0 Replies Latest reply on May 27, 2010 5:01 AM by yderidde
    [svn:cairngorm3:] 16339: Refactoring/ re-organization of the Integration libraries
    yderidde
      Revision: 16339
      Revision: 16339
      Author:   yderidde@adobe.com
      Date:     2010-05-27 05:00:56 -0700 (Thu, 27 May 2010)
      Log Message:
      Refactoring/re-organization of the Integration libraries
      • Integration lib:
      com.adobe.cairngorm.integration.error.* (common channel/rpc errors)
      com.adobe.cairngorm.integration.file.* (delegate/responder for FileReference)
      • IntegrationDMS lib:
      com.adobe.cairngorm.integration.dms.* (parsley extentions for DMS)
        • IntegrationDMS library is now simplified and provide only few parsley decorators described below:
      DataServiceFaultHandler (Handle the Fault of a given DataService)
      GlobalDataServiceConflictHandler (Handle Data Management Conflicts globally for all DataService defined in parsley contexts)
      GlobalDataServiceFaultHandler (Handle the Fault of all DataService defined in parsley contexts)
      GlobalDataServiceResultHandler (Handle the Result of all DataService defined in parsley contexts)
      IsCommitRequired (Observe the commitRequired flag of a given DataService)
        • Adding support for LCDS 2.6, 3.0 and 3.1 in IntegrationDMS
      • IntegrationParsley lib:
      com.adobe.cairngorm.integration.data.* (Data Caching / highlander principal)
      com.adobe.cairngorm.integration.localconnection.* (local connection pub/sub - EXPERIMENTAL)
      com.adobe.cairngorm.integration.rpc.* (global error handler for RPC)
      Modified Paths:
          cairngorm3/trunk/libraries/Integration/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/.flexLibProperties
          cairngorm3/trunk/libraries/Integration/pom.xml
          cairngorm3/trunk/libraries/IntegrationDMS/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationDMS/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationDMS/pom.xml
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/CairngormIntegrationDMS Support.as
      Added Paths:
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/ChannelC onnectFailedEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/IService ErrorEventFactory.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/RequestT imeoutEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/ServiceE rrorEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/ServiceE rrorEventFactory.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/SessionT imeoutEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/SystemEr rorEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/error/UpdateCo nflictEvent.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/file/
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/file/FileRefer enceResponder.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/file/FileTrans ferDelegate.as
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/file/IFileRefe renceResponder.as
          cairngorm3/trunk/libraries/IntegrationDMS/libs/ASMock.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/ASMockFlexUnit4.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/FlexUnit4.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/FlexUnit4UIRunner.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/fds.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/fds_rb.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/hamcrest-as3.swc
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/Abstrac tGlobalDataServiceHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/DataSer viceConflictHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/DataSer viceFaultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/GlobalD ataServiceConflictHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/GlobalD ataServiceFaultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/GlobalD ataServiceResultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/IsCommi tRequired.as
          cairngorm3/trunk/libraries/IntegrationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.flexLibProperties
          cairngorm3/trunk/libraries/IntegrationParsley/.project
          cairngorm3/trunk/libraries/IntegrationParsley/.settings/
          cairngorm3/trunk/libraries/IntegrationParsley/.settings/org.eclipse.core.resources.prefs
          cairngorm3/trunk/libraries/IntegrationParsley/asdocPackageFile.xml
          cairngorm3/trunk/libraries/IntegrationParsley/build.properties
          cairngorm3/trunk/libraries/IntegrationParsley/build.xml
          cairngorm3/trunk/libraries/IntegrationParsley/libs/
          cairngorm3/trunk/libraries/IntegrationParsley/libs/FlexUnit4.swc
          cairngorm3/trunk/libraries/IntegrationParsley/libs/FlexUnit4UIRunner.swc
          cairngorm3/trunk/libraries/IntegrationParsley/libs/hamcrest-as3.swc
          cairngorm3/trunk/libraries/IntegrationParsley/libs/parsley-flex4-2.2.2.swc
          cairngorm3/trunk/libraries/IntegrationParsley/libs/spicelib-flex-2.2.2.swc
          cairngorm3/trunk/libraries/IntegrationParsley/pom.xml
          cairngorm3/trunk/libraries/IntegrationParsley/src/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/CairngormIntegratio nSupport.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/data/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/data/Da taCache.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/data/ID ataCache.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/data/Sy ncIdMetadata.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/ConsumerDelegate.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/ConsumerSettings.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/IConsumerDelegate.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/IProducerDelegate.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/MessageEvent.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/ProducerDelegate.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/ProducerSettings.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/decorator/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/decorator/LocalConnectionProxy.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/localco nnection/decorator/Subscribe.as
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/rpc/
          cairngorm3/trunk/libraries/IntegrationParsley/src/com/adobe/cairngorm/integration/rpc/Glo balRemoteObjectFaultHandler.as
      Removed Paths:
          cairngorm3/trunk/libraries/Integration/libs/parsley-flex4-2.2.2.swc
          cairngorm3/trunk/libraries/Integration/libs/spicelib-flex-2.2.2.swc
          cairngorm3/trunk/libraries/Integration/src/com/adobe/cairngorm/integration/core/
          cairngorm3/trunk/libraries/IntegrationDMS/libs/fds-2.6.1.swc
          cairngorm3/trunk/libraries/IntegrationDMS/libs/fds_rb-2.6.1.rb.swc
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/AbstractGlobalDataServiceHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/BaseOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/CommitOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/CreateItemOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/DataServiceConflictHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/DataServiceFaultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/DeleteItemOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/FillOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/GetItemOperationHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/GlobalDataServiceConflictHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/GlobalDataServiceFaultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/GlobalDataServiceResultHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/GlobalDataServiceStartHandler.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/IsCommitRequired.as
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/decorat ors/message/
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/delegat e/
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/error/
          cairngorm3/trunk/libraries/IntegrationDMS/src/com/adobe/cairngorm/integration/dms/respond er/
