2 Replies Latest reply on May 27, 2010 7:39 AM by bogiesan-gyyClL
    Pre-Comp Question
    G626
      How do I prevent an object that is partly outside the composition window in a pre-comp layer not be cropped off? I am animating a pre-comp layer but part of the object starts outside the window. When I move it into the frame the areas that were outside the composition window is cut off.
        • 1. Re: Pre-Comp Question
          You can't. Make the pre-comp larger!
          Mylenium
          • 2. Re: Pre-Comp Question
            bogiesan-gyyClL Level 3
            > When I move it into the frame the areas that were outside the composition window is cut off.<
            As Myl says, make it larger.
            This is a fundamental aspect of precomposing but it's not immediately apparent until you've banged your head against it a couple of times. Understanding the apparent limits of precomposing is crucial to being able to make them all go away; they're not limitations at all.
            bogiesan
