3 Replies Latest reply on Jun 2, 2010 6:55 AM by cjolif-Fc6gNO
    Design work flow diagram using flex..
    satyasuppu Level 1
         Please tell me whether solution for this issue is feasible or not..
         Design a work fllow diagram using flex and save this diagram in xml format according to the changes u did on diagram..
        Drag data from the datagrid and drop it on canvas as taxt value..After droping it ,need to connect these values with arrows using mouse..Like this neeed to design a diagram .when i click on the save button it shoud save the sequence of vlaues which user has dragged and creadted the sequence we need to save..
      Please tell me whether it is feasible in fiex...
      I tried this..but didn't find any solution for this..i can drag data from grid to canvas..but not able to connect these values using arrows with the mouse.(design a diagram)..
      Please help me on this issue...
      Below is the code which i did for dragiing the data from grid to canvas....Iam bot able to connect these values with arrows..
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml"
        layout="absolute" name="Drag and Drop Tutorial"
        creationComplete="init()" >
        <mx:Script>
          <![CDATA[
            import mx.controls.Image;
            import mx.core.DragSource;
            import mx.core.IUIComponent;
            import mx.managers.DragManager;
            import mx.events.DragEvent;
            import mx.controls.Alert;
            import mx.controls.Text;
            import flash.geom.Point;
            import mx.rpc.events.FaultEvent;
            import mx.rpc.events.ResultEvent;
            import mx.collections.ArrayCollection;
            import oracle.ondemand.diagrammer.*;
            private var templateLine:Link;
            [Bindable]
            private var pictureData:ArrayCollection = new ArrayCollection([
              {JobName:"A"},{JobName:"B"},{JobName:"C"}, {JobName:"D"},{JobName:"E"},{JobName:"F"},{JobName:"G"}]);
            public function init():void
              // a mouseDown event will start the drag
              list.dataProvider = pictureData;
                   // accepting a drag/drop operation...
              this.area.addEventListener( DragEvent.DRAG_ENTER, acceptDrop );
              // handling the drop...
              this.area.addEventListener( DragEvent.DRAG_DROP, handleDrop );
             // this.area.addEventListener(Event.ADDED, handleAdded);
              //this.area.addEventListener(Event.REMOVED, handleRemoved);
            public function get isLinking():Boolean {
                  return this.templateLine.fromNode != null;
            public function beginDrag( mouseEvent:MouseEvent ):void
              var dragInitiator:Text = mouseEvent.currentTarget as Text;
              var dragSource:DragSource = new DragSource();
             // dsource.addData(this, 'node');
              dragSource.addData(this.mouseX, 'mouseX');
              dragSource.addData(this.mouseY, 'mouseY');
              //parent.addChild(dragImg);
              //dragSource.addData(mouseEvent.currentTarget.text, "txt");
              var dragProxy:Text=new Text();
              dragProxy.text = mouseEvent.currentTarget.text;
             // Alert.show("Text isss"+dragProxy.text);
             dragProxy.setActualSize(mouseEvent.currentTarget.width,mouseEvent.currentTarget.height)
              // ask the DragManger to begin the drag
              DragManager.doDrag( dragInitiator, dragSource, mouseEvent, dragProxy );
            public function acceptDrop( dragEvent:DragEvent ):void
              if (dragEvent.dragSource.hasFormat("items"))
                DragManager.showFeedback( DragManager.COPY );
                DragManager.acceptDragDrop(Canvas(dragEvent.currentTarget));
            public function handleDrop( dragEvent:DragEvent ):void
              var dragInitiator:IUIComponent = dragEvent.dragInitiator;
              var dropTarget:IUIComponent = dragEvent.currentTarget as IUIComponent;
              var items:Array  = dragEvent.dragSource.dataForFormat("items") as Array;
              var pt:Point = new Point(dragEvent.localX, dragEvent.localY);
              pt = dragEvent.target.localToContent(pt);
              var img:Text = new Text();
                img.x=dragEvent.localX;   img.y=dragEvent.localY;
             // img.x=pt.x - Number(dragEvent.dragSource.dataForFormat("mouseX"));
                //img.y=pt.y - Number(dragEvent.dragSource.dataForFormat("mouseY"));
              img.width = 50;
              img.height=50;
              // img.fontSize=20;     // img.source="assets/" + items[0].id + ".png";
              img.text=items[0].JobName.toString();
              img.addEventListener(MouseEvent.MOUSE_MOVE,beginDrag);
              area.addChild(img);
            public var xOff:Number;
            public var yOff:Number;
        </mx:Script>
        <mx:DataGrid id="list" width="152" height="200" labelField="JobName"
          dragEnabled="true" dataProvider="{pictureData}" mouseDown="beginDrag(event)" dragMoveEnabled="true" y="109" x="39"/>
          <!--<mx:columns>
            <mx:DataGridColumn dataField="id" id="code"/>
            <mx:DataGridColumn id="picture" draggable="true" >
              <mx:itemRenderer>
                <mx:Component>
                  <mx:Image source="assets/{data.id}.png" mouseDown="outerDocument.beginDrag(event)"/>
                </mx:Component>
              </mx:itemRenderer>
            </mx:DataGridColumn>
          </mx:columns>
        </mx:DataGrid>-->
        <mx:Canvas id="area" width="730" height="520"
          backgroundColor="white" dragDrop="handleDrop(event)"   x="209" y="10">
        </mx:Canvas>
      </mx:Application>
      Thanks in advance.....
