3 Replies Latest reply on May 27, 2010 11:19 AM by MikeZaun
    Not advancing past 2nd scene.
    MikeZaun
      I recently downloaded the trial version of Flash Professional CS5.
      I made a SWF with 4 scenes and a button on each that toggles between the scenes.  I uploaded it to our website and on my PC it works perfectly but when I try from another computer the button on the 2nd scene does not work.  Any ideas?
        • 1. Re: Not advancing past 2nd scene.
          MikeZaun Level 1
          I also tried doing it just advancing frames instead of scenes and it stays stuck on frame 2 and wont advance on other computers but works perfectly on mine.
          Here is my code for scene two:
          stop();
          IBP2.restrict = "0-9"
          var input8:String;
          Submit4.addEventListener(MouseEvent.CLICK, fl_ClickToGoToScene_7);
          function fl_ClickToGoToScene_7(event:MouseEvent):void
          input8 = IBP2.text;
          MovieClip(this.root).gotoAndPlay(1, "Scene 3");
          • 2. Re: Not advancing past 2nd scene.
            put a trace() on frame 1 of "Scene 3" to confirm you're going to that frame.
            then, once that's confirmed, publish a swf and html and upload both.  do not edit the html.  post the url to the html and indicate the problematic button.
            • 3. Re: Not advancing past 2nd scene.
              MikeZaun Level 1
              Ok apparently its either because I am using a trial version or because its CS5.
              I created the same thing using a registered version of CS4 and it works on all machines.
              If anyone can figure out which is the case please let me know.
