to find things that do not match up, or something missing.
                Sorry that the Attach File function is disabled, 'cause it worked so well for situations like this.
                • 5. Re: MediaLayer.dll crashes when using PE 7
                  kibobella Level 1
                  Hi Folks,
                  Sorry for the delay, however better late than never here is all the
                  information I could gather ... I hope that it is not too much!
                  Regards, kibobella
                  PROBLEMS WITH PREMIERE ELEMENTS 7
                  *The only work I do on this computer is video editing, and when I do this It
                  is disconnected from networks and the virus protection software is disabled.
                  I have run a utioity to minimize the number of programmes that run on start
                  up and yet I frequently get the message that PE7 is running low on memory...
                  this in spite of having 4Gb installed with the swap files set to 12 Gb on
                  each drive. PE 7 is installed on drive C which has 124 Gb free, video and
                  other files are on drive D with 112 Gb free and also on drive K which has
                  1.13 Tb free. The problems I have experienced have occurred over a variety
                  of my projects, but the current one has (showing on the time line) 55
                  minutes of HDvideo, 12 jpg images and 12 jpg scans. I progressed the project
                  by saving frequently after adding each title and menu element, so that I was
                  able to make progress past the crashes only to be frustrated at the end by
                  the application crashing when trying to burn onto dvd. I have updated the
                  Nvidia drivers and also the Quick Time programme, prior to the following
                  incidents. I have also uninstalled and re-installed PE 7 twice.*
                  *Given that these crashes have occurred with a variety of projects I do not
                  think that it is caused by this particular set of assets. The video camera
                  is a Canon HF10 with flash memory and the files are loaded using Canon's
                  Imagemixer software and then loaded into PE 7 from the PC files.*
                  What do you think is going wrong?
                  INFORMATION ABOUT CRASHES
                  Problem signature:
                  Problem Event Name: APPCRASH
                  Application Name: Adobe Premiere Elements.exe
                  Application Version: 7.0.0.0
                  Application Timestamp: 48cee0db
                  Fault Module Name: MediaLayer.dll
                  Fault Module Version: 7.0.0.0
                  Fault Module Timestamp: 48ced19b
                  Exception Code: c0000005
                  Exception Offset: 00343978
                  OS Version: 6.0.6002.2.2.0.768.3
                  Locale ID: 3081
                  Additional Information 1: fd00
                  Additional Information 2: ea6f5fe8924aaa756324d57f87834160
                  Additional Information 3: fd00
                  Additional Information 4: ea6f5fe8924aaa756324d57f87834160
                  Read our privacy statement:
                  http://go.microsoft.com/fwlink/?linkid=50163&clcid=0x0409
                  Problem signature:
                  Locale ID: 3081
                  INFORMATION ABOUT COMPUTER
                  OS Name Microsoft® Windows Vista™ Home Premium
                  Version 6.0.6002 Service Pack 2 Build 6002
                  Other OS Description Not Available
                  OS Manufacturer Microsoft Corporation
                  System Name MARKCOOPERPC
                  System Manufacturer System manufacturer
                  System Model P5Q SE/R
                  System Type X86-based PC
                  Processor Intel(R) Core(TM)2 Quad CPU Q9550 @ 2.83GHz, 2833 Mhz, 4 Core(s),
                  4 Logical Processor(s)
                  BIOS Version/Date American Megatrends Inc. 0906, 6/03/2009
                  SMBIOS Version 2.5
                  Windows Directory C:\Windows
                  System Directory C:\Windows\system32
                  Boot Device \Device\HarddiskVolume1
                  Locale Australia
                  Hardware Abstraction Layer Version = "6.0.6002.18005"
                  User Name MarkcooperPC\Mark Cooper
                  Time Zone AUS Eastern Standard Time
                  Installed Physical Memory (RAM) 4.00 GB
                  Total Physical Memory 3.25 GB
                  Available Physical Memory 2.01 GB
                  Total Virtual Memory 16.4 GB
                  Available Virtual Memory 15.2 GB
                  Page File Space 13.2 GB
                  Page File C:\pagefile.sys
                  VIDEO CARD - NVIDIA GeForce 9800 GT
                  EXTRACT FROM WINDOWS ERROR REPORTING
                  5/05/2010 5:26 AM Application Error Faulting application 3 Mobile
                  Broadband.exe, version 1.0.0.1, time stamp 0x48bd0ea9, faulting module
                  unknown, version 0.0.0.0, time stamp 0x00000000, exception code 0xc0000005,
                  fault offset 0x01fb9966, process id 0x15f0, application start time
                  0x01caeb2399fe22d7.
                  30/07/2009 4:33 AM Application Error Faulting application Adobe Premiere
                  Elements.exe, version 7.0.0.0, time stamp 0x48cee0db, faulting module
                  ad2mpgdmux.dll, version 7.5.0.34854, time stamp 0x48c8ca9c, exception code
                  0xc0000005, fault offset 0x00001307, process id 0x11a4, application start
                  time 0x01ca10b468d69e92.
                  11/05/2009 3:52 AM Application Error Faulting application Adobe Premiere
                  ImageRenderer.dll, version 7.0.0.0, time stamp 0x48cecec4, exception code
                  0xc0000005, fault offset 0x0001ec60, process id 0xc30, application start
                  time 0x01c9d03ab36dc1c1.
                  19/04/2009 3:46 AM Application Error Faulting application Adobe Premiere
                  ImporterAVI.prm, version 7.0.0.0, time stamp 0x48cee5b9, exception code
                  0xc0000005, fault offset 0x000058a7, process id 0x15a0, application start
                  time 0x01c9c0a108394792.
                  19/05/2009 10:30 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x0001d338, process id 0x6c4, application start
                  time 0x01c9d86ca9ba3098.
                  19/05/2009 9:34 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00029761, process id 0x1648, application start
                  time 0x01c9d84c00593078.
                  19/05/2009 10:29 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x0002977c, process id 0x14b4, application start
                  time 0x01c9d86510d2d5a8.
                  15/08/2009 11:45 PM Application Error Faulting application Adobe Premiere
                  ImporterFastMPEG.prm, version 7.0.0.0, time stamp 0x48cee66e, exception code
                  0xc0000005, fault offset 0x0000842d, process id 0x105c, application start
                  time 0x01ca1def097ce610.
                  6/08/2009 5:12 AM Application Error Faulting application Adobe Premiere
                  IPPMPEGDecoder.dll, version 7.0.0.0, time stamp 0x48ced1e5, exception code
                  0xc0000005, fault offset 0x000106c2, process id 0x1ce0, application start
                  time 0x01ca1631a0170c10.
                  11/06/2009 10:26 PM Application Error Faulting application Adobe Premiere
                  kernel32.dll, version 6.0.6001.18215, time stamp 0x49953395, exception code
                  0xc06d007e, fault offset 0x000442eb, process id 0x10e8, application start
                  time 0x01c9eade9f3c7ab0.
                  18/05/2009 11:32 PM Application Error Faulting application Adobe Premiere
                  0xc06d007e, fault offset 0x000442eb, process id 0x1574, application start
                  time 0x01c9d806eab92f50.
                  3/09/2009 10:12 PM Application Error Faulting application Adobe Premiere
                  0xc06d007e, fault offset 0x000442eb, process id 0xe80, application start
                  time 0x01ca2ce0ab548560.
                  29/04/2010 1:40 AM Application Error Faulting application Adobe Premiere
                  kernel32.dll, version 6.0.6002.18005, time stamp 0x49e037dd, exception code
                  0xc06d007e, fault offset 0x0003fbae, process id 0xf48, application start
                  time 0x01cae72fa9858720.
                  27/04/2010 3:33 AM Application Error Faulting application Adobe Premiere
                  MediaLayer.dll, version 7.0.0.0, time stamp 0x48ced19b, exception code
                  0xc0000005, fault offset 0x00343978, process id 0x1020, application start
                  time 0x01cae5b4801961cb.
                  31/07/2009 12:03 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1024, application start
                  time 0x01ca116ef8d8b190.
                  19/04/2010 10:45 PM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1098, application start
                  time 0x01cadeb5f32f7160.
                  27/04/2010 2:38 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1180, application start
                  time 0x01cae5ad3321442b.
                  26/04/2010 5:14 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1208, application start
                  time 0x01cae4f048743855.
                  31/07/2009 5:08 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1210, application start
                  time 0x01ca11784f4a17e0.
                  17/08/2009 5:32 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1280, application start
                  time 0x01ca1efaf302c5f4.
                  31/07/2009 5:28 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1380, application start
                  time 0x01ca119d73203a30.
                  17/08/2009 4:04 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1384, application start
                  time 0x01ca1eef426a7700.
                  17/08/2009 6:17 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x138c, application start
                  time 0x01ca1efd7600d264.
                  27/04/2010 4:41 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x13a8, application start
                  time 0x01cae5c3693da442.
                  27/04/2010 4:32 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x13ac, application start
                  time 0x01cae5c10e0f46fb.
                  20/04/2010 2:41 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x13e0, application start
                  time 0x01cae02cda98ad56.
                  1/05/2010 3:52 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1404, application start
                  time 0x01cae8de0a7fc590.
                  27/04/2010 6:54 AM Application Error Faulting application Adobe Premiere
                  0xc0000005, fault offset 0x00343978, process id 0x1414, application start
                  time 0x01cae5d5deb0073b.
                  • 6. Re: MediaLayer.dll crashes when using PE 7
                    TheBaldConvict
                    Am searching for an answer to this problem here too, Have just encounted a client having this exact problem including the same exception offsets and so on.
                    One of their machines is a dual core Intel with 3GB ram and 1TB free HDD, the other is a Quad core with 3GB ram and 2TB free HDD.
                    Both run Windows 7 32bit and get the same messages regarding running low on system memory and the crashes although the crashes seem more frequent when putting an image onto the time line perhaps coincidence?
                    Anyway, any help would be most appreciated.
                    • 7. Re: MediaLayer.dll crashes when using PE 7
                      kibobella Level 1
                      Dear John,
                      How is progress on my problem?
                      Regards,
                      kibobella
                      • 8. Re: MediaLayer.dll crashes when using PE 7
                        Here are some other threads with a common element:
                        http://forums.adobe.com/thread/528344
                        http://forums.adobe.com/thread/445200
                        http://forums.adobe.com/thread/389312
                        http://www.geekstogo.com/forum/Audio-Device-High-Definition-Audio-Bus-t146422.html&st=15
                        http://muvipix.com/phpBB3/viewtopic.php?f=8&t=570
                        Considering the other .dll's, that are also faulting, I have two thoughts:
                        1.) something that is probably loaded at boot up is either not reporting its memory usage properly, or is informing the OS that it has released certain memory addresses, when it has not.
                        2.) the installation of PrE has become corrupted. If possible, I would try a Repair Install, and if not, I would uninstall, run a Registry cleaner, like Ccleaner (do the Registry backup, when prompted), and reinstall PrE.
                        • 9. Re: MediaLayer.dll crashes when using PE 7
                          kibobella Level 1
                          Thank you Bill for your response, I have read all of the links you
                          attached.   in respect to your suggestions I have carried 'suggestion 2'
                          twice over.   With suggestion 1 I have subsequent to the appearance of these
                          difficulties cleaned out my 'start up list' and I usually disable the virus
                          software (Avast) and this computer is rarely connected to the internet and
                          never when using PE software.   I notice that there are some hints that some
                          have found it better to work on several small files first and then stitch
                          them together before the final rendering.   My current project started off
                          with about 2 hours of video, is this likely to  be a problem or is this not
                          relevant?   What does MediaLayer.dll do?  Is it an Adobe created file or is
                          it a Windows file?   One thing that does worry me a little is that whenever
                          I open PE7 it builds a library of thumbnails of all the videos I have on the
                          computer.   It does this even though I reduce the number of thumbnails
                          visible by specifying the particular project I am working on.   This
                          facility must consume RAM, would it be possible/helpful to disable it.
                          I notice from a number of comments in the forum and elsewhere on the net
                          that Adobe appears to have a 'hard nosed' attitude to its customers.    I
                          too object to having to pay for a service call, but would consider doing
                          so if there was a guarantee that they would work on it until my problem was
                          resolved.   It is a shame that they do not a 'product recall' system forced
                          upon them as the car manufacturers do!    Do all of the video editing
                          programmes have problems, which of them are more reliable?
                          Regards,
                          Kibobella
                          • 10. Re: MediaLayer.dll crashes when using PE 7
                            I have 5 copies of MediaLayer.dll on my laptop, one for each of my Adobe Video, or Audio editing programs.
                            A .dll, is a Dynamic Link Library, and contains code that is used by the program to perform certain operations. It is called by that program, when needed.
                            I do not know what is enclosed in the MediaLayer.dll, but as I see it in PrE, Premiere, Encore, Audition, etc., would assume that it contains info/code for both Audio & Video.
                            • 11. Re: MediaLayer.dll crashes when using PE 7
                              kibobella Level 1
                              Thanks Bill,
                              I am assuming from your reply that you can see no obvious cause of the
                              frequent shut downs I am experiencing from PE 7 from the respect of my
                              hardware resources.   Would this be a valid assumption?
                              Regards,
                              Kibobella