        • 1. Re: Design work flow diagram using flex..
          TanweerHq Level 2
          Try this. I have added few lines in your code. Now it will draw lines between the items as soon as u drop them in canvas.
            <mx:Script>
              <![CDATA[
               /*  import oracle.ondemand.diagrammer.*;
                private var templateLine:Link; */
                [Bindable]
                      return false;//this.templateLine.fromNode != null;
                 dragProxy.setActualSize(mouseEvent.currentTarget.width,mouseEvent.currentTarget .height)
               var pt:Point;
                  pt = new Point(dragEvent.localX, dragEvent.localY);
                  img.width = 50;
                  img.height=50;
                  area.addChild(img);
                  pt.x = pt.x+5;
                  pt.y = pt.y+10;
                  if(area.getChildren().length>1){
                      end = pt;
                      drawLine();
                      start = end;
                  else{
                      start = pt;
              protected function drawLine() : void
                      var g:Graphics = ui.graphics;
                      //g.clear();
                      var lt:Number = 2;
                      g.lineStyle(lt, 0xAADDFF, 0.5);
                      createLine(g, start, end, false);
                  public static function createLine(g:Graphics, start:Point, end:Point,
                                                  dashed:Boolean = false, dashLength:Number = 10):void {
                      g.moveTo(start.x, start.y);
                      g.lineTo(end.x, end.y);
            </mx:Script>
              dragEnabled="true" dataProvider="{pictureData}" mouseDown="beginDrag(event)" dragMoveEnabled="true" y="217" x="28"/>
              <!--<mx:columns>
                  <mx:itemRenderer>
                    <mx:Component>
                    </mx:Component>
                  </mx:itemRenderer>
              </mx:columns>
            </mx:DataGrid>-->
            <mx:UIComponent width="700" height="320"  id="ui" x="199" y="217"/>
            <mx:Canvas id="area" width="700" height="320" alpha="0.5"
              backgroundColor="white" dragDrop="handleDrop(event)"   x="199" y="217">
            </mx:Canvas>
          </mx:Application>
          Message was edited by: TanweerHq >> edited drawLine function
          • 2. Re: Design work flow diagram using flex..
            satyasuppu Level 1
            Thank you very much for your help..
            I neeed to design a workflow diagram using flex and save this diagram in xml  format according to the diagram u drawn on UI.
            what needs be done iss::
              Drag all data  from the datagrid and drop it on canvas as taxt value..After droping it  ,need to connect these values with arrows using mouse..i.e design a workflow diagram.These should be one stating point,so that we can identify the start of the diagram..and Stop point....Like this neeed  to design a diagram .when i click on the save button it shoud save the  sequence of vlaues which user has dragged and creadted the sequence we  need to save in xml and save it in DB....
            Please  tell me whether it is feasible in fiex or not.......
            Thanks alot inadvance...
            • 3. Re: Design work flow diagram using flex..
              cjolif-Fc6gNO Level 1
              This is perfectly feasible. Actually several libraries will help you to
              achieve this. Including IBM ILOG Elixir Enteprise. Check
              http://www-01.ibm.com/software/integration/visualization/elixir-enterprise/
              and in particular:
              http://visunetdemos.demos.ibm.com/diagramdemos/bpmeditor/bpmeditor.html
              Hope this helps,
              Christophe
              satyasuppu <forums@adobe.com>
              To:
              Christophe Jolif/France/IBM@IBMFR
              Date:
              31/05/2010 11:24
              Subject:
